Home » Eclipse Projects » Mylyn » Eclipse timeline plugin
Eclipse timeline plugin [message #25224] |
Tue, 04 September 2007 02:26  |
Originally posted by: chen4613.gmail.com
Good morning/afternoon/evening,
Please forgive me if I post the wrong place, but i definitely think it will
help to mylyn users.
I recently start a eclipse plugin project which use Timeline view (from
http://simile.mit.edu/timeline/) to show events in eclipse, and it integrate
with Mylyn to show Mylyn tasks modification in the scrolling timeline view.
The project is http://code.google.com/p/eclipsetimeline/, though it is in
beta state, I hope someone can take a try and provide precious feedback for
me.
Thanks.
Re: Eclipse timeline plugin [message #27200 is a reply to message #26923] |
Mon, 10 September 2007 05:53   |
It may caused by your port 80 is in used. Eclipse Timeline depends on
HttpService, and the OSGi HttpService's default port is 80, if it is in
used, the HTTPService will start fail, hence, can't start the timeline view.
You can try to start eclipse with
argument -Dorg.osgi.service.http.port=other port.
"Kim Sullivan" <alicebot@seznam.cz> wrote in message
news:fbs4pj$p0f$1@build.eclipse.org...
>> for
>> me.
> I wanted to try it, but couldn't get it to run. After I restarted Eclipse
> and opened the Timeline view, I got the following error:
> "HttpService not started. Please check the OSGi HTTP service
> configuration, make sure the port is not in used."
> Kim
Re: OSGi (was Re: Eclipse timeline plugin) [message #28104 is a reply to message #27274] |
Wed, 12 September 2007 23:15   |
I am not a OSGi guru, and i think i am not master OSGi in deep, so i can't
answer you what the OSGi really is.
I think do more google search, visist wikipedia may help you some, or you
can post question in eclipse.technology.equinox group or other OSGi mailling
list.
Also, i think do some research on eclipse architecture is a plus to help you
understand OSGi.
"Jay Levitt" <jay+news@jay.fm> wrote in message
news:dn8eegj6y9em.dlg@jay.fm...
>> view.
> Since you sound like you know what you're talking about - could you tell
> me
> what the heck OSGi is? I went to their web site last week, and all I
> could
> figure out is that it's a thing to enable things in the something space.
> Jay
Re: Eclipse timeline plugin [message #28143 is a reply to message #27826] |
Wed, 12 September 2007 23:24   |
Do you install the org.eclipse.equinox.http?
I recommend you to install it use the update site
http://eclipsetimeline.googlecode.com/svn/updates, it can resolved the
dependcy issue.
If it still can't work, plz post your eclipse configuration details.
news:fc6hfd$fr7$1@build.eclipse.org...
>> view.
> Doesn't help, I still get the same error (I checked the eclipse log, there
> are no errors in there). I never used the osgi http service, is there
> anything else I have to do to configure it?
> Kim
Re: Eclipse timeline plugin [message #28233 is a reply to message #28143] |
Thu, 13 September 2007 04:24   |
> dependcy issue.
Yes, I originally installed it using the update site, and some
dependency got resolved (I think Eclipse Project Equinox bundle
feature). Here are my configuration details (the only unusual thing
would be using the mylyn dev builds instead of the release or the
milestone... the activity.xml file has changed since the Europa release).
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=I20070323-1616
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
D:\Progs\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
D:\Progs\eclipse\plugins\org.eclipse.equinox.launcher.win32. win32.x86_1.0.0.v20070523\eclipse_1017a.dll
-startup
D:\Progs\eclipse\plugins\org.eclipse.equinox.launcher_1.0.0. v20070606.jar
-Dorg.osgi.service.http.port=2001
-vm
C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1189671460687
eclipse.vm=C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.vmargs=-Xmx256M
-XX:MaxPermSize=256m
-Djava.class.path=D:\Progs\eclipse\plugins\org.eclipse.equin ox.launcher_1.0.0.v20070606.jar
eof=eof
file.encoding=Cp1250
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=D:\Progs\eclipse\plugins\org.eclipse.equinox .launcher_1.0.0.v20070606.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_02\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_02\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_02
java.io.tmpdir=C:\DOCUME~1\User\LOCALS~1\Temp\
java.library.path=D:\Progs\eclipse;.;C:\WINDOWS\Sun\Java\bin ;C:\WINDOWS\system32;C:\WINDOWS;C:\Program
Files\Java\jre1.6.0_02\bin\client;C:\Program
Files\Java\jre1.6.0_02\bin;E:\cygwin\bin\;D:\Progs\MinGW\bin ;D:\Progs\Python24\.;D:\Program
Files\Borland\BDS\3.0\Bin;C:\WINDOWS\system32;C:\WINDOWS;C:\ WINDOWS\System32\Wbem;D:\Program
Files\Common
Files\GTK\2.0\bin;D:\progs\PHP\;d:\progs\svn\bin\;"C:\Progra~1\Java\jdk1.6.0 "\bin;d:\Progs\ant\bin;D:\Program
Files\WinSCP\;D:\Progs\svk-2.0.0-1\bin;D:\My Documents\Borland Studio
Projects\Bpl;D:\Modeltech_xe_starter\win32xoem;D:\Program Files\MKVtoolnix
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_02-b06
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_02
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0_02-b06
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.handle=32375712
org.eclipse.equinox.launcher.splash.location=d:\Progs\eclips e\plugins\org.eclipse.platform_3.3.0.v20070613\splash.bmp
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=cs
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.
kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.security.auth.x500,javax.security.cert,javax.security.s asl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sample d,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.s ql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swin g.border,javax.swing.colorchooser,javax.swing.event,javax.sw ing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,java x.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.s ynth,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.tools,javax.transaction,java x.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.ann otation,javax.xml.bind.annotation.adapters,javax.xml.bind.at tachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xm l.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xm l.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cr ypto.dsig.spec,javax.xml.datat
ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stream,javax.xml.stream.events,javax.xml.stream.util, javax.xml.transform,javax.xml.transform.dom,javax.xml.transf orm.sax,javax.xml.transform.stax,javax.xml.transform.stream, javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax .xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,jav ax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,or g.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.Dyn AnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,o rg.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingContextExtPackage,org.omg.CosNaming.NamingContext Package,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAn y.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org. omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPac kage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.P ortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer ,org.omg.PortableServer.Curren
tPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Po rtableServer.POAPackage,org.omg.PortableServer.portable,org. omg.PortableServer.ServantLocatorPackage,org.omg.SendingCont ext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap, org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ex t,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=D:\Progs\eclipse\configuration\org.eclipse. osgi\bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/D:/Progs/eclipse/configuration /
osgi.framework=file:/d:/Progs/eclipse/plugins/org.eclipse.os gi_3.3.0.v20070530.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.0.v20070530
osgi.install.area=file:/D:/Progs/eclipse/
osgi.instance.area=file:/D:/.projects/ibm/eclipse-workspace/
osgi.instance.area.default=file:/D:/.windows/workspace/
osgi.logfile=D:\.projects\ibm\eclipse-workspace\.metadata\.l og
osgi.manifest.cache=D:\Progs\eclipse\configuration\org.eclip se.osgi\manifests
osgi.nl=cs_CZ
osgi.os=win32
osgi.splashLocation=d:\Progs\eclipse\plugins\org.eclipse.pla tform_3.3.0.v20070613\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=d:\Progs\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.6.0_02\lib\resources.jar;C:\Program
Files\Java\jre1.6.0_02\lib\rt.jar;C:\Program
Files\Java\jre1.6.0_02\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.6.0_02\lib\jsse.jar;C:\Program
Files\Java\jre1.6.0_02\lib\jce.jar;C:\Program
Files\Java\jre1.6.0_02\lib\charsets.jar;C:\Program
Files\Java\jre1.6.0_02\classes
sun.boot.library.path=C:\Program Files\Java\jre1.6.0_02\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1250
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=CZ
user.dir=D:\Progs\eclipse
user.home=D:\.windows
user.language=cs
user.name=User
user.timezone=Europe/Prague
user.variant=
*** Features:
org.eclipse.cvs (1.0.0.v20070606-7C79_79EI99g_Y9e) "Eclipse CVS Client"
org.eclipse.cvs.source (1.0.0.v20070606-7C79_79EI99g_Y9e) "Eclipse CVS
Client SDK"
org.eclipse.emf (2.3.0.v200706262000) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.0.v200706262000) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.0.v200706262000) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200706262000) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.0.v200706262000) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.3.0.v200706262000) "EMF Common"
org.eclipse.emf.common.ui (2.3.0.v200706262000) "EMF Common UI"
org.eclipse.emf.converter (2.3.0.v200706262000) "EMF Model Convert Support"
org.eclipse.emf.doc (2.3.0.v200706262000) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore (2.3.0.v200706262000) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200706262000) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.0.v200706262000) "Sample Ecore Editor"
org.eclipse.emf.edit (2.3.0.v200706262000) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.0.v200706262000) "EMF Edit UI"
org.eclipse.emf.mapping (2.3.0.v200706262000) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.0.v200706262000) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200706262000) "Eclipse
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.0.v200706262000) "EMF Mapping UI"
org.eclipse.emf.ocl (1.1.0.v200706071450-10-7w311817312619) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.query (1.0.1.v200703301543) "Eclipse Modeling Framework
Technology Query Framework"
org.eclipse.emf.query.ocl (1.1.0.v200703301543) "Eclipse Modeling
Framework Technology Query OCL"
org.eclipse.emf.source (2.3.0.v200706262000) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.emf.transaction (1.1.0.v200703301538) "Eclipse Modeling
Framework Technology Transaction Core"
org.eclipse.emf.validation (1.1.0.v200703301524) "Eclipse Modeling
Framework Technology Model Validation Core"
org.eclipse.emf.validation.ocl (1.1.0.v200703301524) "Eclipse Modeling
Framework Technology Validation Support for OCL"
org.eclipse.emf.workspace (1.1.0.v200703301538) "Eclipse Modeling
Framework Technology Workbench Core"
org.eclipse.gef (3.3.0.v20070620) "Graphical Editing Framework"
org.eclipse.gmf (1.0.100.v20070601-1400-7d-ETeEYjiMWQX3az0fBWRjypkm7)
"Graphical Modeling Framework"
org.eclipse.jdt (3.3.0.v20070606-0010-7o7jCHEFpPoqQYvnXqejeR) "Eclipse
Java Development Tools"
org.eclipse.jdt.source (3.3.0.v20070606-0010-7o7jCHEFpPoqQYvnXqejeR)
"Eclipse Java Development Tools SDK"
org.eclipse.jet (0.8.0.v200704041505) "Eclipse Modeling Framework
Technologies - JET"
org.eclipse.jet.doc (0.8.0.v200704041505) "Eclipse Modeling Framework
Technologies - JET Documentation"
org.eclipse.jet.examples (0.8.0.v200704041505) "Eclipse Modeling
Framework Technologies - JET Examples"
org.eclipse.jet.source (0.8.0.v200704041505) "Eclipse Modeling Framework
Technologies - JET SDK"
org.eclipse.mylyn_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.context_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.ide_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.java_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.pde_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.sandbox.ui_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.trac_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.ocl (1.1.0.v200706071450-32-9oA55P5M8C8KCK) "Object
Constraint Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.uml (1.1.0.v200706071450-10-7w311817182561) "OCL 2.0
Binding for UML"
org.eclipse.pde (3.3.0.v20070607-7N7M-DUUEF6Ez0H46IcCC) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.3.0.v20070607-7N7M-DUUEF6Ez0H46IcCC) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G) "Eclipse
Platform"
org.eclipse.platform.source (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse RCP"
org.eclipse.rcp.source (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG)
"Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.3.0.v20070607-7M7J-BIolz-OcxWxvWAPSfLPqevO) "Eclipse
Project SDK"
org.eclipse.uml2 (2.1.0.v200706251652) "UML2"
org.eclipse.wst (2.0.0.v200706041905-7C-18k0IWJZ93WDDJlQ60nUjTdJp) "Web
Standard Tools (WST)"
org.eclipse.wst.common_core.feature.source
(2.0.0.v200706041905-7C78EK9E_EkMNfNOd2d8qq) "Web Standard Tools -
Common Core Source"
org.eclipse.wst.common_ui.feature.source
(2.0.0.v200706041905-7C5EGzE9RvTVniSrwnf4TgOPe3e9) "Web Standard Tools -
Common UI Source"
org.eclipse.wst.sdk (2.0.0.v200706041905-7E-18aNKbx2jys2HTkz0_f_9fLWx)
"Web Standard Tools (WST)"
org.eclipse.wst.server_core.feature.source
(2.0.0.v200706041905-2-CL8s733G3E4B2862) "Web Standard Tools - Server
Core Source"
org.eclipse.wst.server_ui.feature.source
(2.0.0.v200706041905-77-CQ9vCXBjvZGTVARHF8DBA) "Web Standard Tools -
Server UI Source"
org.eclipse.wst.web_core.feature.source
(2.0.0.v200706041905-42CI_kE77Y7TAMAVHH) "Web Standard Tools - Web Core
Source"
org.eclipse.wst.web_ui.feature.source
(2.0.0.v200706041905-7A0EAeCiWfEJsCcbAj88SKfRX) "Web Standard Tools -
Web UI Source"
org.eclipse.wst.ws_core.feature.source
(2.0.0.v200706210215-7E7KE_QEC3wSU4TpiAiQ0r) "Web Standard Tools - Web
Service Core Source"
org.eclipse.wst.ws_ui.feature.source
(2.0.0.v200706041905-791ECBAufYO8_EaomWE4Fe3uXjR1) "Web Standard Tools -
Web Service UI Source"
org.eclipse.wst.xml_core.feature.source
(2.0.0.v200706041905-787BE9zCYQCCz-CnUGLYQV) "Web Standard Tools - XML
Core Source"
org.eclipse.wst.xml_ui.feature.source
(2.0.0.v200706182145-7A1ECBCnbckz0bZu9wHqAKN3mYpZ) "Web Standard Tools -
