Home » Modeling » TMF (Xtext) » ei.unescapeString(getText(), 1)
ei.unescapeString(getText(), 1) [message #25331] Sun, 04 January 2009 17:41 Go to next message
Hi eclipse.modeling.tmf group.
I have some strings delimited with double-quotes (eg. "string") and some
strings delimited by leading underscore and double quotes (eg. _"string").
I can add ('_\"' | '\"') to the NAME rule so the lexer can recognize both
strings but then the ei.unescapeString(getText(), 1) is a problem because
sometimes I need to escape just the double quotes and other times the
underscore and double-quotes.
Can anyone let me know how the unescapeString(String, int) method works
and how it may be used here or suggest another function which may deal
with this?
Jeff
Re: ei.unescapeString(getText(), 1) [message #25371 is a reply to message #25331] Mon, 05 January 2009 03:00 Go to previous messageGo to next message
I assume this question is dedicated to TCS, right?
Sven
> both strings but then the ei.unescapeString(getText(), 1) is a problem
> because sometimes I need to escape just the double quotes and other
> times the underscore and double-quotes.
> with this?
> Jeff
[TCS] Re: ei.unescapeString(getText(), 1) [message #25412 is a reply to message #25371] Mon, 05 January 2009 11:48 Go to previous messageGo to next message
That is correct. Sorry, I forgot the [TCS] prefix.
> Sven
>> I can add ('_"' | '"') to the NAME rule so the lexer can recognize
>> with this?
>> Thanks,
>> Jeff
Re:[TCS] ei.unescapeString(getText(), 1) [message #25453 is a reply to message #25331] Tue, 06 January 2009 04:20 Go to previous messageGo to next message
I can't tell you how the ei.unescapeString() function
works, but I don't think that you're trying to take the
correct approach.
As you have two different primitives, I think that you
need to declare two string primitiveTemplates. One of
these should be defined with the default keyword,
and will be called for most string type attributes in
your grammar. For string type attributes that need the
other syntax, use the "{as=xxx}" annotation on the
attribute name; where xxx is the name of your
non-default string primitiveTemplate.
I hope that this helps
Andy.
"J Rusk" <rusk@qiniq.com> wrote in message
news:8190d4c1599f5ad80a8260d6449b0b9a$1@www.eclipse.org...
> with this?
> Jeff
Re: [TCS] ei.unescapeString(getText(), 1) [message #25646 is a reply to message #25453] Tue, 06 January 2009 16:56 Go to previous messageGo to next message
Thanks Andy. Very good point. I likely was heading in the wrong direction.
Would this work in situations where I do not know in advance which
primitiveTemplate would be required for a given attribute (i.e. could be
"string" or _"string" for a given attribute)?
Jeff
> correct approach.
> Andy.
Re: [TCS] ei.unescapeString(getText(), 1) [message #25677 is a reply to message #25646] Fri, 09 January 2009 07:34 Go to previous messageGo to next message
Jeff,
The way that I'd handle this is by making the model
reflect more syntax than ideal by having an attribute
for each of the possible types. I'd then do an m2m
transformation to convert the 'syntactic' model into
a 'purer' form.
Andy.
news:cc1870b08f6247196a9c1a7403770c72$1@www.eclipse.org...
> direction.
> Jeff
>> correct approach.
>> Andy.
Re: [TCS] ei.unescapeString(getText(), 1) [message #25706 is a reply to message #25677] Sat, 10 January 2009 12:45 Go to previous messageGo to next message
Thanks. This was working for me just great - until I realized with an
example that the different syntaxes ("string", _"string", or just string)
can show up within the same attribute, please see example below:
importsOntology { GML#GML212Ontology, FilterEncoding#FilterEncoding,
_”http://www.swing-project.org/virtual” }
My basic problem is that any IRI can be abbreviated to a Compact URI. Full
IRI's are delimited with the symbols ' _" ' and ' " ' but Compact URI does
not require special delimiters.
I'm not sure where to go from here. Any thoughts?
> Jeff,
> a 'purer' form.
> Andy.
>> direction.
>> Jeff
>>> correct approach.
>>> Andy.
Re: [TCS] ei.unescapeString(getText(), 1) [message #25826 is a reply to message #25706] Sat, 10 January 2009 18:54 Go to previous message
Actually a colleague provided a hint which seems to do the trick.
Unfortunately, I'm usually oblivious to the simplest, most elegant
solution. Relevant additions to .tcs and .km3 below ...
In TCS:
template Full_IRI
: "_" <no_space> link
template Compact_IRI context
: link
template IRI abstract;
In KM3:
abstract class IRI extends LocatedElement {
attribute link : String;
class Full_IRI extends LocatedElement, IRI {}
class Compact_IRI extends LocatedElement, IRI {}
Previous Topic:Complex DSL
Next Topic:Dependency between eclipse plugins
Current Time: Mon May 12 05:40:07 EDT 2025
Powered by FUDForum. Page generated in 0.11134 seconds
