Home » Eclipse Projects » Eclipse Platform » Corba + Eclipse: VerifyError exception
Corba + Eclipse: VerifyError exception [message #256694] Tue, 29 June 2004 11:09 Go to next message
I'm trying to initialize Corba (Visibroker) inside a plugin, and I get an
exception in the ORB.init(). It looks like the OMG code is trying to
install a class loader and that fails. Is this related to the new OSGi
framework of Eclipse ? (it's a bit too low-level for me, I must admit).
Has somebody already succeeded in initializing an ORB inside a plugin
(with Eclipse 3.0) ?
Laurent
PS: I don't know if this is related, but I also had to add this piece of
code before my call so that the OMG factory would find the correct
Visibroker classes:
Thread.currentThread().setContextClassLoader(this.getClass() .getClassLoader());
eclipse.buildId=unknown
java.version=1.4.1_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_CH
Command-line arguments: -application com.nagra.ims.topo.RcpApplication
!ENTRY org.eclipse.osgi juin 29, 2004 14:40:23.744
!MESSAGE Application error
!STACK 1
java.lang.VerifyError: class org.omg.PortableServer.AdapterActivatorPOA
overrides final method .
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:502)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.defineClass(DefaultClassLoader.java:298)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:216)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClassImpl(DefaultClassLoader.java:281)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClass(DefaultClassLoader.java:172)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:220)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:135)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:59)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315 )
at com.inprise.vbroker.orb.ORB.adapterManager(ORB.java:1450)
at com.inprise.vbroker.ds.DSUser.<init>(DSUser.java:299)
at com.inprise.vbroker.ds.Init.init(Init.java:20)
at com.inprise.vbroker.orb.ORB.initializeServices(ORB.java:1264 )
at com.inprise.vbroker.orb.ORB.initialize(ORB.java:1056)
at com.inprise.vbroker.orb.ORB.set_parameters(ORB.java:1282)
at org.omg.CORBA.ORB.init(ORB.java:337)
at com.nagra.ims.topo.corba.EcsPool.initORB(EcsPool.java:27)
at com.nagra.ims.topo.RcpApplication.run(RcpApplication.java:18 )
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:334)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:272)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:128)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
Re: Corba + Eclipse: VerifyError exception [message #257093 is a reply to message #256694] Wed, 30 June 2004 09:30 Go to previous message
I found out, it's just that Visibroker 5 only runs on JDK 1.3.1, so I
gotta upgrade to 5.2 to be able to use JDK 1.4.
Laurent
> Laurent
> Visibroker classes:
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Cannot export Plugins in 3.0
Next Topic:editorinput questions
Current Time: Mon Sep 01 00:03:18 EDT 2025
Powered by FUDForum. Page generated in 0.03895 seconds