XML UI Source"
org.eclipse.xsd (2.3.0.v200706262000) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200706262000) "XML Schema Edit Framework"
org.tigris.subversion.subclipse (1.2.3) "SVN Team Provider Core"
*** Plug-in Registry:
com.ibm.icu (3.6.1.v20070417) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.6.1.v20070417) "International Components for
Unicode for Java (ICU4J) source plug-in" [Resolved]
com.ibm.icu36.data.update (3.6.1.v20070701_2007f) "ICU4J Data Update
Fragment" [Resolved]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
eclipse.timeline (1.0.0.200709051757) "Timeline Plug-in" [Starting]
eclipse.timeline.mylyn (1.0.0.200709051757) "Mylyn Tasks Event Source
Plug-in" [Starting]
eclipse.timeline.xml (1.0.0.200709051757) "Xml Event Source Plug-in"
[Starting]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
javax.servlet.jsp.source (2.0.0.v200706191603) "Java Server Pages API
Source Bundle" [Resolved]
javax.servlet.source (2.4.0.v200706111738) "Servlet API Source Bundle"
[Resolved]
javax.wsdl (1.4.0.v200706111329) "WSDL4J" [Resolved]
javax.wsdl15 (1.5.1.v200705290614) "WSDL4J" [Resolved]
javax.xml.rpc (1.1.0.v200706111329) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200706111329) "SAAJ" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge
LPG" [Resolved]
net.sourceforge.lpg.lpgjavaruntime.source (1.1.0.v200706111738)
"SourceForge LPG Source Bundle" [Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200706080842) "Apache Ant Source" [Resolved]
org.apache.axis (1.4.0.v200706191647) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser"
[Resolved]
org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
org.apache.commons.discovery (0.2.0.v200706111329) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP
2.0 Expression Language Interpreter Source" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v200706111724) "Apache Commons
Logging Plug-in Source" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.jasper.source (5.5.17.v200706111724) "Apache Jasper 2 Source
Plug-in" [Resolved]
org.apache.log4j (1.2.13.v200706111418) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene
Analysis" [Resolved]
org.apache.lucene.analysis.source (1.9.1.v200706181610) "Apache Lucene
Analysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v200706111724) "Apache Lucene Source"
[Resolved]
org.apache.wsil4j (1.0.0.v200706111329) "WSIL4J" [Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"
[Resolved]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.2.100.v20070511) "Ant UI" [Active]
org.eclipse.compare (3.3.0.I20070606) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.0.0.I20070606-0010) "JFace Data Binding"
[Resolved]
org.eclipse.core.databinding.beans (1.0.0.I20070606-0010) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.3.0.v20070606-0010) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.3.0.v20070423) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.0.0.I20070531) "Internet Connection Management"
[Active]
org.eclipse.core.resources (3.3.0.v20070604) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Starting]
org.eclipse.cvs (1.0.0.v20070606) "Eclipse CVS Client" [Starting]
Client SDK" [Resolved]
org.eclipse.debug.core (3.3.0.v20070607-1800) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.0.v20070607-1800) "Debug UI" [Active]
org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework
Draw2d" [Starting]
[Starting]
org.eclipse.emf.ant (2.3.0.v200706262000) "EMF Ant Tasks" [Starting]
Generator" [Starting]
Generation" [Starting]
Generation UI" [Starting]
Generator UI" [Starting]
org.eclipse.emf.common (2.3.0.v200706262000) "EMF Common" [Starting]
org.eclipse.emf.common.ui (2.3.0.v200706262000) "EMF Common UI" [Starting]
Support" [Starting]
(EMF) Programmers Guide" [Starting]
org.eclipse.emf.ecore (2.3.0.v200706262000) "EMF Ecore" [Starting]
Support" [Starting]
[Starting]
org.eclipse.emf.ecore.change (2.3.0.v200706262000) "EMF Ecore Change
Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.3.0.v200706262000) "EMF Ecore
Change Edit Support" [Starting]
org.eclipse.emf.ecore.xmi (2.3.0.v200706262000) "EMF XMI" [Starting]
org.eclipse.emf.edit (2.3.0.v200706262000) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.3.0.v200706262000) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.3.0.v200706262000) "EMF Model Export
Support" [Starting]
org.eclipse.emf.cheatsheets (2.3.0.v200706262000) "EMF Cheat Sheets"
[Starting]
org.eclipse.emf.importer (2.3.0.v200706262000) "EMF Model Import
Support" [Starting]
org.eclipse.emf.importer.ecore (2.3.0.v200706262000) "EMF Ecore
Importer" [Starting]
org.eclipse.emf.importer.java (2.3.0.v200706262000) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.3.0.v200706262000) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.3.0.v200706262000) "EMF Mapping" [Starting]
Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200706262000) "Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200706262000) "Ecore
to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.3.0.v200706262000) "Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200706262000) "Ecore to XML
Mapping UI" [Starting]
org.eclipse.emf.mapping.ui (2.3.0.v200706262000) "EMF Mapping UI" [Starting]
org.eclipse.emf.ocl (1.1.0.v200706201508) "Object Constraint Language
(OCL) 2.0 Compatibility API" [Starting]
Technology Query Framework" [Starting]
Framework Technology Query OCL" [Starting]
(EMF) Source" [Resolved]
Framework Technology Transaction Core" [Starting]
org.eclipse.emf.transaction.ui (1.0.1.v200703301538) "Eclipse Modeling
Framework Technology Transaction UI" [Starting]
Framework Technology Model Validation Core" [Starting]
Framework Technology Validation Support for OCL" [Resolved]
org.eclipse.emf.validation.ui (1.1.0.v200703301524) "Eclipse Modeling
Framework Technology Validation UI" [Starting]
org.eclipse.emf.validation.ui.ide (1.0.1.v200703301524) "Eclipse
Modeling Framework Technology Validation UI IDE" [Starting]
Framework Technology Workbench Core" [Starting]
org.eclipse.emf.workspace.ui (1.0.100.v200703301538) "Eclipse Modeling
Framework Technology Workbench UI" [Starting]
org.eclipse.equinox.app (1.0.0.v20070606) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.device (1.0.0.v20070226) "Device Access Service"
[Resolved]
org.eclipse.equinox.event (1.0.100.v20070516) "Event Admin" [Resolved]
org.eclipse.equinox.http (1.0.100.v20070423) "HTTP Service" [Resolved]
org.eclipse.equinox.http.jetty (1.0.0.v20070607) "Jetty Http Service"
[Starting]
org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service
Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.0.v20070606) "Http Services
Servlet" [Starting]
org.eclipse.equinox.http.servletbridge (1.0.0.v20070523) "Servletbridge
Http Service" [Resolved]
org.eclipse.equinox.jsp.jasper (1.0.0.v20070607) "Jasper Jsp Support
Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.0.v20070606) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.0.v20070523) "Equinox
Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.log (1.0.100.v20070226) "Log Service" [Resolved]
org.eclipse.equinox.metatype (1.0.0.v20070226) "Meta Type" [Resolved]
org.eclipse.equinox.preferences (3.2.100.v20070522) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.3.0.v20070522) "Extension Registry
Support" [Active]
org.eclipse.equinox.servletbridge (1.0.0.v20070523) "bundleName" [Resolved]
org.eclipse.equinox.useradmin (1.0.0.v20070226) "User Admin Service"
[Resolved]
org.eclipse.gef (3.2.100.v20070620) "Graphical Editing Framework" [Starting]
org.eclipse.gmf (1.0.0.v20070601-1400) "Graphical Modeling Framework"
[Starting]
org.eclipse.gmf.bridge (1.1.0.v20070621-0000) "GMF Models Bridging
Plug-in" [Starting]
org.eclipse.gmf.bridge.ui (1.1.0.v20070621-0000) "GMF Tooling UI" [Starting]
org.eclipse.gmf.bridge.ui.dashboard (2.0.0.v20070621-0000) "GMF
Dashboard" [Starting]
org.eclipse.gmf.codegen (2.0.0.v20070621-0000) "GMF GenModel and Code
org.eclipse.gmf.codegen.edit (2.0.0.v20070614-1400) "GMF GenModel Edit
Support" [Starting]
org.eclipse.gmf.codegen.ui (1.1.0.v20070621-0000) "GMF Code Generation
UI" [Starting]
org.eclipse.gmf.common (1.1.0.v20070621-0000) "GMF Tooling Commons
Plug-in" [Starting]
org.eclipse.gmf.doc.ui (1.1.0.v20070601-1400) "GMF Documentation
Cheatsheets" [Starting]
org.eclipse.gmf.ecore.editor (2.0.0.v20070621-0000) "ECore Sample
Diagram Plugin" [Starting]
org.eclipse.gmf.graphdef (2.0.0.v20070621-0000) "GMF Graphical
Definition" [Resolved]
org.eclipse.gmf.graphdef.codegen (2.0.0.v20070621-0000) "Graphical
Definition Code Generator" [Starting]
org.eclipse.gmf.graphdef.codegen.ui (1.0.100.v20070621-0000) "Graphical
Definition Code Generator UI Support" [Resolved]
org.eclipse.gmf.graphdef.edit (2.0.0.v20070601-1400) "GMFGraph Edit
Support" [Starting]
org.eclipse.gmf.map (2.0.0.v20070621-0000) "GMF Mapping Model" [Starting]
org.eclipse.gmf.map.edit (2.0.0.v20070621-0000) "GMF Mapping Edit
Support" [Starting]
org.eclipse.gmf.runtime.common.core (1.0.100.v20070601-1400) "GMF Common
Core" [Starting]
org.eclipse.gmf.runtime.common.ui (1.0.100.v20070601-1400) "GMF Common
UI" [Starting]
org.eclipse.gmf.runtime.common.ui.action (1.0.100.v20070601-1400) "GMF
Common UI Action" [Starting]
org.eclipse.gmf.runtime.common.ui.action.ide (1.0.1.v20070601-1400) "GMF
Common UI Action IDE" [Starting]
org.eclipse.gmf.runtime.common.ui.printing (1.0.1.v20070601-1400) "GMF
Printing" [Starting]
org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.2.v20070601-1400)
"GMF Printing for Win32" [Resolved]
org.eclipse.gmf.runtime.common.ui.services (1.0.100.v20070601-1400) "GMF
Common UI Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.action
(1.0.100.v20070601-1400) "GMF Common UI Action Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.1.v20070601-1400)
"GMF Common UI DND Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.dnd.ide
(1.0.1.v20070601-1400) "GMF Common UI DND IDE Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.properties
(1.0.1.v20070601-1400) "GMF Common UI Properties Service Framework"
[Starting]
org.eclipse.gmf.runtime.diagram.core (1.0.100.v20070601-1400) "GMF
Diagram Core" [Starting]
org.eclipse.gmf.runtime.diagram.ui (1.0.100.v20070621-0000) "GMF Diagram
UI" [Starting]
org.eclipse.gmf.runtime.diagram.ui.actions (1.0.100.v20070621-0000) "GMF
Diagram Actions" [Starting]
org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.1.v20070601-1400) "GMF
Diagram Browse" [Starting]
org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.0.1.v20070601-1400) "GMF
Geometric Shapes" [Starting]
org.eclipse.gmf.runtime.diagram.ui.printing (1.0.100.v20070621-0000)
"GMF Diagram Printing" [Starting]
org.eclipse.gmf.runtime.diagram.ui.printing.render
(1.0.1.v20070601-1400) "GMF Diagram UI Printing Render Plug-In" [Starting]
org.eclipse.gmf.runtime.diagram.ui.properties (1.0.100.v20070608-1300)
"GMF Diagram UI Properties" [Starting]
org.eclipse.gmf.runtime.diagram.ui.providers (1.0.100.v20070621-0000)
"GMF Diagram Providers" [Starting]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.0.1.v20070601-1400)
"GMF Diagram Providers IDE" [Starting]
org.eclipse.gmf.runtime.diagram.ui.render (1.0.100.v20070621-0000) "GMF
Diagram UI Render Plug-In" [Starting]
org.eclipse.gmf.runtime.diagram.ui.resources.editor
(1.0.3.v20070601-1400) "GMF Diagram UI Resources Editor Plug-In" [Starting]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide
(1.0.3.v20070601-1400) "GMF IDE Editor" [Starting]
org.eclipse.gmf.runtime.draw2d.ui (1.0.100.v20070621-0000) "GMF Draw2d
Additions" [Starting]
org.eclipse.gmf.runtime.draw2d.ui.render (1.0.100.v20070614-1400) "GMF
Draw2d Image Rendering Additions" [Starting]
org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.0.100.v20070614-1400)
"GMF Draw2d Image AWT based Rendering Additions" [Starting]
org.eclipse.gmf.runtime.emf.clipboard.core (1.0.100.v20070621-0000) "GMF
EMF Clipboard Support" [Starting]
org.eclipse.gmf.runtime.emf.commands.core (1.0.3.v20070601-1400) "GMF
Commands" [Starting]
org.eclipse.gmf.runtime.emf.core (1.0.100.v20070601-1400) "GMF Modeling
Service Layer" [Starting]
org.eclipse.gmf.runtime.emf.type.core (1.0.100.v20070601-1400) "GMF EMF
Type Core" [Starting]
org.eclipse.gmf.runtime.emf.type.ui (1.0.1.v20070601-1400) "GMF EMF Type
UI" [Starting]
org.eclipse.gmf.runtime.emf.ui (1.0.100.v20070621-0000) "GMF MSL UI"
[Starting]
org.eclipse.gmf.runtime.emf.ui.properties (1.0.2.v20070601-1400) "GMF
EMF UI Properties Providers" [Starting]
org.eclipse.gmf.runtime.gef.ui (1.0.1.v20070601-1400) "GMF GEF
org.eclipse.gmf.runtime.notation (1.0.100.v20070621-0000) "GMF Notation
Model Support" [Starting]
org.eclipse.gmf.runtime.notation.edit (1.0.1.v20070621-0000) "GMF
Notation Edit Support" [Starting]
org.eclipse.gmf.runtime.notation.providers (1.0.1.v20070601-1400) "GMF
Notation Metamodel" [Starting]
org.eclipse.gmf.sdk (1.0.0.v20070601-1400) "Graphical Modeling Framework
SDK" [Starting]
org.eclipse.gmf.tooldef (2.0.0.v20070621-0000) "GMF Tooling Model"
[Starting]
org.eclipse.gmf.tooldef.edit (2.0.0.v20070601-1400) "GMF Tooling Edit
Support" [Starting]
org.eclipse.gmf.validate (1.1.0.v20070621-0000) "GMF Validation" [Starting]
org.eclipse.gmf.xpand (1.0.0.v20070608-1300) "GMF Xpand Template Engine"
[Starting]
org.eclipse.help (3.3.0.v20070524) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.0.v20070606) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.0.v20070530) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.0.v20070607) "Help System Webapp" [Starting]
org.eclipse.jdt (3.3.0.v20070607-1300) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.3.0.v20070607-1200) "Java Annotation
Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.0.v20070529-2100) "Java Compiler
Apt IDE" [Starting]
org.eclipse.jdt.apt.ui (3.3.0.v20070430-1135) "Java Annotation
Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.0.v20070510-2000) "Java Compiler Apt"
[Resolved]
org.eclipse.jdt.compiler.tool (1.0.0.v_771) "Java Compiler Tool Support"
[Resolved]
org.eclipse.jdt.core (3.3.0.v_771) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.3.0.v20070530a) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.100.v20070531-1800) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.3.0.v20070613) "Eclipse JDT Plug-in Developer
Guide" [Starting]
org.eclipse.jdt.doc.user (3.3.0.v20070608-1300) "Eclipse Java
Development User Guide" [Starting]
org.eclipse.jdt.junit (3.3.0.v20070606-0010) "Java Development Tools
JUnit support" [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java
Development Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.3.0.v20070510) "Java Development Tools
