Encoding problem with JIRA Connector [message #25266] |
Tue, 04 September 2007 10:08  |
I've just installed Mylyn 2.0.0 (with JIRA Connector) for my Eclipse
3.3.0. I've added our JIRA Repository using ISO-8859-1 as encoding.
Everything works as expected when querying and viewing the JIRA Tasks.
But when I update a task which contains non-ascii characters, those
characters are converted to garbage characters (e.g. ü -> ü), as if the
text was converted to utf-8 before committing the changes.
What could be the problem? I thought that if a repository task is read
with the correct encoding, the write operation should use the same encoding.
best regards,
Mads
Re: Encoding problem with JIRA Connector [message #26521 is a reply to message #26311] |
Fri, 07 September 2007 02:34  |
Mik Kersten wrote:
> Window -> Preferences -> Mylyn -> Task List -> Task Editing
> Mads wrote:
>> How can I make Mylyn use the Web-Browser as default Task editor
>> (double-click)?
I must be complete blind. How did I miss that one? Thanks ;-)!
Re: Encoding problem with JIRA Connector [message #579526 is a reply to message #25266] |
Tue, 04 September 2007 13:03  |
> the text was converted to utf-8 before committing the changes.
> encoding.
Can you please create an issue in the Mylyn's bugzilla and specify
what kind of update you are doing, info about your local platform
encoding (you can attach configuration from Help / About Eclipse SDK /
Configuration Details), as well as platform encoding and encoding and
language setting on your JIRA server.
Eugene
Re: Encoding problem with JIRA Connector [message #580205 is a reply to message #26311] |
>> (double-click)?
FUDForum. Page generated in 0.11287 seconds
