Home » Archived » BIRT » Fixed pie chart size with outside series labels
Fixed pie chart size with outside series labels [message #255863] Thu, 20 September 2007 05:09 Go to next message
Originally posted by: frederic.anyware-tech.com
I'm currently designing a report with 4 pie charts inside (I'm using 2D
with depth, BIRT 2.2.0). I'd like the 4 pie charts to have exactly the
same size, with series labels outside the plot.
However, even when using the same width and height hints, I can't
achieve this. Depending on series data, the chart engine adapts the plot
size, and as a result, the 4 pie charts can look very different.
With inside series labels, it's working fine.
Is it possible to ask the chart rendering engine to use fixed plot size?
Fred
Re: Fixed pie chart size with outside series labels [message #256219 is a reply to message #255863] Wed, 26 September 2007 07:41 Go to previous messageGo to next message
The problem is that the labels position and length will affect the size of
the chart, so the solution is either to put the labels inside the chart or
use tooltips instead. You can file an enhancement to get more control on the
chart size independently of labels, but in that case, it's likely that
labels will get truncated if they don't have enough space.
David
"Fr
Re: Fixed pie chart size with outside series labels [message #256264 is a reply to message #256219] Wed, 26 September 2007 09:28 Go to previous message
AFAIU, tooltips are not an option for me here, since they only show up
one by one (in terms of slice) with user interactivity (mouse click,
mouse over, ...) and then are not printable all together.
yes, indeed. Truncated, or with carriage returns added to display labels
on several lines.
(I filed bug #204677)
Fred
> David
> "Frédéric Bertin" <frederic@anyware-tech.com> wrote in message
> news:fctdch$kf4$1@build.eclipse.org...
>> However, even when using the same width and height hints, I can't achieve
>> this. Depending on series data, the chart engine adapts the plot size, and
>> Thanks,
>> Fred
Previous Topic:Pie chart: minimum slice using Top N
Next Topic:Viewer 'Printer on server' dialog Printers list is empty.
Current Time: Sun Aug 31 21:46:39 EDT 2025
Powered by FUDForum. Page generated in 0.03312 seconds