Launching Support" [Active]
"Eclipse Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.3.0.v20070607-0010) "Java Development Tools UI"
[Active]
org.eclipse.jem.util (2.0.0.v200705302225) "Java EMF Model Utilities"
[Starting]
Technologies - JET" [Starting]
org.eclipse.jet.core (1.0.0.v200704041505) "Eclipse Modeling Framework
Technologies - JET Core" [Starting]
Technologies - JET Documentation" [Starting]
Framework Technologies - JET Examples" [Starting]
Technologies - JET SDK" [Resolved]
org.eclipse.jet.ui (0.8.0.v200704041505) "JET Transformations UI
Plug-in" [Active]
org.eclipse.jface (3.3.0.I20070606-0010) "JFace" [Active]
org.eclipse.jface.databinding (1.1.0.I20070606-0010) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.3.0.v20070606-0010) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Active]
org.eclipse.jsch.ui (1.0.0.I20070525) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.3.0.v20070606-0010) "Refactoring
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.3.0.v20070606-0010) "Refactoring UI"
[Active]
org.eclipse.mylyn (2.0.0.v20070910-1300) "Mylyn" [Starting]
org.eclipse.mylyn.bugzilla.core (2.0.0.v20070910-1300) "Mylyn Bugzilla
Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (2.0.0.v20070910-1300) "Mylyn Bugzilla
Connector IDE" [Active]
org.eclipse.mylyn.bugzilla.ui (2.0.0.v20070910-1300) "Mylyn Bugzilla
Connector UI" [Active]
org.eclipse.mylyn.compatibility (2.0.0.v20070910-1300) "Java 5
Compatibility Checker" [Active]
org.eclipse.mylyn.context.core (2.0.0.v20070910-1300) "Mylyn Context
Core" [Active]
org.eclipse.mylyn.context.ui (2.0.0.v20070910-1300) "Mylyn Context UI"
[Active]
org.eclipse.mylyn.help.ui (2.0.0.v20070910-1300) "Mylyn Help" [Starting]
org.eclipse.mylyn.ide.ant (2.0.0.v20070910-1300) "Mylyn Ant UI Plug-in"
[Active]
org.eclipse.mylyn.ide.ui (2.0.0.v20070910-1300) "Mylyn IDE UI" [Active]
org.eclipse.mylyn.java.ui (2.0.0.v20070910-1300) "Mylyn Java" [Active]
org.eclipse.mylyn.monitor.core (2.0.0.v20070910-1300) "Mylyn Monitor
Core" [Resolved]
org.eclipse.mylyn.monitor.ui (2.0.0.v20070910-1300) "Mylyn Monitor UI"
[Active]
org.eclipse.mylyn.pde.ui (2.0.0.v20070910-1300) "Mylyn PDE UI Plug-in"
[Active]
org.eclipse.mylyn.resources.ui (2.0.0.v20070910-1300) "Mylyn Resources
UI" [Active]
org.eclipse.mylyn.sandbox.ui (2.0.0.v20070910-1300) "Mylyn Sandbox
Experimental UI" [Active]
org.eclipse.mylyn.tasks.core (2.0.0.v20070910-1300) "Mylyn Tasks Core"
[Active]
org.eclipse.mylyn.tasks.ui (2.0.0.v20070910-1300) "Mylyn Tasks UI" [Active]
org.eclipse.mylyn.team.cvs (2.0.0.v20070910-1300) "Mylyn Team CVS
Plug-in" [Resolved]
org.eclipse.mylyn.team.ui (2.0.0.v20070910-1300) "Mylyn Team UI" [Active]
org.eclipse.mylyn.trac.core (2.0.0.v20070910-1300) "Mylyn Trac Connector
Core" [Active]
org.eclipse.mylyn.trac.ui (2.0.0.v20070910-1300) "Mylyn Trac Connector
UI" [Active]
org.eclipse.mylyn.web.core (2.0.0.v20070910-1300) "Mylyn Web Core
Plug-in" [Active]
org.eclipse.mylyn.web.ui (2.0.0.v20070910-1300) "Mylyn Web UI" [Starting]
org.eclipse.ocl (1.1.0.v200706201508) "Object Constraint Language (OCL)
2.0 Parser/Interpreter" [Starting]
org.eclipse.ocl.ecore (1.1.0.v200706071450) "OCL 2.0 Binding for Ecore"
[Starting]
org.eclipse.ocl.uml (1.1.0.v200706071450) "OCL 2.0 Binding for UML"
[Starting]
org.eclipse.osgi (3.3.0.v20070530) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1
org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1 Utility
Classes" [Resolved]
org.eclipse.pde (3.3.0.v20070608-1300) "Eclipse Plug-in Development
Environment" [Active]
org.eclipse.pde.build (3.3.0.v20070612) "Plug-in Development Environment
Build Support" [Starting]
org.eclipse.pde.core (3.3.0.v20070608-1300) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in
Development User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development
Environment Runtime" [Starting]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.3.0.v20070608-1300) "Plug-in Development UI" [Active]
org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates"
[Starting]
org.eclipse.platform (3.3.0.v20070613) "Eclipse Platform" [Starting]
org.eclipse.platform.doc.isv (3.3.0.v20070621) "Eclipse Platform Plug-in
Developer Guide" [Starting]
org.eclipse.platform.doc.user (3.3.0.I20070615-1300) "Eclipse Workbench
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.0.v20070612) "Eclipse RCP" [Starting]
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.3.0.v20070613) "Eclipse Project SDK" [Starting]
org.eclipse.search (3.3.0.v20070606-0010) "Search Support" [Active]
org.eclipse.swt (3.3.0.v3346) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.3.0.v3346) "Standard Widget Toolkit
org.eclipse.team.core (3.3.0.I20070607) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.0.I20070607) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.100.I20070604) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.0.I20070607) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.3.0.I20070607) "Team Support UI" [Active]
org.eclipse.text (3.3.0.v20070606-0010) "Text" [Resolved]
org.eclipse.tomcat (4.1.230.v20070531) "Tomcat Wrapper" [Starting]
org.eclipse.ui (3.3.0.I20070614-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Starting]
org.eclipse.ui.console (3.2.0.v20070530) "Console" [Active]
org.eclipse.ui.editors (3.3.0.v20070606-0010) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools" [Active]
org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
org.eclipse.ui.cheatsheets (3.3.0.v20070507) "Cheat Sheets" [Starting]
org.eclipse.ui.ide (3.3.0.I20070620) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE UI
Application" [Resolved]
org.eclipse.ui.intro (3.2.100.v20070530) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal Welcome"
[Starting]
org.eclipse.ui.navigator (3.3.0.I20070605-0010) "Common Navigator View"
[Starting]
org.eclipse.ui.navigator.resources (3.3.0.I20070605-0010) "Navigator
Workbench Components" [Starting]
org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management UI"
[Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21
Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.2.100.I20070319-0010) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.3.0.I20070605-0010) "Tabbed
Properties View" [Starting]
org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.3.0.I20070608-1100) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.3.0.v20070606-0010) "Text Editor
Framework" [Active]
org.eclipse.uml2 (2.1.0.v200706251652) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.3.0.v200706251652) "UML2 Ecore Code
org.eclipse.uml2.codegen.ecore.ui (1.3.0.v200706251652) "UML2 Ecore Code
org.eclipse.uml2.common (1.3.0.v200706251652) "UML2 Common" [Starting]
org.eclipse.uml2.common.edit (1.3.0.v200706251652) "UML2 Common Edit
Support" [Starting]
org.eclipse.uml2.uml (2.1.0.v200706251652) "UML2 UML Model" [Starting]
org.eclipse.uml2.uml.ecore.exporter (2.1.0.v200706251652) "UML2 UML
Exporter for EMF" [Starting]
org.eclipse.uml2.uml.ecore.importer (2.1.0.v200706251652) "UML2 UML
Importer for EMF" [Starting]
org.eclipse.uml2.uml.edit (2.1.0.v200706251652) "UML2 UML Edit Support"
[Starting]
org.eclipse.uml2.uml.editor (2.1.0.v200706251652) "UML2 UML Editor"
[Starting]
org.eclipse.uml2.uml.resources (2.1.0.v200706251652) "UML2 UML
org.eclipse.update.configurator (3.2.100.v20070615) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.100.v20070615) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update Core
org.eclipse.update.scheduler (3.2.100.v20070615) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.100.v20070615) "Install/Update UI" [Starting]
org.eclipse.wst (1.0.2.v200706120315) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.203.v200705302225) "Environment Command
Framework (headless)" [Starting]
org.eclipse.wst.command.env.core (1.0.202.v200705302225) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.doc.user (1.5.1.v200706120315) "Web services
Axis Ant task documentation" [Starting]
org.eclipse.wst.command.env.infopop (1.0.3.v200706110217) "Web services
UI" [Starting]
org.eclipse.wst.command.env.ui (1.0.202.v200705302225) "Environment
Command Framework (GUI)" [Starting]
Common Core Source" [Resolved]
Common UI Source" [Resolved]
org.eclipse.wst.common.core (1.1.101.v200706120315) "WST Common Core
Plug-in" [Starting]
org.eclipse.wst.common.emf (1.1.103.v200706071630) "EMF Utilities"
[Starting]
org.eclipse.wst.common.emfworkbench.integration (1.1.103.v200706071630)
"EMF Workbench Edit Plug-in" [Starting]
org.eclipse.wst.common.environment (1.0.200.v200705302225) "Enviornment
Plug-in" [Starting]
org.eclipse.wst.common.frameworks (1.1.102.v200706071630) "Common
Frameworks" [Starting]
org.eclipse.wst.common.frameworks.ui (1.1.100.v200706071630) "WTP UI
Plug-in" [Starting]
org.eclipse.wst.common.infopop (1.0.2.v200706110217) "Common WST
infopops" [Starting]
org.eclipse.wst.common.modulecore (1.1.102.v200706071630) "Modulecore
Plug-in" [Starting]
org.eclipse.wst.common.project.facet.core (1.2.0.v200706071740) "Project
Facet Core" [Starting]
org.eclipse.wst.common.project.facet.ui (1.2.0.v200706071742) "Project
Facet UI" [Starting]
org.eclipse.wst.common.snippets (1.1.101.v200705302225) "Snippets View"
[Starting]
org.eclipse.wst.common.ui (1.1.200.v200705302225) "Eclipse Base UI
extensions" [Starting]
org.eclipse.wst.common.ui.properties (1.0.102.v200706120315) "Common
Properties UI" [Starting]
org.eclipse.wst.common.uriresolver (1.1.201.v200705302225) "Common URI
Resolver Framework" [Starting]
org.eclipse.wst.css.core (1.1.101.v200705302225) "Structured Source CSS
Model" [Starting]
org.eclipse.wst.css.ui (1.0.201.v200705302225) "SSE CSS Source Editor"
[Starting]
org.eclipse.wst.doc.isv (1.0.304.v200706112015) "WST ISV Documentation"
[Starting]
org.eclipse.wst.doc.user (1.1.0.v200705302225) "Master User Doc TOC"
[Starting]
org.eclipse.wst.dtd.core (1.1.101.v200705302225) "Structured Source DTD
Core" [Starting]
org.eclipse.wst.dtd.ui (1.0.201.v200705302225) "SSE DTD Source Editor"
[Starting]
org.eclipse.wst.dtd.ui.infopop (1.0.2.v200706110217) "DTD Editor
infopops" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.300.v200705302225) "DTD Editor
documentation" [Resolved]
org.eclipse.wst.html.core (1.1.101.v200706120811) "Structured Source
HTML Model" [Starting]
org.eclipse.wst.html.ui (1.0.201.v200705302225) "HTML UI Source Editor"
[Starting]
org.eclipse.wst.html.ui.infopop (1.0.2.v200706110217) "HTML editor
org.eclipse.wst.internet.cache (1.0.201.v200705302225) "Cache URI
Resolver Plug-in" [Starting]
org.eclipse.wst.internet.monitor.core (1.0.203.v20070608) "Monitor"
[Starting]
org.eclipse.wst.internet.monitor.ui (1.0.203.v20070608) "TCP/IP Monitor"
[Starting]
org.eclipse.wst.javascript.core (1.0.101.v200706071955) "Structured
Source JavaScript Model" [Starting]
org.eclipse.wst.javascript.ui (1.0.101.v200705302225) "SSE JavaScript
Source Editor" [Starting]
org.eclipse.wst.javascript.ui.infopop (1.0.2.v200706110217) "Javascript
infopop" [Resolved]
Server UI Source" [Resolved]
org.eclipse.wst.server.core (1.0.204.v200706111751) "Server Core" [Starting]
org.eclipse.wst.server.http.core (1.0.0.v200705302225) "HTTP Server
Support" [Starting]
org.eclipse.wst.server.http.ui (1.0.0.v200705302225) "HTTP Server UI
Support" [Starting]
org.eclipse.wst.server.preview (1.0.0.v200705302225) "Preview Server
Support" [Starting]
org.eclipse.wst.server.preview.adapter (1.0.0.v200705302225) "HTTP
Preview Support" [Starting]
org.eclipse.wst.server.ui (1.0.204.v20070619) "Server UI" [Starting]
org.eclipse.wst.server.ui.doc.user (1.0.303.v200705302225) "Server Tools
documentation for Web Standard Tools" [Starting]
org.eclipse.wst.server.ui.infopop (1.0.5.v200705302225) "Server Tools
infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sse.core (1.1.201.v200706212223) "Structured Text Model"
[Starting]
org.eclipse.wst.sse.doc.user (1.0.300.v200705302225) "Structured text
editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.302.v200706192034) "Structured Source
Editor" [Starting]
org.eclipse.wst.sse.ui.infopop (1.0.102.v200706110217) "SSE infopops"
[Resolved]
org.eclipse.wst.standard.schemas (1.0.1.v200705302225) "Standard Schemas
and DTDs" [Resolved]
org.eclipse.wst.validation (1.1.101.v200706071630) "Validation
org.eclipse.wst.validation.infopop (1.0.202.v200706110217) "WST
validation infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.102.v200706071630) "Validation
Framework UI" [Starting]
org.eclipse.wst.web (1.1.101.v200706071630) "Simple Web Plug-in" [Starting]
Source" [Resolved]
Web UI Source" [Resolved]
org.eclipse.wst.web.ui (1.1.101.v200706071630) "Simple Web UI Plug-in"
[Starting]
org.eclipse.wst.web.ui.infopop (1.0.202.v200706110217) "Static Web
infopop" [Starting]
org.eclipse.wst.webtools.doc.user (1.0.300.v200705302225) "Web tools
org.eclipse.wst.ws (1.0.202.v200705311823) "Web Services" [Starting]
Service Core Source" [Resolved]
Web Service UI Source" [Resolved]
org.eclipse.wst.ws.explorer (1.0.204.v200706061845) "Web Services
Explorer" [Starting]
org.eclipse.wst.ws.infopop (1.0.203.v200706110217) "Web Services UI"
[Starting]
org.eclipse.wst.ws.parser (1.0.201.v200706061845) "Web Services
Description Parser" [Starting]
org.eclipse.wst.ws.ui (1.0.202.v200705311823) "Web Services UI" [Starting]
org.eclipse.wst.wsdl (1.1.0.v200706062140) "WSDL Model" [Starting]
org.eclipse.wst.wsdl.ui (1.2.0.v200706062140) "WSDL UI" [Starting]
org.eclipse.wst.wsdl.ui.doc.user (1.0.300.v200705302225) "WSDL Editor
org.eclipse.wst.wsdl.validation (1.1.201.v200706062140) "WSDL Validator"
[Starting]
org.eclipse.wst.wsi (1.0.105.v200706120315) "WSI Conformance Tools"
[Starting]
org.eclipse.wst.wsi.ui (1.0.300.v200706062140) "Soap Monitor" [Starting]
org.eclipse.wst.wsi.ui.doc.user (1.0.203.v200706120315) "WS-I Validation
Documentation" [Resolved]
XML UI Source" [Resolved]
org.eclipse.wst.xml.core (1.1.200.v200706120811) "Structured Source XML
Model" [Starting]
org.eclipse.wst.xml.ui (1.0.300.v200705302225) "XML UI Plugin" [Starting]
org.eclipse.wst.xml.ui.infopop (1.0.2.v200706110217) "XML infopops"
[Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.300.v200705302225) "XML editor"
[Resolved]
org.eclipse.wst.xsd.core (1.1.200.v200705302225) "XSD Core Plugin"
[Starting]
org.eclipse.wst.xsd.ui (1.2.0.v200706131840) "XML Schema Editor" [Starting]
org.eclipse.wst.xsdeditor.doc.user (1.0.300.v200705302225) "XML schema
editor" [Resolved]
org.eclipse.xsd (2.3.0.v200706262000) "XML Schema Infoset Model (XSD)&qu
Re: Eclipse timeline plugin [message #28321 is a reply to message #28233] |
Thu, 13 September 2007 08:42   |
I found that the plugin org.eclipse.equinox.http did not start.
