Array braces formatting [message #1439850] |
Tue, 07 October 2014 15:41 |
Robert Phillips Messages: 2 Registered: October 2014 |
I'm have trouble with the settings of the Eclipse formatter (Java ID on OSX 10.9.5). I want a simple array to look like this:
Foo myFoo[] =
foo1,
foo2,
foo3
but instead I get this:
Foo myFoo[] =
foo1,
foo2,
foo3
I found a discussion about formatting multi-dimensional arrays, and followed their formatting suggestions as their arrays looked like what I want, but I can't figure out how to set the indentation of the braces to line up as I want.
- New Lines: Array Initializer: Insert new line after opening brace of array initializer (checked)
- New Lines: Array Initializer: Insert new line before closing brace of array initializer (checked)
- Braces: Array Initializer: Next Line
- Line Wrapping: Array Initializers: Wrap all elements, each element on a new line, Indent by one
[Updated on: Wed, 08 October 2014 13:41] Report message to a moderator
Re: Array braces formatting [message #1440660 is a reply to message #1440607] |
Wed, 08 October 2014 17:12 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
Automatic code formatting is a moving target; you're never going to be able to match every person's exact desires for every situation. Even trying to do so results in a formatter framework with so many configuration options that it becomes nearly unusable.
Having said that, you're welcome to submit enhancement requests into Bugzilla; just be aware that the backlog of requests and bug reports is enormous, so unless you dive in an offer to help with implementation don't expect it to be implemented soon.
[Updated on: Wed, 08 October 2014 17:13] Report message to a moderator
FUDForum. Page generated in 0.09005 seconds
