Home » Language IDEs » Java Development Tools (JDT) » Support for Java 7 (Dolphin) in Galileo?
Support for Java 7 (Dolphin) in Galileo? [message #255814] Thu, 21 August 2008 13:54 Go to next message
Originally posted by: Barry.BurdBrain.com
--____HTZKYVGPWWBZUSKZCVCU____
Content-Type: text/plain; charset=utf-8
Content-Disposition: inline; modification-date="Fri, 21 Aug 2008 09:54:33
-0400"
SSdtIHVwZGF0aW5nIGEgSmF2YSBib29rIGFuZCBJIHdhbnQgdG8gdXNlIEVj bGlwc2UgYXMgdGhl
IGJvb2sncyBwcmltYXJ5IElERS4gVGhlIHByb2JsZW0gaXMsIHRoZSB1cGRh dGUgaXMgZm9yIEph
dmEgNyAoRG9scGhpbikuIFdoZW4gaXMgRWNsaXBzZSBleHBlY3RlZCB0byBz dXBwb3J0IEphdmEg
Nz8NClRoYW5rcy4=
Content-Type: multipart/related; boundary="____YNTXGMBKOMXWSNELAROW____"
--____YNTXGMBKOMXWSNELAROW____
Content-Type: text/html; charset=utf-8
-0400"
PEhUTUw+PEhFQUQ+DQo8TUVUQSBjb250ZW50PSJ0ZXh0L2h0bWw7IGNoYXJz ZXQ9dXRmLTgiIGh0
dHAtZXF1aXY9Q29udGVudC1UeXBlPg0KPE1FVEEgbmFtZT1HRU5FUkFUT1Ig Y29udGVudD0iTVNI
VE1MIDYuMDAuNjAwMS4xNzUxMSI+PC9IRUFEPg0KPEJPRFkgc3R5bGU9Ik1B UkdJTjogNHB4IDRw
eCAxcHg7IEZPTlQ6IDEwcHQgVGFob21hIj4NCjxESVY+SSdtIHVwZGF0aW5n IGEgSmF2YSBib29r
IGFuZCBJIHdhbnQgdG8gdXNlIEVjbGlwc2UgYXMgdGhlIGJvb2sncyBwcmlt YXJ5IElERS4gVGhl
IHByb2JsZW0gaXMsIHRoZSB1cGRhdGUgaXMgZm9yIEphdmEgNyAoRG9scGhp bikuIFdoZW4gaXMg
RWNsaXBzZSBleHBlY3RlZCB0byBzdXBwb3J0IEphdmEgNz88L0RJVj4NCjxE SVY+VGhhbmtzLjwv
RElWPjwvQk9EWT48L0hUTUw+
--____YNTXGMBKOMXWSNELAROW____--
--____HTZKYVGPWWBZUSKZCVCU____--
Re: Support for Java 7 (Dolphin) in Galileo? [message #255930 is a reply to message #255814] Wed, 27 August 2008 11:15 Go to previous message
"Barry Burd" <Barry@BurdBrain.com> wrote in message
news:48AD7399.618A.0054.0@BurdBrain.com...
> When is Eclipse expected to support Java 7?
"Support" is a broad term... you might be asking about when Eclipse will be
able to run on Java 7, or when the Eclipse Java tooling (JDT) is able to
compile code with Java 7 language features, or when Eclipse itself will use
Java 7 language features, or when Eclipse will be able to pass the Java 7
compliance tests, et cetera.
Rather than assume what you mean, I'd suggest that the broad answer is
"probably in the first release after Java 7 becomes available from Sun,
whenever that might be", and the specific answers are to be found in the
plans of the respective groups. These plan documents are just now starting
to get posted, for the Eclipse 3.5 dev cycle; for instance,
http://www.eclipse.org/jdt/core/r3.5/index.php (but this one is still
incomplete) or http://www.eclipse.org/eclipse/platform-text/3.5/plan.php
(looks pretty solid).
Previous Topic:EnumDeclaration not recognized as AbstractTypeDeclaration
Next Topic:Re: Java Search Suggestion
Current Time: Tue Jul 22 12:09:38 EDT 2025
Powered by FUDForum. Page generated in 0.03476 seconds