Can you open eclipse with osgi console, and try to start plugin
org.eclipse.equinox.http manually to see what happen?
news:fcas2t$u23$1@build.eclipse.org...
>> dependcy issue.
> Yes, I originally installed it using the update site, and some dependency
> got resolved (I think Eclipse Project Equinox bundle feature). Here are my
> configuration details (the only unusual thing would be using the mylyn dev
> builds instead of the release or the milestone... the activity.xml file
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> -vm
> eof=eof
> file.separator=\
> Files\Common
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=cs_CZ
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=CZ
> user.language=cs
> user.name=User
> user.variant=
> *** Features:
> Client SDK"
> Generator"
> Generation"
> Generation UI"
> Generator UI"
> Support"
> (EMF) Source"
> Technologies - JET"
> org.eclipse.jet.examples (0.8.0.v200704041505) "Eclipse Modeling Framework
> org.eclipse.ocl (1.1.0.v200706071450-32-9oA55P5M8C8KCK) "Object Constraint
> Binding for UML"
> Platform"
> org.eclipse.rcp.source (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse
> Project SDK"
> (2.0.0.v200706041905-7C78EK9E_EkMNfNOd2d8qq) "Web Standard Tools - Common
> Core Source"
> Common UI Source"
> (2.0.0.v200706041905-2-CL8s733G3E4B2862) "Web Standard Tools - Server Core
> Source"
> Server UI Source"
> Source"
> (2.0.0.v200706041905-7A0EAeCiWfEJsCcbAj88SKfRX) "Web Standard Tools - Web
> UI Source"
> Core Source"
> XML UI Source"
> com.ibm.icu.source (3.6.1.v20070417) "International Components for Unicode
> Plug-in" [Starting]
> [Starting]
> [Resolved]
> [Resolved]
> net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge LPG"
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP 2.0
> Plug-in" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene Analysis"
> [Resolved]
> [Resolved]
> [Resolved]
> Mechanism" [Active]
> [Resolved]
> org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression Language"
> [Active]
> [Active]
> org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File System
> [Active]
> [Active]
> Draw2d" [Starting]
> [Starting]
> Support" [Starting]
> [Starting]
> [Starting]
> Model" [Starting]
> org.eclipse.emf.ecore.change.edit (2.3.0.v200706262000) "EMF Ecore Change
> org.eclipse.emf.exporter (2.3.0.v200706262000) "EMF Model Export Support"
> [Starting]
> [Starting]
> org.eclipse.emf.importer (2.3.0.v200706262000) "EMF Model Import Support"
> [Starting]
> org.eclipse.emf.importer.ecore (2.3.0.v200706262000) "EMF Ecore Importer"
> [Starting]
> [Starting]
> [Starting]
> org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200706262000) "Ecore to Ecore
> Mapping" [Starting]
> org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200706262000) "Ecore to
> Mapping" [Starting]
> [Starting]
> org.eclipse.emf.validation.ui.ide (1.0.1.v200703301524) "Eclipse Modeling
> org.eclipse.equinox.app (1.0.0.v20070606) "Equinox Application Container"
> [Active]
> [Active]
> [Resolved]
> [Starting]
> org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service Registry
> org.eclipse.equinox.http.servlet (1.0.0.v20070606) "Http Services Servlet"
> [Starting]
> Bundle" [Starting]
> [Resolved]
> Mechanism" [Active]
> Support" [Active]
> [Resolved]
> [Resolved]
> [Starting]
> [Starting]
> Plug-in" [Starting]
> [Starting]
> org.eclipse.gmf.bridge.ui.dashboard (2.0.0.v20070621-0000) "GMF Dashboard"
> [Starting]
> Support" [Starting]
> org.eclipse.gmf.codegen.ui (1.1.0.v20070621-0000) "GMF Code Generation UI"
> [Starting]
> Plug-in" [Starting]
> org.eclipse.gmf.ecore.editor (2.0.0.v20070621-0000) "ECore Sample Diagram
> Plugin" [Starting]
> org.eclipse.gmf.graphdef (2.0.0.v20070621-0000) "GMF Graphical Definition"
> [Resolved]
> Support" [Starting]
> org.eclipse.gmf.map.edit (2.0.0.v20070621-0000) "GMF Mapping Edit Support"
> [Starting]
> Core" [Starting]
> org.eclipse.gmf.runtime.common.ui (1.0.100.v20070601-1400) "GMF Common UI"
> [Starting]
> org.eclipse.gmf.runtime.common.ui.services.action (1.0.100.v20070601-1400)
> org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.1.v20070601-1400) "GMF
> org.eclipse.gmf.runtime.common.ui.services.dnd.ide (1.0.1.v20070601-1400)
> [Starting]
> org.eclipse.gmf.runtime.diagram.core (1.0.100.v20070601-1400) "GMF Diagram
> Core" [Starting]
> UI" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.1.v20070601-1400) "GMF Diagram
> Browse" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.printing (1.0.100.v20070621-0000) "GMF
> org.eclipse.gmf.runtime.diagram.ui.printing.render (1.0.1.v20070601-1400)
> org.eclipse.gmf.runtime.diagram.ui.providers (1.0.100.v20070621-0000) "GMF
> org.eclipse.gmf.runtime.diagram.ui.resources.editor (1.0.3.v20070601-1400)
> org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.0.100.v20070614-1400) "GMF
> UI" [Starting]
> [Starting]
> org.eclipse.gmf.runtime.emf.ui.properties (1.0.2.v20070601-1400) "GMF EMF
> org.eclipse.gmf.runtime.gef.ui (1.0.1.v20070601-1400) "GMF GEF Additions"
> [Starting]
> org.eclipse.gmf.runtime.notation.edit (1.0.1.v20070621-0000) "GMF Notation
> SDK" [Starting]
> [Starting]
> Support" [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Resolved]
> Apt IDE" [Starting]
> org.eclipse.jdt.apt.ui (3.3.0.v20070430-1135) "Java Annotation Processing
> UI" [Starting]
> [Resolved]
> [Resolved]
> Guide" [Starting]
> org.eclipse.jdt.doc.user (3.3.0.v20070608-1300) "Eclipse Java Development
> org.eclipse.jdt.junit (3.3.0.v20070606-0010) "Java Development Tools JUnit
> support" [Starting]
> org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java Development
> [Active]
> [Starting]
> org.eclipse.jet.ui (0.8.0.v200704041505) "JET Transformations UI Plug-in"
> [Active]
> org.eclipse.ltk.core.refactoring (3.3.0.v20070606-0010) "Refactoring Core"
> [Active]
> [Active]
> org.eclipse.mylyn.context.core (2.0.0.v20070910-1300) "Mylyn Context Core"
> [Active]
> [Active]
> [Active]
> org.eclipse.mylyn.monitor.core (2.0.0.v20070910-1300) "Mylyn Monitor Core"
> [Resolved]
> [Active]
> [Active]
> org.eclipse.mylyn.resources.ui (2.0.0.v20070910-1300) "Mylyn Resources UI"
> [Active]
> [Active]
> [Active]
> org.eclipse.mylyn.team.cvs (2.0.0.v20070910-1300) "Mylyn Team CVS Plug-in"
> [Resolved]
> Core" [Active]
> org.eclipse.mylyn.trac.ui (2.0.0.v20070910-1300) "Mylyn Trac Connector UI"
> [Active]
> org.eclipse.mylyn.web.core (2.0.0.v20070910-1300) "Mylyn Web Core Plug-in"
> [Active]
> [Starting]
> [Starting]
> Classes" [Resolved]
> [Active]
> Test" [Resolved]
> [Active]
> [Starting]
> (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G) "Eclipse Platform Plug-in Developer
> org.eclipse.swt.win32.win32.x86 (3.3.0.v3346) "Standard Widget Toolkit for
> Windows" [Resolved]
> [Active]
> [Active]
> [Starting]
> [Starting]
> [Active]
> Framework" [Active]
> Support" [Starting]
> [Starting]
> [Starting]
> org.eclipse.uml2.uml.resources (2.1.0.v200706251652) "UML2 UML Resources"
> [Resolved]
> org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update Core for
> Windows" [Resolved]
> Scheduler" [Active]
> [Resolved]
> UI" [Starting]
> Plug-in" [Starting]
> [Starting]
> Plug-in" [Starting]
> Plug-in" [Starting]
> org.eclipse.wst.common.infopop (1.0.2.v200706110217) "Common WST infopops"
> [Starting]
> Plug-in" [Starting]
> [Starting]
> Model" [Starting]
> [Starting]
> [Starting]
> [Starting]
> Core" [Starting]
> [Starting]
> org.eclipse.wst.dtd.ui.infopop (1.0.2.v200706110217) "DTD Editor infopops"
> [Resolved]
> org.eclipse.wst.html.core (1.1.101.v200706120811) "Structured Source HTML
> Model" [Starting]
> [Starting]
> org.eclipse.wst.internet.cache (1.0.201.v200705302225) "Cache URI Resolver
> Plug-in" [Starting]
> [Starting]
> [Starting]
> org.eclipse.wst.javascript.core (1.0.101.v200706071955) "Structured Source
> infopop" [Resolved]
> Source" [Resolved]
Re: Eclipse timeline plugin [message #28867 is a reply to message #28396] |
Fri, 14 September 2007 01:48   |
Thanks Robert, i should read the wiki item carefully,;).
And one another quesion which can not find answer on wiki is, how can i get
the repository task created date, the AbstractTask getCreationDate() retrun
the local task created date not the creation date of the remote task.
To David Rothenberger, the bug had fixed, please update the Timeline
features.
"Robert Elves" <rob.elves@eclipse.org> wrote in message
news:fcbp6a$7j0$1@build.eclipse.org...
> Here are the primary entry points you will likely need:
> TaskList taskList = TasksUiPlugin.getTaskListManager().getTaskList();
> // Retrieve all categories
> Set<AbstractTaskCategory> categories = taskList.getCategories();
> // Retrieve all queries
> Set<AbstractRepositoryQuery> queries = taskList.getQueries();
> Call getChildren() on either of these returned types to get all
> AbstractTask objects contained within.
> I've added these notes to:
> http://wiki.eclipse.org/Mylyn_Integrator_Reference#Accessing _the_Task_List
> Feel free to expand on this as you proceed.
> -Rob
> Jay Chen wrote:
>> Yes, there is bug showing all task groups, currently just show task
>> categories, and i am trying to fix it.
>> Since i am not familiar with Mylyn API, do you have any advisement on
>> retreiveing all task groups and retreiveing special groups tasks?
>> I am cleaning up the code, i will upload the code soon.
>> "David Rothenberger" <daveroth@acm.org> wrote in message
>> news:fc771c$kde$1@build.eclipse.org...
>>> On 9/3/2007 11:26 PM, Jay Chen wrote:
>>>> I recently start a eclipse plugin project which use Timeline view (from
>>>> http://simile.mit.edu/timeline/) to show events in eclipse, and it
>>>> integrate with Mylyn to show Mylyn tasks modification in the scrolling
>>>> timeline view.
>>> I tried out this plugin yesterday and really like it. One question: Can
>>> it display information about Mylyn tasks from repositories other than
>>> the local one? I have a Trac repository and the timeline doesn't seem to
>>> include tasks from that repository.
>>> David Rothenberger ---- daveroth@acm.org
>>> wolf, n.:
>>> A man who knows all the ankles.
Re: Eclipse timeline plugin [message #30082 is a reply to message #25224] |
Fri, 21 September 2007 04:19   |
Originally posted by: mk.nospam.org
Jay,
This is really a great idea, I have tried your plug-in and after setting
the http port via the command line it worked for me. However, it is a
little annoying to define a new port for each instance of eclipse, since
I'm often running two or three at once. I don't know if it's possible
with the current implementation of the timeline component, but a
solution could be to run it offline and configure it only via the
browser widget API (assuming you are using that) without having a web
server.
I would enjoy hearing your thoughts about this.
Thanks for your great work so far!
Martin Klinke
Jay Chen wrote:
> Good morning/afternoon/evening,
> Please forgive me if I post the wrong place, but i definitely think it will
> help to mylyn users.
> http://simile.mit.edu/timeline/) to show events in eclipse, and it integrate
> with Mylyn to show Mylyn tasks modification in the scrolling timeline view.
> The project is http://code.google.com/p/eclipsetimeline/, though it is in
> beta state, I hope someone can take a try and provide precious feedback for
> me.
> Thanks.
Re: Eclipse timeline plugin [message #30227 is a reply to message #30082] |
Mon, 24 September 2007 02:43   |
Originally posted by: chen4613.gmail.com
Hi Martin,
For this plugin depends on the great effort from
http://simile.mit.edu/timeline which is a javascript component that best
used in client-server mode. So I choose use a web server in the plugin. To
keep the plugin simple, I use the simple OSGi http service and it was a lazy
approching. Maybe I should change to use the org.eclipse.equinox.http.jetty
which can do more server configuration as the Eclipse Help does. But it is a
heavier implementation than OSGi http service.
