Home » Eclipse Projects » Eclipse Platform » Problem finding plugin location.
Problem finding plugin location. [message #256439] Mon, 28 June 2004 14:14 Go to next message
Originally posted by: dave_gray.versata.com
I am building a plugin that will handle some background utilities. The
plugin will have a directory of property files outside of the plugin jar.
I need to be able to query the plugin to find the path to these files.
I have tried through the plugin's bundle:
Platform.getBundle("my.bundle.symbolicName").getLocation()
I have tried with deprecated methods:
((PluginDescriptor)MyPlugin.getDefault()
.getDescriptor()).getInstallURL()
Both produce NPEs. My impression was that these calls should load the
plugin if not already loaded.
Can anyone help?
Dave
Re: Problem finding plugin location. [message #256473 is a reply to message #256439] Mon, 28 June 2004 16:05 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Try Platform.getBundle("my.bundle.symbolicName").getEntry() and friends.
You can use "/" or "" to get the root location of the bundle. Note that
there are no guarantees as to the form of the returned URL. Bundles can be
in jars, in the file system, on http servers, ...
Jeff
"Dave Gray" <dave_gray@versata.com> wrote in message
news:cbpn5r$a2v$1@eclipse.org...
> Can anyone help?
> Dave
Re: Problem finding plugin location. [message #256642 is a reply to message #256473] Tue, 29 June 2004 08:53 Go to previous messageGo to next message
Originally posted by: dave_gray.xxxx.versata.com
Platform.getBundle("my.bundle.symbolicName") calls
InternalPlatform.getDefault().getBundle(symbolicName) which calls
packageAdmin.getBundles(symbolicName, null) where packageAdmin is a field
of InternalPlatform.
Problem is that packageAdmin is null. The InternalPlatform singleton
instance is not null but most of its fields are. Seems like the plugin has
not yet been initialized. Is my call to a class in the plugin jar not
causing the plugin to be intialized and loaded? How can I ensure that it
is?
Dave
> Jeff
> > Can anyone help?
> > Dave
Re: Problem finding plugin location. [message #256676 is a reply to message #256642] Tue, 29 June 2004 10:15 Go to previous messageGo to next message
There must be something strange about how your system is starting up. If
PlatformAdmin is not available then the system pretty much will not run. Is
there anything in your log? Are you doing this code very early (i.e., where
is your code running?)
Jeff
"Dave" <dave_gray@xxxx.versata.com> wrote in message
news:cbroo7$f2d$1@eclipse.org...
> is?
> Dave
be
> > Jeff
jar.
> > > Can anyone help?
> > > Dave
Re: Problem finding plugin location. [message #256726 is a reply to message #256676] Tue, 29 June 2004 12:34 Go to previous messageGo to next message
Originally posted by: dave_gray.xxxxx.versata.com
After playing around a bit I think my problem is understanding how actions
in a non-UI related plugin are triggered. If I put code in a simple plugin
that has a visual component - view, button, or menu itme, and then have
that (show view, or click item) trigger the action, I can find the info
from the resource bundle or plugin that I want.
If instead have a plugin with no UI component, how do I trigger actions? I
have been trying to just call methods in classes in the plugin jar. I
assumed from what I had read that this would load my "utility" plugin and
make the information available. This does not work and I am not sure what
else I need to do.
Jeff, to answer your question more exactly: I have installed my plugin in
the ../plugins directory and see it in the list in the "about" box. I am
then just calling methods from a java class that I code and run in Eclipse.
Dave
> Jeff
> > is?
> > Dave
> be
> > > Jeff
> jar.
> > > > Can anyone help?
> > > > Dave
Re: Problem finding plugin location. [message #256933 is a reply to message #256726] Tue, 29 June 2004 21:48 Go to previous message
It seems like this is a separate issue. The initial post was related to the
InternalPlatform object is not initialized correctly. If this were true then
really very little in Eclipse would work. Do you have any more information
on that? What happens if you put a breakpoint in
InternalPlatform.getPlatformAdmin()? Is the ServiceReference really coming
back null? If so, put a breakpoint in EclipseAdaptor.frameworkStart() where
the PlatformAdmin service is registered and confirm that it is getting
registered.
Jeff
"Dave" <dave_gray@xxxxx.versata.com> wrote in message
news:cbs5mu$ium$1@eclipse.org...
> else I need to do.
Eclipse.
> Dave
If
Is
where
> > Jeff
field
has
it
> > > is?
> > > Dave
friends.
that
can
> > be
> > > > Jeff
The
plugin
> > jar.
files.
the
> > > > > Can anyone help?
> > > > > Dave
Previous Topic:Seeing more...
Next Topic:Eclipse not recognized by Mac OS X Finder when run from command line
Current Time: Mon Jul 21 20:09:07 EDT 2025
Powered by FUDForum. Page generated in 0.04553 seconds