About the your suggestion of offline mode, I think it will increase the
complication of manage the javascript source and the datasource locally,
and reduce the performance (must write datasource to somewhere). But I will
try it.
Anyway, thanks for your feedback.
"Martin Klinke" <mk@nospam.org> wrote in message
news:fcvur0$2m2$1@build.eclipse.org...
> Jay,
> I'm often running two or three at once. I don't know if it's possible with
> the current implementation of the timeline component, but a solution could
> be to run it offline and configure it only via the browser widget API
> (assuming you are using that) without having a web server.
> Martin Klinke
>> will help to mylyn users.
>> timeline view.
>> for me.
>> Thanks.
Re: Eclipse timeline plugin [message #31069 is a reply to message #30227] |
Thu, 27 September 2007 14:05   |
Originally posted by: devaughn.cisco.com
For the jetty plugin if you specify 0 for the port then it uses the
first available port. You can then retrieve the http service and get
the port property to see what port it used. I thought this was true for
the osgi http service as well. At least this way a port would not need
to be specified. I have not used the timeline plugin so I am not sure
if this solution would work for you.
Dennis
Jay Chen wrote:
> Hi Martin,
> try it.
>> Jay,
>> Martin Klinke
>>> timeline view.
>>> for me.
>>> Thanks.
Re: Eclipse timeline plugin [message #32820 is a reply to message #31069] |
Thu, 11 October 2007 10:41   |
Sorry for the late reply, i had a long vacation, :).
Thanks for your hint Dennis, i have found a work around for this issue.
If the http service is not avaliable, and BundleContext has no
org.osgi.service.http.port property, set a system property
org.osgi.service.http.port with a unused local port then start
org.eclipse.equinox.http will resolve this problem.
To Martin, i had update the update site files, please update your plugins.
To other people who are intersted with this plugin, since here is mylyn
newsgroup, if you had any issues or suggestions on this plugin, please feel
free to post it in the project issues page, instead here. I think here is
used to talk about mylyn mostly. :).
"Dennis Vaughn" <devaughn@cisco.com>
??????:fdgrce$6go$1@build.eclipse.org...
> For the jetty plugin if you specify 0 for the port then it uses the first
> available port. You can then retrieve the http service and get the port
> property to see what port it used. I thought this was true for the osgi
> http service as well. At least this way a port would not need to be
> specified. I have not used the timeline plugin so I am not sure if this
> Cheers,
> Dennis
> Jay Chen wrote:
>> Hi Martin,
>> To keep the plugin simple, I use the simple OSGi http service and it was
>> a lazy approching. Maybe I should change to use the
>> org.eclipse.equinox.http.jetty which can do more server configuration as
>> the Eclipse Help does. But it is a heavier implementation than OSGi http
>> service.
>> will try it.
>>> Jay,
>>> server.
>>> Martin Klinke
>>>> timeline view.
>>>> in beta state, I hope someone can take a try and provide precious
>>>> feedback for me.
>>>> Thanks.
Re: Eclipse timeline plugin [message #35386 is a reply to message #25224] |
Sat, 03 November 2007 15:58   |
> me.
> Thanks.
Hi, I'm willing to try this plugin, but update manager complains
org.eclipse.equinox.http bundle is not available even it is.
Also, where is the source code? I was willing to take a look in why that
error was happening, but SVN repository in google code is empty.
Willian.
Re: Eclipse timeline plugin [message #70339 is a reply to message #25224] |
Tue, 07 July 2009 12:06   |
Hi everybody,
as I was interested in brushing up my Eclipse skills, I've gone ahead
and hacked together an updated version of this plugin from the
distributes jar files. No source had been made public, but the jars were
under New BSD License according to http://code.google.com/p/eclipsetimeline/
So.. if anybody is interested, I'd be happy to provide what I've got
sofar. Basically working in Eclipse 3.5 environment with Mylyn 3.2
Andreas
> me.
> Thanks.
Re: Eclipse timeline plugin [message #482445 is a reply to message #481521] |
Wed, 26 August 2009 10:54  |
Originally posted by: tagadax.voila.fr
I am trying to use timeline, but :
In the timeline view in Eclipse, I have the following message :
HttpService is not started. Please check the OSGi HTTP service
configuration, make sure the port is not in used.
Could you please help me? I would like to see mylyn tasks in timeline in
Eclipse.
Best regards.
Re: Eclipse timeline plugin [message #580472 is a reply to message #25224] |
Fri, 07 September 2007 14:20  |
> me.
I wanted to try it, but couldn't get it to run. After I restarted Eclipse
and opened the Timeline view, I got the following error:
"HttpService not started. Please check the OSGi HTTP service
configuration, make sure the port is not in used."
Kim
Re: Eclipse timeline plugin [message #580664 is a reply to message #26923] |
Mon, 10 September 2007 05:53  |
It may caused by your port 80 is in used. Eclipse Timeline depends on
HttpService, and the OSGi HttpService's default port is 80, if it is in
used, the HTTPService will start fail, hence, can't start the timeline view.
You can try to start eclipse with
argument -Dorg.osgi.service.http.port=other port.
"Kim Sullivan" <alicebot@seznam.cz> wrote in message
news:fbs4pj$p0f$1@build.eclipse.org...
>> for
>> me.
> Kim
OT: OSGi (was Re: Eclipse timeline plugin) [message #580730 is a reply to message #27200] |
Mon, 10 September 2007 08:56  |
Since you sound like you know what you're talking about - could you tell me
what the heck OSGi is? I went to their web site last week, and all I could
figure out is that it's a thing to enable things in the something space.
Jay
Re: Eclipse timeline plugin [message #580825 is a reply to message #27200] |
Tue, 11 September 2007 12:58  |
Doesn't help, I still get the same error (I checked the eclipse log,
there are no errors in there). I never used the osgi http service, is
there anything else I have to do to configure it?
Kim
Re: Eclipse timeline plugin [message #580843 is a reply to message #25224] |
Tue, 11 September 2007 19:06  |
wolf, n.:
Re: OSGi (was Re: Eclipse timeline plugin) [message #580985 is a reply to message #27274] |
Wed, 12 September 2007 23:15  |
I am not a OSGi guru, and i think i am not master OSGi in deep, so i can't
answer you what the OSGi really is.
I think do more google search, visist wikipedia may help you some, or you
can post question in eclipse.technology.equinox group or other OSGi mailling
list.
Also, i think do some research on eclipse architecture is a plus to help you
understand OSGi.
"Jay Levitt" <jay+news@jay.fm> wrote in message
news:dn8eegj6y9em.dlg@jay.fm...
>> view.
> me
> could
> Jay
Re: Eclipse timeline plugin [message #581006 is a reply to message #27826] |
Wed, 12 September 2007 23:24  |
Do you install the org.eclipse.equinox.http?
I recommend you to install it use the update site
http://eclipsetimeline.googlecode.com/svn/updates, it can resolved the
dependcy issue.
If it still can't work, plz post your eclipse configuration details.
news:fc6hfd$fr7$1@build.eclipse.org...
>> view.
> Doesn't help, I still get the same error (I checked the eclipse log, there
> are no errors in there). I never used the osgi http service, is there
> Kim
Re: Eclipse timeline plugin [message #581030 is a reply to message #27866] |
Wed, 12 September 2007 23:30  |
>> timeline view.
> I tried out this plugin yesterday and really like it. One question: Can it
> display information about Mylyn tasks from repositories other than the
> wolf, n.:
Re: Eclipse timeline plugin [message #581044 is a reply to message #28143] |
Thu, 13 September 2007 04:24  |
> dependcy issue.
dependency got resolved (I think Eclipse Project Equinox bundle
feature). Here are my configuration details (the only unusual thing
would be using the mylyn dev builds instead of the release or the
milestone... the activity.xml file has changed since the Europa release).
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=I20070323-1616
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
D:\Progs\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
D:\Progs\eclipse\plugins\org.eclipse.equinox.launcher.win32. win32.x86_1.0.0.v20070523\eclipse_1017a.dll
-startup
D:\Progs\eclipse\plugins\org.eclipse.equinox.launcher_1.0.0. v20070606.jar
-Dorg.osgi.service.http.port=2001
-vm
C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1189671460687
eclipse.vm=C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.vmargs=-Xmx256M
-XX:MaxPermSize=256m
-Djava.class.path=D:\Progs\eclipse\plugins\org.eclipse.equin ox.launcher_1.0.0.v20070606.jar
eof=eof
file.encoding=Cp1250
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=D:\Progs\eclipse\plugins\org.eclipse.equinox .launcher_1.0.0.v20070606.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_02\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_02\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_02
java.io.tmpdir=C:\DOCUME~1\User\LOCALS~1\Temp\
java.library.path=D:\Progs\eclipse;.;C:\WINDOWS\Sun\Java\bin ;C:\WINDOWS\system32;C:\WINDOWS;C:\Program
Files\Java\jre1.6.0_02\bin\client;C:\Program
Files\Java\jre1.6.0_02\bin;E:\cygwin\bin\;D:\Progs\MinGW\bin ;D:\Progs\Python24\.;D:\Program
Files\Borland\BDS\3.0\Bin;C:\WINDOWS\system32;C:\WINDOWS;C:\ WINDOWS\System32\Wbem;D:\Program
Files\Common
Files\GTK\2.0\bin;D:\progs\PHP\;d:\progs\svn\bin\;"C:\Progra~1\Java\jdk1.6.0 "\bin;d:\Progs\ant\bin;D:\Program
Files\WinSCP\;D:\Progs\svk-2.0.0-1\bin;D:\My Documents\Borland Studio
Projects\Bpl;D:\Modeltech_xe_starter\win32xoem;D:\Program Files\MKVtoolnix
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_02-b06
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_02
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0_02-b06
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.handle=32375712
org.eclipse.equinox.launcher.splash.location=d:\Progs\eclips e\plugins\org.eclipse.platform_3.3.0.v20070613\splash.bmp
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=cs
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.
kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.security.auth.x500,javax.security.cert,javax.security.s asl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sample d,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.s ql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swin g.border,javax.swing.colorchooser,javax.swing.event,javax.sw ing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,java x.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.s ynth,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.tools,javax.transaction,java x.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.ann otation,javax.xml.bind.annotation.adapters,javax.xml.bind.at tachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xm l.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xm l.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cr ypto.dsig.spec,javax.xml.datat
ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stream,javax.xml.stream.events,javax.xml.stream.util, javax.xml.transform,javax.xml.transform.dom,javax.xml.transf orm.sax,javax.xml.transform.stax,javax.xml.transform.stream, javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax .xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,jav ax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,or g.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.Dyn AnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,o rg.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingContextExtPackage,org.omg.CosNaming.NamingContext Package,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAn y.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org. omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPac kage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.P ortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer ,org.omg.PortableServer.Curren
tPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Po rtableServer.POAPackage,org.omg.PortableServer.portable,org. omg.PortableServer.ServantLocatorPackage,org.omg.SendingCont ext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap, org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ex t,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=D:\Progs\eclipse\configuration\org.eclipse. osgi\bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/D:/Progs/eclipse/configuration /
osgi.framework=file:/d:/Progs/eclipse/plugins/org.eclipse.os gi_3.3.0.v20070530.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.0.v20070530
osgi.install.area=file:/D:/Progs/eclipse/
osgi.instance.area=file:/D:/.projects/ibm/eclipse-workspace/
osgi.instance.area.default=file:/D:/.windows/workspace/
osgi.logfile=D:\.projects\ibm\eclipse-workspace\.metadata\.l og
osgi.manifest.cache=D:\Progs\eclipse\configuration\org.eclip se.osgi\manifests
osgi.nl=cs_CZ
osgi.os=win32
osgi.splashLocation=d:\Progs\eclipse\plugins\org.eclipse.pla tform_3.3.0.v20070613\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=d:\Progs\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.6.0_02\lib\resources.jar;C:\Program
Files\Java\jre1.6.0_02\lib\rt.jar;C:\Program
Files\Java\jre1.6.0_02\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.6.0_02\lib\jsse.jar;C:\Program
Files\Java\jre1.6.0_02\lib\jce.jar;C:\Program
Files\Java\jre1.6.0_02\lib\charsets.jar;C:\Program
Files\Java\jre1.6.0_02\classes
sun.boot.library.path=C:\Program Files\Java\jre1.6.0_02\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1250
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=CZ
user.dir=D:\Progs\eclipse
user.home=D:\.windows
user.language=cs
user.name=User
user.timezone=Europe/Prague
user.variant=
*** Features:
org.eclipse.cvs (1.0.0.v20070606-7C79_79EI99g_Y9e) "Eclipse CVS Client"
org.eclipse.cvs.source (1.0.0.v20070606-7C79_79EI99g_Y9e) "Eclipse CVS
Client SDK"
org.eclipse.emf (2.3.0.v200706262000) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.0.v200706262000) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.0.v200706262000) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200706262000) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.0.v200706262000) "EMF Template Code
Generator UI"
org.eclipse.emf.converter (2.3.0.v200706262000) "EMF Model Convert Support"
org.eclipse.emf.doc (2.3.0.v200706262000) "Eclipse Modeling Framework
org.eclipse.emf.ecore.edit (2.3.0.v200706262000) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.0.v200706262000) "Sample Ecore Editor"
org.eclipse.emf.mapping (2.3.0.v200706262000) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.0.v200706262000) "Eclipse Modeling
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200706262000) "Eclipse
org.eclipse.emf.ocl (1.1.0.v200706071450-10-7w311817312619) "Object
Constraint Language (OCL) 2.0 Compatibility API"
org.eclipse.emf.query (1.0.1.v200703301543) "Eclipse Modeling Framework
org.eclipse.emf.query.ocl (1.1.0.v200703301543) "Eclipse Modeling
org.eclipse.emf.source (2.3.0.v200706262000) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.emf.transaction (1.1.0.v200703301538) "Eclipse Modeling
org.eclipse.emf.validation (1.1.0.v200703301524) "Eclipse Modeling
org.eclipse.emf.validation.ocl (1.1.0.v200703301524) "Eclipse Modeling
org.eclipse.emf.workspace (1.1.0.v200703301538) "Eclipse Modeling
org.eclipse.gef (3.3.0.v20070620) "Graphical Editing Framework"
org.eclipse.gmf (1.0.100.v20070601-1400-7d-ETeEYjiMWQX3az0fBWRjypkm7)
org.eclipse.jdt (3.3.0.v20070606-0010-7o7jCHEFpPoqQYvnXqejeR) "Eclipse
org.eclipse.jdt.source (3.3.0.v20070606-0010-7o7jCHEFpPoqQYvnXqejeR)
org.eclipse.jet (0.8.0.v200704041505) "Eclipse Modeling Framework
Technologies - JET"
org.eclipse.jet.doc (0.8.0.v200704041505) "Eclipse Modeling Framework
org.eclipse.jet.source (0.8.0.v200704041505) "Eclipse Modeling Framework
org.eclipse.mylyn_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.context_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.ide_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.java_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.pde_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.sandbox.ui_feature (2.0.0.v20070910-1300) "Mylyn"
org.eclipse.mylyn.trac_feature (2.0.0.v20070910-1300) "Mylyn"
Constraint Language (OCL) 2.0 Parser/Interpreter"
org.eclipse.ocl.uml (1.1.0.v200706071450-10-7w311817182561) "OCL 2.0
Binding for UML"
org.eclipse.pde (3.3.0.v20070607-7N7M-DUUEF6Ez0H46IcCC) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.3.0.v20070607-7N7M-DUUEF6Ez0H46IcCC) "Eclipse
org.eclipse.platform (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G) "Eclipse
Platform"
org.eclipse.platform.source (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G)
org.eclipse.rcp (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse RCP"
org.eclipse.sdk (3.3.0.v20070607-7M7J-BIolz-OcxWxvWAPSfLPqevO) "Eclipse
Project SDK"
org.eclipse.wst (2.0.0.v200706041905-7C-18k0IWJZ93WDDJlQ60nUjTdJp) "Web
org.eclipse.wst.common_core.feature.source
Common Core Source"
org.eclipse.wst.common_ui.feature.source
(2.0.0.v200706041905-7C5EGzE9RvTVniSrwnf4TgOPe3e9) "Web Standard Tools -
Common UI Source"
org.eclipse.wst.sdk (2.0.0.v200706041905-7E-18aNKbx2jys2HTkz0_f_9fLWx)
org.eclipse.wst.server_core.feature.source
Core Source"
org.eclipse.wst.server_ui.feature.source
(2.0.0.v200706041905-77-CQ9vCXBjvZGTVARHF8DBA) "Web Standard Tools -
Server UI Source"
org.eclipse.wst.web_core.feature.source
(2.0.0.v200706041905-42CI_kE77Y7TAMAVHH) "Web Standard Tools - Web Core
Source"
org.eclipse.wst.web_ui.feature.source
Web UI Source"
org.eclipse.wst.ws_core.feature.source
(2.0.0.v200706210215-7E7KE_QEC3wSU4TpiAiQ0r) "Web Standard Tools - Web
org.eclipse.wst.ws_ui.feature.source
(2.0.0.v200706041905-791ECBAufYO8_EaomWE4Fe3uXjR1) "Web Standard Tools -
org.eclipse.wst.xml_core.feature.source
(2.0.0.v200706041905-787BE9zCYQCCz-CnUGLYQV) "Web Standard Tools - XML
Core Source"
org.eclipse.wst.xml_ui.feature.source
(2.0.0.v200706182145-7A1ECBCnbckz0bZu9wHqAKN3mYpZ) "Web Standard Tools -
XML UI Source"
org.eclipse.xsd (2.3.0.v200706262000) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200706262000) "XML Schema Edit Framework"
org.tigris.subversion.subclipse (1.2.3) "SVN Team Provider Core"
*** Plug-in Registry:
com.ibm.icu (3.6.1.v20070417) "International Components for Unicode for
Java (ICU4J)" [Active]
Unicode for Java (ICU4J) source plug-in" [Resolved]
com.ibm.icu36.data.update (3.6.1.v20070701_2007f) "ICU4J Data Update
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
eclipse.timeline (1.0.0.200709051757) "Timeline Plug-in" [Starting]
eclipse.timeline.mylyn (1.0.0.200709051757) "Mylyn Tasks Event Source
Plug-in" [Starting]
eclipse.timeline.xml (1.0.0.200709051757) "Xml Event Source Plug-in"
[Starting]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
javax.servlet.jsp.source (2.0.0.v200706191603) "Java Server Pages API
Source Bundle" [Resolved]
javax.servlet.source (2.4.0.v200706111738) "Servlet API Source Bundle"
[Resolved]
javax.wsdl (1.4.0.v200706111329) "WSDL4J" [Resolved]
javax.wsdl15 (1.5.1.v200705290614) "WSDL4J" [Resolved]
javax.xml.rpc (1.1.0.v200706111329) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200706111329) "SAAJ" [Resolved]
LPG" [Resolved]
net.sourceforge.lpg.lpgjavaruntime.source (1.1.0.v200706111738)
"SourceForge LPG Source Bundle" [Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200706080842) "Apache Ant Source" [Resolved]
org.apache.axis (1.4.0.v200706191647) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200706111724) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200706111724) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200706111724) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200706111724) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200706111724) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.parser (1.6.0.v200706111724) "Apache Batik Parser"
[Resolved]
org.apache.batik.svggen (1.6.0.v200706111724) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.transcoder (1.6.0.v200706111724) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200706111724) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200706111724) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200706111724) "Apache Batik XML" [Resolved]
org.apache.commons.discovery (0.2.0.v200706111329) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
2.0 Expression Language Interpreter Source" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v200706111724) "Apache Commons
Logging Plug-in Source" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.jasper.source (5.5.17.v200706111724) "Apache Jasper 2 Source
Plug-in" [Resolved]
org.apache.log4j (1.2.13.v200706111418) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
Analysis" [Resolved]
org.apache.lucene.analysis.source (1.9.1.v200706181610) "Apache Lucene
Analysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v200706111724) "Apache Lucene Source"
[Resolved]
org.apache.wsil4j (1.0.0.v200706111329) "WSIL4J" [Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"
[Resolved]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.2.100.v20070511) "Ant UI" [Active]
org.eclipse.compare (3.3.0.I20070606) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.0.0.I20070606-0010) "JFace Data Binding"
[Resolved]
org.eclipse.core.databinding.beans (1.0.0.I20070606-0010) "JFace Data
Binding for JavaBeans" [Resolved]
Language" [Active]
org.eclipse.core.filebuffers (3.3.0.v20070606-0010) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Active]
System for Windows" [Resolved]
org.eclipse.core.jobs (3.3.0.v20070423) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.0.0.I20070531) "Internet Connection Management"
[Active]
org.eclipse.core.resources (3.3.0.v20070604) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Starting]
org.eclipse.cvs (1.0.0.v20070606) "Eclipse CVS Client" [Starting]
Client SDK" [Resolved]
org.eclipse.debug.core (3.3.0.v20070607-1800) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.0.v20070607-1800) "Debug UI" [Active]
org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework
Draw2d" [Starting]
[Starting]
org.eclipse.emf.ant (2.3.0.v200706262000) "EMF Ant Tasks" [Starting]
Generator" [Starting]
Generation" [Starting]
Generation UI" [Starting]
Generator UI" [Starting]
org.eclipse.emf.common (2.3.0.v200706262000) "EMF Common" [Starting]
org.eclipse.emf.common.ui (2.3.0.v200706262000) "EMF Common UI" [Starting]
Support" [Starting]
(EMF) Programmers Guide" [Starting]
org.eclipse.emf.ecore (2.3.0.v200706262000) "EMF Ecore" [Starting]
Support" [Starting]
[Starting]
org.eclipse.emf.ecore.change (2.3.0.v200706262000) "EMF Ecore Change
Model" [Starting]
Change Edit Support" [Starting]
org.eclipse.emf.ecore.xmi (2.3.0.v200706262000) "EMF XMI" [Starting]
org.eclipse.emf.edit (2.3.0.v200706262000) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.3.0.v200706262000) "EMF Edit UI" [Starting]
Support" [Starting]
org.eclipse.emf.cheatsheets (2.3.0.v200706262000) "EMF Cheat Sheets"
[Starting]
Support" [Starting]
Importer" [Starting]
org.eclipse.emf.importer.java (2.3.0.v200706262000) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.3.0.v200706262000) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.3.0.v200706262000) "EMF Mapping" [Starting]
Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor" [Starting]
Ecore Mapping" [Starting]
to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.3.0.v200706262000) "Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200706262000) "Ecore to XML
Mapping UI" [Starting]
org.eclipse.emf.mapping.ui (2.3.0.v200706262000) "EMF Mapping UI" [Starting]
org.eclipse.emf.ocl (1.1.0.v200706201508) "Object Constraint Language
(OCL) 2.0 Compatibility API" [Starting]
Technology Query Framework" [Starting]
Framework Technology Query OCL" [Starting]
(EMF) Source" [Resolved]
Framework Technology Transaction Core" [Starting]
org.eclipse.emf.transaction.ui (1.0.1.v200703301538) "Eclipse Modeling
Framework Technology Transaction UI" [Starting]
Framework Technology Model Validation Core" [Starting]
Framework Technology Validation Support for OCL" [Resolved]
org.eclipse.emf.validation.ui (1.1.0.v200703301524) "Eclipse Modeling
Framework Technology Validation UI" [Starting]
Modeling Framework Technology Validation UI IDE" [Starting]
Framework Technology Workbench Core" [Starting]
org.eclipse.emf.workspace.ui (1.0.100.v200703301538) "Eclipse Modeling
Framework Technology Workbench UI" [Starting]
Container" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.device (1.0.0.v20070226) "Device Access Service"
[Resolved]
org.eclipse.equinox.event (1.0.100.v20070516) "Event Admin" [Resolved]
org.eclipse.equinox.http (1.0.100.v20070423) "HTTP Service" [Resolved]
org.eclipse.equinox.http.jetty (1.0.0.v20070607) "Jetty Http Service"
[Starting]
Registry Extensions" [Resolved]
Servlet" [Starting]
org.eclipse.equinox.http.servletbridge (1.0.0.v20070523) "Servletbridge
Http Service" [Resolved]
org.eclipse.equinox.jsp.jasper (1.0.0.v20070607) "Jasper Jsp Support
Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.0.v20070606) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.0.v20070523) "Equinox
Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.log (1.0.100.v20070226) "Log Service" [Resolved]
org.eclipse.equinox.metatype (1.0.0.v20070226) "Meta Type" [Resolved]
org.eclipse.equinox.preferences (3.2.100.v20070522) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.3.0.v20070522) "Extension Registry
Support" [Active]
org.eclipse.equinox.servletbridge (1.0.0.v20070523) "bundleName" [Resolved]
org.eclipse.equinox.useradmin (1.0.0.v20070226) "User Admin Service"
[Resolved]
org.eclipse.gef (3.2.100.v20070620) "Graphical Editing Framework" [Starting]
org.eclipse.gmf (1.0.0.v20070601-1400) "Graphical Modeling Framework"
[Starting]
org.eclipse.gmf.bridge (1.1.0.v20070621-0000) "GMF Models Bridging
Plug-in" [Starting]
org.eclipse.gmf.bridge.ui (1.1.0.v20070621-0000) "GMF Tooling UI" [Starting]
Dashboard" [Starting]
org.eclipse.gmf.codegen (2.0.0.v20070621-0000) "GMF GenModel and Code
org.eclipse.gmf.codegen.edit (2.0.0.v20070614-1400) "GMF GenModel Edit
Support" [Starting]
UI" [Starting]
org.eclipse.gmf.common (1.1.0.v20070621-0000) "GMF Tooling Commons
Plug-in" [Starting]
org.eclipse.gmf.doc.ui (1.1.0.v20070601-1400) "GMF Documentation
Cheatsheets" [Starting]
Diagram Plugin" [Starting]
Definition" [Resolved]
org.eclipse.gmf.graphdef.codegen (2.0.0.v20070621-0000) "Graphical
Definition Code Generator" [Starting]
org.eclipse.gmf.graphdef.codegen.ui (1.0.100.v20070621-0000) "Graphical
Definition Code Generator UI Support" [Resolved]
org.eclipse.gmf.graphdef.edit (2.0.0.v20070601-1400) "GMFGraph Edit
Support" [Starting]
org.eclipse.gmf.map (2.0.0.v20070621-0000) "GMF Mapping Model" [Starting]
Support" [Starting]
org.eclipse.gmf.runtime.common.core (1.0.100.v20070601-1400) "GMF Common
Core" [Starting]
UI" [Starting]
org.eclipse.gmf.runtime.common.ui.action (1.0.100.v20070601-1400) "GMF
Common UI Action" [Starting]
org.eclipse.gmf.runtime.common.ui.action.ide (1.0.1.v20070601-1400) "GMF
Common UI Action IDE" [Starting]
org.eclipse.gmf.runtime.common.ui.printing (1.0.1.v20070601-1400) "GMF
Printing" [Starting]
org.eclipse.gmf.runtime.common.ui.printing.win32 (1.0.2.v20070601-1400)
"GMF Printing for Win32" [Resolved]
org.eclipse.gmf.runtime.common.ui.services (1.0.100.v20070601-1400) "GMF
Common UI Services" [Starting]
(1.0.100.v20070601-1400) "GMF Common UI Action Services" [Starting]
"GMF Common UI DND Services" [Starting]
(1.0.1.v20070601-1400) "GMF Common UI DND IDE Services" [Starting]
org.eclipse.gmf.runtime.common.ui.services.properties
(1.0.1.v20070601-1400) "GMF Common UI Properties Service Framework"
[Starting]
Diagram Core" [Starting]
org.eclipse.gmf.runtime.diagram.ui (1.0.100.v20070621-0000) "GMF Diagram
UI" [Starting]
org.eclipse.gmf.runtime.diagram.ui.actions (1.0.100.v20070621-0000) "GMF
Diagram Actions" [Starting]
Diagram Browse" [Starting]
org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.0.1.v20070601-1400) "GMF
Geometric Shapes" [Starting]
"GMF Diagram Printing" [Starting]
(1.0.1.v20070601-1400) "GMF Diagram UI Printing Render Plug-In" [Starting]
org.eclipse.gmf.runtime.diagram.ui.properties (1.0.100.v20070608-1300)
"GMF Diagram UI Properties" [Starting]
"GMF Diagram Providers" [Starting]
org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.0.1.v20070601-1400)
"GMF Diagram Providers IDE" [Starting]
org.eclipse.gmf.runtime.diagram.ui.render (1.0.100.v20070621-0000) "GMF
Diagram UI Render Plug-In" [Starting]
(1.0.3.v20070601-1400) "GMF Diagram UI Resources Editor Plug-In" [Starting]
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide
(1.0.3.v20070601-1400) "GMF IDE Editor" [Starting]
org.eclipse.gmf.runtime.draw2d.ui (1.0.100.v20070621-0000) "GMF Draw2d
Additions" [Starting]
org.eclipse.gmf.runtime.draw2d.ui.render (1.0.100.v20070614-1400) "GMF
Draw2d Image Rendering Additions" [Starting]
"GMF Draw2d Image AWT based Rendering Additions" [Starting]
org.eclipse.gmf.runtime.emf.clipboard.core (1.0.100.v20070621-0000) "GMF
EMF Clipboard Support" [Starting]
org.eclipse.gmf.runtime.emf.commands.core (1.0.3.v20070601-1400) "GMF
Commands" [Starting]
org.eclipse.gmf.runtime.emf.core (1.0.100.v20070601-1400) "GMF Modeling
Service Layer" [Starting]
org.eclipse.gmf.runtime.emf.type.core (1.0.100.v20070601-1400) "GMF EMF
Type Core" [Starting]
org.eclipse.gmf.runtime.emf.type.ui (1.0.1.v20070601-1400) "GMF EMF Type
UI" [Starting]
org.eclipse.gmf.runtime.emf.ui (1.0.100.v20070621-0000) "GMF MSL UI"
[Starting]
EMF UI Properties Providers" [Starting]
org.eclipse.gmf.runtime.notation (1.0.100.v20070621-0000) "GMF Notation
Model Support" [Starting]
Notation Edit Support" [Starting]
org.eclipse.gmf.runtime.notation.providers (1.0.1.v20070601-1400) "GMF
Notation Metamodel" [Starting]
org.eclipse.gmf.sdk (1.0.0.v20070601-1400) "Graphical Modeling Framework
SDK" [Starting]
org.eclipse.gmf.tooldef (2.0.0.v20070621-0000) "GMF Tooling Model"
[Starting]
org.eclipse.gmf.tooldef.edit (2.0.0.v20070601-1400) "GMF Tooling Edit
Support" [Starting]
org.eclipse.gmf.validate (1.1.0.v20070621-0000) "GMF Validation" [Starting]
org.eclipse.gmf.xpand (1.0.0.v20070608-1300) "GMF Xpand Template Engine"
[Starting]
org.eclipse.help (3.3.0.v20070524) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.0.v20070606) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.0.v20070530) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.0.v20070607) "Help System Webapp" [Starting]
org.eclipse.jdt (3.3.0.v20070607-1300) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.3.0.v20070607-1200) "Java Annotation
Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.0.v20070529-2100) "Java Compiler
Apt IDE" [Starting]
Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.0.v20070510-2000) "Java Compiler Apt"
[Resolved]
org.eclipse.jdt.compiler.tool (1.0.0.v_771) "Java Compiler Tool Support"
[Resolved]
org.eclipse.jdt.core (3.3.0.v_771) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.3.0.v20070530a) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.100.v20070531-1800) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.3.0.v20070613) "Eclipse JDT Plug-in Developer
Guide" [Starting]
Development User Guide" [Starting]
JUnit support" [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development
Tools JUnit runtime support" [Resolved]
Development Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.3.0.v20070510) "Java Development Tools
Launching Support" [Active]
"Eclipse Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.3.0.v20070607-0010) "Java Development Tools UI"
[Active]
org.eclipse.jem.util (2.0.0.v200705302225) "Java EMF Model Utilities"
[Starting]
Technologies - JET" [Starting]
org.eclipse.jet.core (1.0.0.v200704041505) "Eclipse Modeling Framework
Technologies - JET Core" [Starting]
Technologies - JET Documentation" [Starting]
Framework Technologies - JET Examples" [Starting]
Technologies - JET SDK" [Resolved]
Plug-in" [Active]
org.eclipse.jface (3.3.0.I20070606-0010) "JFace" [Active]
org.eclipse.jface.databinding (1.1.0.I20070606-0010) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.3.0.v20070606-0010) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Active]
org.eclipse.jsch.ui (1.0.0.I20070525) "JSch UI" [Starting]
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.3.0.v20070606-0010) "Refactoring UI"
[Active]
org.eclipse.mylyn (2.0.0.v20070910-1300) "Mylyn" [Starting]
org.eclipse.mylyn.bugzilla.core (2.0.0.v20070910-1300) "Mylyn Bugzilla
Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (2.0.0.v20070910-1300) "Mylyn Bugzilla
Connector IDE" [Active]
org.eclipse.mylyn.bugzilla.ui (2.0.0.v20070910-1300) "Mylyn Bugzilla
Connector UI" [Active]
org.eclipse.mylyn.compatibility (2.0.0.v20070910-1300) "Java 5
Compatibility Checker" [Active]
Core" [Active]
org.eclipse.mylyn.context.ui (2.0.0.v20070910-1300) "Mylyn Context UI"
[Active]
org.eclipse.mylyn.help.ui (2.0.0.v20070910-1300) "Mylyn Help" [Starting]
org.eclipse.mylyn.ide.ant (2.0.0.v20070910-1300) "Mylyn Ant UI Plug-in"
[Active]
org.eclipse.mylyn.ide.ui (2.0.0.v20070910-1300) "Mylyn IDE UI" [Active]
org.eclipse.mylyn.java.ui (2.0.0.v20070910-1300) "Mylyn Java" [Active]
Core" [Resolved]
org.eclipse.mylyn.monitor.ui (2.0.0.v20070910-1300) "Mylyn Monitor UI"
[Active]
org.eclipse.mylyn.pde.ui (2.0.0.v20070910-1300) "Mylyn PDE UI Plug-in"
[Active]
UI" [Active]
org.eclipse.mylyn.sandbox.ui (2.0.0.v20070910-1300) "Mylyn Sandbox
Experimental UI" [Active]
org.eclipse.mylyn.tasks.core (2.0.0.v20070910-1300) "Mylyn Tasks Core"
[Active]
org.eclipse.mylyn.tasks.ui (2.0.0.v20070910-1300) "Mylyn Tasks UI" [Active]
Plug-in" [Resolved]
org.eclipse.mylyn.team.ui (2.0.0.v20070910-1300) "Mylyn Team UI" [Active]
org.eclipse.mylyn.trac.core (2.0.0.v20070910-1300) "Mylyn Trac Connector
Core" [Active]
UI" [Active]
Plug-in" [Active]
org.eclipse.mylyn.web.ui (2.0.0.v20070910-1300) "Mylyn Web UI" [Starting]
org.eclipse.ocl (1.1.0.v200706201508) "Object Constraint Language (OCL)
2.0 Parser/Interpreter" [Starting]
org.eclipse.ocl.ecore (1.1.0.v200706071450) "OCL 2.0 Binding for Ecore"
[Starting]
org.eclipse.ocl.uml (1.1.0.v200706071450) "OCL 2.0 Binding for UML"
[Starting]
org.eclipse.osgi (3.3.0.v20070530) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1
org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1 Utility
Classes" [Resolved]
org.eclipse.pde (3.3.0.v20070608-1300) "Eclipse Plug-in Development
Environment" [Active]
org.eclipse.pde.build (3.3.0.v20070612) "Plug-in Development Environment
Build Support" [Starting]
org.eclipse.pde.core (3.3.0.v20070608-1300) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in
Development User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development
Environment Runtime" [Starting]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.3.0.v20070608-1300) "Plug-in Development UI" [Active]
org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates"
[Starting]
org.eclipse.platform (3.3.0.v20070613) "Eclipse Platform" [Starting]
org.eclipse.platform.doc.isv (3.3.0.v20070621) "Eclipse Platform Plug-in
Developer Guide" [Starting]
org.eclipse.platform.doc.user (3.3.0.I20070615-1300) "Eclipse Workbench
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
org.eclipse.rcp (3.2.0.v20070612) "Eclipse RCP" [Starting]
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.3.0.v20070613) "Eclipse Project SDK" [Starting]
org.eclipse.search (3.3.0.v20070606-0010) "Search Support" [Active]
org.eclipse.swt (3.3.0.v3346) "Standard Widget Toolkit" [Resolved]
org.eclipse.team.core (3.3.0.I20070607) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.0.I20070607) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.100.I20070604) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.0.I20070607) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.3.0.I20070607) "Team Support UI" [Active]
org.eclipse.text (3.3.0.v20070606-0010) "Text" [Resolved]
org.eclipse.tomcat (4.1.230.v20070531) "Tomcat Wrapper" [Starting]
org.eclipse.ui (3.3.0.I20070614-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Starting]
org.eclipse.ui.console (3.2.0.v20070530) "Console" [Active]
org.eclipse.ui.editors (3.3.0.v20070606-0010) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools" [Active]
org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
org.eclipse.ui.cheatsheets (3.3.0.v20070507) "Cheat Sheets" [Starting]
org.eclipse.ui.ide (3.3.0.I20070620) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE UI
Application" [Resolved]
org.eclipse.ui.intro (3.2.100.v20070530) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal Welcome"
[Starting]
org.eclipse.ui.navigator (3.3.0.I20070605-0010) "Common Navigator View"
[Starting]
org.eclipse.ui.navigator.resources (3.3.0.I20070605-0010) "Navigator
Workbench Components" [Starting]
org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management UI"
[Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21
Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.2.100.I20070319-0010) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.3.0.I20070605-0010) "Tabbed
Properties View" [Starting]
org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.3.0.I20070608-1100) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.3.0.v20070606-0010) "Text Editor
Framework" [Active]
org.eclipse.uml2 (2.1.0.v200706251652) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.3.0.v200706251652) "UML2 Ecore Code
org.eclipse.uml2.codegen.ecore.ui (1.3.0.v200706251652) "UML2 Ecore Code
org.eclipse.uml2.common (1.3.0.v200706251652) "UML2 Common" [Starting]
org.eclipse.uml2.common.edit (1.3.0.v200706251652) "UML2 Common Edit
Support" [Starting]
org.eclipse.uml2.uml (2.1.0.v200706251652) "UML2 UML Model" [Starting]
org.eclipse.uml2.uml.ecore.exporter (2.1.0.v200706251652) "UML2 UML
Exporter for EMF" [Starting]
org.eclipse.uml2.uml.ecore.importer (2.1.0.v200706251652) "UML2 UML
Importer for EMF" [Starting]
org.eclipse.uml2.uml.edit (2.1.0.v200706251652) "UML2 UML Edit Support"
[Starting]
org.eclipse.uml2.uml.editor (2.1.0.v200706251652) "UML2 UML Editor"
[Starting]
org.eclipse.update.configurator (3.2.100.v20070615) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.100.v20070615) "Install/Update Core" [Active]
org.eclipse.update.scheduler (3.2.100.v20070615) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.100.v20070615) "Install/Update UI" [Starting]
org.eclipse.wst (1.0.2.v200706120315) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.203.v200705302225) "Environment Command
Framework (headless)" [Starting]
org.eclipse.wst.command.env.core (1.0.202.v200705302225) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.doc.user (1.5.1.v200706120315) "Web services
Axis Ant task documentation" [Starting]
org.eclipse.wst.command.env.infopop (1.0.3.v200706110217) "Web services
UI" [Starting]
org.eclipse.wst.command.env.ui (1.0.202.v200705302225) "Environment
Command Framework (GUI)" [Starting]
Common Core Source" [Resolved]
Common UI Source" [Resolved]
org.eclipse.wst.common.core (1.1.101.v200706120315) "WST Common Core
Plug-in" [Starting]
org.eclipse.wst.common.emf (1.1.103.v200706071630) "EMF Utilities"
[Starting]
org.eclipse.wst.common.emfworkbench.integration (1.1.103.v200706071630)
"EMF Workbench Edit Plug-in" [Starting]
org.eclipse.wst.common.environment (1.0.200.v200705302225) "Enviornment
Plug-in" [Starting]
org.eclipse.wst.common.frameworks (1.1.102.v200706071630) "Common
Frameworks" [Starting]
org.eclipse.wst.common.frameworks.ui (1.1.100.v200706071630) "WTP UI
Plug-in" [Starting]
infopops" [Starting]
org.eclipse.wst.common.modulecore (1.1.102.v200706071630) "Modulecore
Plug-in" [Starting]
org.eclipse.wst.common.project.facet.core (1.2.0.v200706071740) "Project
Facet Core" [Starting]
org.eclipse.wst.common.project.facet.ui (1.2.0.v200706071742) "Project
Facet UI" [Starting]
org.eclipse.wst.common.snippets (1.1.101.v200705302225) "Snippets View"
[Starting]
org.eclipse.wst.common.ui (1.1.200.v200705302225) "Eclipse Base UI
extensions" [Starting]
org.eclipse.wst.common.ui.properties (1.0.102.v200706120315) "Common
Properties UI" [Starting]
org.eclipse.wst.common.uriresolver (1.1.201.v200705302225) "Common URI
Resolver Framework" [Starting]
org.eclipse.wst.css.core (1.1.101.v200705302225) "Structured Source CSS
Model" [Starting]
org.eclipse.wst.css.ui (1.0.201.v200705302225) "SSE CSS Source Editor"
[Starting]
org.eclipse.wst.doc.isv (1.0.304.v200706112015) "WST ISV Documentation"
[Starting]
org.eclipse.wst.doc.user (1.1.0.v200705302225) "Master User Doc TOC"
[Starting]
org.eclipse.wst.dtd.core (1.1.101.v200705302225) "Structured Source DTD
Core" [Starting]
org.eclipse.wst.dtd.ui (1.0.201.v200705302225) "SSE DTD Source Editor"
[Starting]
infopops" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.300.v200705302225) "DTD Editor
documentation" [Resolved]
HTML Model" [Starting]
org.eclipse.wst.html.ui (1.0.201.v200705302225) "HTML UI Source Editor"
[Starting]
org.eclipse.wst.html.ui.infopop (1.0.2.v200706110217) "HTML editor
Resolver Plug-in" [Starting]
org.eclipse.wst.internet.monitor.core (1.0.203.v20070608) "Monitor"
[Starting]
org.eclipse.wst.internet.monitor.ui (1.0.203.v20070608) "TCP/IP Monitor"
[Starting]
Source JavaScript Model" [Starting]
org.eclipse.wst.javascript.ui (1.0.101.v200705302225) "SSE JavaScript
Source Editor" [Starting]
org.eclipse.wst.javascript.ui.infopop (1.0.2.v200706110217) "Javascript
infopop" [Resolved]
Server UI Source" [Resolved]
org.eclipse.wst.server.core (1.0.204.v200706111751) "Server Core" [Starting]
org.eclipse.wst.server.http.core (1.0.0.v200705302225) "HTTP Server
Support" [Starting]
org.eclipse.wst.server.http.ui (1.0.0.v200705302225) "HTTP Server UI
Support" [Starting]
org.eclipse.wst.server.preview (1.0.0.v200705302225) "Preview Server
Support" [Starting]
org.eclipse.wst.server.preview.adapter (1.0.0.v200705302225) "HTTP
Preview Support" [Starting]
org.eclipse.wst.server.ui (1.0.204.v20070619) "Server UI" [Starting]
org.eclipse.wst.server.ui.doc.user (1.0.303.v200705302225) "Server Tools
documentation for Web Standard Tools" [Starting]
org.eclipse.wst.server.ui.infopop (1.0.5.v200705302225) "Server Tools
infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sse.core (1.1.201.v200706212223) "Structured Text Model"
[Starting]
org.eclipse.wst.sse.doc.user (1.0.300.v200705302225) "Structured text
editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.302.v200706192034) "Structured Source
Editor" [Starting]
org.eclipse.wst.sse.ui.infopop (1.0.102.v200706110217) "SSE infopops"
[Resolved]
org.eclipse.wst.standard.schemas (1.0.1.v200705302225) "Standard Schemas
and DTDs" [Resolved]
org.eclipse.wst.validation (1.1.101.v200706071630) "Validation
org.eclipse.wst.validation.infopop (1.0.202.v200706110217) "WST
validation infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.102.v200706071630) "Validation
Framework UI" [Starting]
org.eclipse.wst.web (1.1.101.v200706071630) "Simple Web Plug-in" [Starting]
Source" [Resolved]
Web UI Source" [Resolved]
org.eclipse.wst.web.ui (1.1.101.v200706071630) "Simple Web UI Plug-in"
[Starting]
org.eclipse.wst.web.ui.infopop (1.0.202.v200706110217) "Static Web
infopop" [Starting]
org.eclipse.wst.webtools.doc.user (1.0.300.v200705302225) "Web tools
org.eclipse.wst.ws (1.0.202.v200705311823) "Web Services" [Starting]
Service Core Source" [Resolved]
Web Service UI Source" [Resolved]
org.eclipse.wst.ws.explorer (1.0.204.v200706061845) "Web Services
Explorer" [Starting]
org.eclipse.wst.ws.infopop (1.0.203.v200706110217) "Web Services UI"
[Starting]
org.eclipse.wst.ws.parser (1.0.201.v200706061845) "Web Services
Description Parser" [Starting]
org.eclipse.wst.ws.ui (1.0.202.v200705311823) "Web Services UI" [Starting]
org.eclipse.wst.wsdl (1.1.0.v200706062140) "WSDL Model" [Starting]
org.eclipse.wst.wsdl.ui (1.2.0.v200706062140) "WSDL UI" [Starting]
org.eclipse.wst.wsdl.ui.doc.user (1.0.300.v200705302225) "WSDL Editor
org.eclipse.wst.wsdl.validation (1.1.201.v200706062140) "WSDL Validator"
[Starting]
org.eclipse.wst.wsi (1.0.105.v200706120315) "WSI Conformance Tools"
[Starting]
org.eclipse.wst.wsi.ui (1.0.300.v200706062140) "Soap Monitor" [Starting]
org.eclipse.wst.wsi.ui.doc.user (1.0.203.v200706120315) "WS-I Validation
Documentation" [Resolved]
XML UI Source" [Resolved]
org.eclipse.wst.xml.core (1.1.200.v200706120811) "Structured Source XML
Model" [Starting]
org.eclipse.wst.xml.ui (1.0.300.v200705302225) "XML UI Plugin" [Starting]
org.eclipse.wst.xml.ui.infopop (1.0.2.v200706110217) "XML infopops"
[Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.300.v200705302225) "XML editor"
[Resolved]
org.eclipse.wst.xsd.core (1.1.200.v200705302225) "XSD Core Plugin"
[Starting]
org.eclipse.wst.xsd.ui (1.2.0.v200706131840) "XML Schema Editor" [Starting]
org.eclipse.wst.xsdeditor.doc.user (1.0.300.v200705302225) "XML schema
editor" [Resolved]
org.eclipse.xsd (2.3.0.v200706262000) "XML Schema Infoset Model (XSD)&qu
Re: Eclipse timeline plugin [message #581112 is a reply to message #28233] |
Thu, 13 September 2007 08:42  |
I found that the plugin org.eclipse.equinox.http did not start.
Can you open eclipse with osgi console, and try to start plugin
org.eclipse.equinox.http manually to see what happen?
news:fcas2t$u23$1@build.eclipse.org...
>> dependcy issue.
> Yes, I originally installed it using the update site, and some dependency
> got resolved (I think Eclipse Project Equinox bundle feature). Here are my
> configuration details (the only unusual thing would be using the mylyn dev
> builds instead of the release or the milestone... the activity.xml file
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> -vm
> eof=eof
> file.separator=\
> Files\Common
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=cs_CZ
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=CZ
> user.language=cs
> user.name=User
> user.variant=
> *** Features:
> Client SDK"
> Generator"
> Generation"
> Generation UI"
> Generator UI"
> Support"
> (EMF) Source"
> Technologies - JET"
> org.eclipse.jet.examples (0.8.0.v200704041505) "Eclipse Modeling Framework
> org.eclipse.ocl (1.1.0.v200706071450-32-9oA55P5M8C8KCK) "Object Constraint
> Binding for UML"
> Platform"
> org.eclipse.rcp.source (3.3.0.v20070607-8y8eE8NEbsN3X_fjWS8HPNG) "Eclipse
> Project SDK"
> (2.0.0.v200706041905-7C78EK9E_EkMNfNOd2d8qq) "Web Standard Tools - Common
> Core Source"
> Common UI Source"
> (2.0.0.v200706041905-2-CL8s733G3E4B2862) "Web Standard Tools - Server Core
> Source"
> Server UI Source"
> Source"
> (2.0.0.v200706041905-7A0EAeCiWfEJsCcbAj88SKfRX) "Web Standard Tools - Web
> UI Source"
> Core Source"
> XML UI Source"
> com.ibm.icu.source (3.6.1.v20070417) "International Components for Unicode
> Plug-in" [Starting]
> [Starting]
> [Resolved]
> [Resolved]
> net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200706111738) "SourceForge LPG"
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP 2.0
> Plug-in" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene Analysis"
> [Resolved]
> [Resolved]
> [Resolved]
> Mechanism" [Active]
> [Resolved]
> org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression Language"
> [Active]
> [Active]
> org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File System
> [Active]
> [Active]
> Draw2d" [Starting]
> [Starting]
> Support" [Starting]
> [Starting]
> [Starting]
> Model" [Starting]
> org.eclipse.emf.ecore.change.edit (2.3.0.v200706262000) "EMF Ecore Change
> org.eclipse.emf.exporter (2.3.0.v200706262000) "EMF Model Export Support"
> [Starting]
> [Starting]
> org.eclipse.emf.importer (2.3.0.v200706262000) "EMF Model Import Support"
> [Starting]
> org.eclipse.emf.importer.ecore (2.3.0.v200706262000) "EMF Ecore Importer"
> [Starting]
> [Starting]
> [Starting]
> org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200706262000) "Ecore to Ecore
> Mapping" [Starting]
> org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200706262000) "Ecore to
> Mapping" [Starting]
> [Starting]
> org.eclipse.emf.validation.ui.ide (1.0.1.v200703301524) "Eclipse Modeling
> org.eclipse.equinox.app (1.0.0.v20070606) "Equinox Application Container"
> [Active]
> [Active]
> [Resolved]
> [Starting]
> org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service Registry
> org.eclipse.equinox.http.servlet (1.0.0.v20070606) "Http Services Servlet"
> [Starting]
> Bundle" [Starting]
> [Resolved]
> Mechanism" [Active]
> Support" [Active]
> [Resolved]
> [Resolved]
> [Starting]
> [Starting]
> Plug-in" [Starting]
> [Starting]
> org.eclipse.gmf.bridge.ui.dashboard (2.0.0.v20070621-0000) "GMF Dashboard"
> [Starting]
> Support" [Starting]
> org.eclipse.gmf.codegen.ui (1.1.0.v20070621-0000) "GMF Code Generation UI"
> [Starting]
> Plug-in" [Starting]
> org.eclipse.gmf.ecore.editor (2.0.0.v20070621-0000) "ECore Sample Diagram
> Plugin" [Starting]
> org.eclipse.gmf.graphdef (2.0.0.v20070621-0000) "GMF Graphical Definition"
> [Resolved]
> Support" [Starting]
> org.eclipse.gmf.map.edit (2.0.0.v20070621-0000) "GMF Mapping Edit Support"
> [Starting]
> Core" [Starting]
> org.eclipse.gmf.runtime.common.ui (1.0.100.v20070601-1400) "GMF Common UI"
> [Starting]
> org.eclipse.gmf.runtime.common.ui.services.action (1.0.100.v20070601-1400)
> org.eclipse.gmf.runtime.common.ui.services.dnd (1.0.1.v20070601-1400) "GMF
> org.eclipse.gmf.runtime.common.ui.services.dnd.ide (1.0.1.v20070601-1400)
> [Starting]
> org.eclipse.gmf.runtime.diagram.core (1.0.100.v20070601-1400) "GMF Diagram
> Core" [Starting]
> UI" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.dnd (1.0.1.v20070601-1400) "GMF Diagram
> Browse" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.printing (1.0.100.v20070621-0000) "GMF
> org.eclipse.gmf.runtime.diagram.ui.printing.render (1.0.1.v20070601-1400)
> org.eclipse.gmf.runtime.diagram.ui.providers (1.0.100.v20070621-0000) "GMF
> org.eclipse.gmf.runtime.diagram.ui.resources.editor (1.0.3.v20070601-1400)
> org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.0.100.v20070614-1400) "GMF
> UI" [Starting]
> [Starting]
> org.eclipse.gmf.runtime.emf.ui.properties (1.0.2.v20070601-1400) "GMF EMF
> org.eclipse.gmf.runtime.gef.ui (1.0.1.v20070601-1400) "GMF GEF Additions"
> [Starting]
> org.eclipse.gmf.runtime.notation.edit (1.0.1.v20070621-0000) "GMF Notation
> SDK" [Starting]
> [Starting]
> Support" [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Resolved]
> Apt IDE" [Starting]
> org.eclipse.jdt.apt.ui (3.3.0.v20070430-1135) "Java Annotation Processing
> UI" [Starting]
> [Resolved]
> [Resolved]
> Guide" [Starting]
> org.eclipse.jdt.doc.user (3.3.0.v20070608-1300) "Eclipse Java Development
> org.eclipse.jdt.junit (3.3.0.v20070606-0010) "Java Development Tools JUnit
> support" [Starting]
> org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java Development
> [Active]
> [Starting]
> org.eclipse.jet.ui (0.8.0.v200704041505) "JET Transformations UI Plug-in"
> [Active]
> org.eclipse.ltk.core.refactoring (3.3.0.v20070606-0010) "Refactoring Core"
> [Active]
> [Active]
> org.eclipse.mylyn.context.core (2.0.0.v20070910-1300) "Mylyn Context Core"
> [Active]
> [Active]
> [Active]
> org.eclipse.mylyn.monitor.core (2.0.0.v20070910-1300) "Mylyn Monitor Core"
> [Resolved]
> [Active]
> [Active]
> org.eclipse.mylyn.resources.ui (2.0.0.v20070910-1300) "Mylyn Resources UI"
> [Active]
> [Active]
> [Active]
> org.eclipse.mylyn.team.cvs (2.0.0.v20070910-1300) "Mylyn Team CVS Plug-in"
> [Resolved]
> Core" [Active]
> org.eclipse.mylyn.trac.ui (2.0.0.v20070910-1300) "Mylyn Trac Connector UI"
> [Active]
> org.eclipse.mylyn.web.core (2.0.0.v20070910-1300) "Mylyn Web Core Plug-in"
> [Active]
> [Starting]
> [Starting]
> Classes" [Resolved]
> [Active]
> Test" [Resolved]
> [Active]
> [Starting]
> (3.3.0.v20070612-_19UEkLEzwsdF9jSqQ-G) "Eclipse Platform Plug-in Developer
> org.eclipse.swt.win32.win32.x86 (3.3.0.v3346) "Standard Widget Toolkit for
> Windows" [Resolved]
> [Active]
> [Active]
> [Starting]
> [Starting]
> [Active]
> Framework" [Active]
> Support" [Starting]
> [Starting]
> [Starting]
> org.eclipse.uml2.uml.resources (2.1.0.v200706251652) "UML2 UML Resources"
> [Resolved]
> org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update Core for
> Windows" [Resolved]
> Scheduler" [Active]
> [Resolved]
> UI" [Starting]
> Plug-in" [Starting]
> [Starting]
> Plug-in" [Starting]
> Plug-in" [Starting]
> org.eclipse.wst.common.infopop (1.0.2.v200706110217) "Common WST infopops"
> [Starting]
> Plug-in" [Starting]
> [Starting]
> Model" [Starting]
> [Starting]
> [Starting]
> [Starting]
> Core" [Starting]
> [Starting]
> org.eclipse.wst.dtd.ui.infopop (1.0.2.v200706110217) "DTD Editor infopops"
> [Resolved]
> org.eclipse.wst.html.core (1.1.101.v200706120811) "Structured Source HTML
> Model" [Starting]
> [Starting]
> org.eclipse.wst.internet.cache (1.0.201.v200705302225) "Cache URI Resolver
> Plug-in" [Starting]
> [Starting]
> [Starting]
> org.eclipse.wst.javascript.core (1.0.101.v200706071955) "Structured Source
> infopop" [Resolved]
> Source" [Resolved]
Re: Eclipse timeline plugin [message #581152 is a reply to message #28182] |
Thu, 13 September 2007 12:40  |
Here are the primary entry points you will likely need:
TaskList taskList = TasksUiPlugin.getTaskListManager().getTaskList();
// Retrieve all categories
Set<AbstractTaskCategory> categories = taskList.getCategories();
// Retrieve all queries
Set<AbstractRepositoryQuery> queries = taskList.getQueries();
Call getChildren() on either of these returned types to get all
AbstractTask objects contained within.
I've added these notes to:
http://wiki.eclipse.org/Mylyn_Integrator_Reference#Accessing _the_Task_List
Feel free to expand on this as you proceed.
-Rob
Jay Chen wrote:
> Yes, there is bug showing all task groups, currently just show task
> categories, and i am trying to fix it.
> Since i am not familiar with Mylyn API, do you have any advisement on
> retreiveing all task groups and retreiveing special groups tasks?
> I am cleaning up the code, i will upload the code soon.
> "David Rothenberger" <daveroth@acm.org> wrote in message
> news:fc771c$kde$1@build.eclipse.org...
>> On 9/3/2007 11:26 PM, Jay Chen wrote:
>>> I recently start a eclipse plugin project which use Timeline view (from
>>> http://simile.mit.edu/timeline/) to show events in eclipse, and it
>>> integrate with Mylyn to show Mylyn tasks modification in the scrolling
>>> timeline view.
>> local one? I have a Trac repository and the timeline doesn't seem to
>> include tasks from that repository.
>> David Rothenberger ---- daveroth@acm.org
>> wolf, n.:
>> A man who knows all the ankles.
Re: Eclipse timeline plugin [message #581207 is a reply to message #28396] |
Fri, 14 September 2007 01:48  |
Originally posted by: chen4613.gmail.com
Thanks Robert, i should read the wiki item carefully,;).
And one another quesion which can not find answer on wiki is, how can i get
the repository task created date, the AbstractTask getCreationDate() retrun
the local task created date not the creation date of the remote task.
To David Rothenberger, the bug had fixed, please update the Timeline
features.
"Robert Elves" <rob.elves@eclipse.org> wrote in message
news:fcbp6a$7j0$1@build.eclipse.org...
> -Rob
>>>> timeline view.
>>> it display information about Mylyn tasks from repositories other than
>>> the local one? I have a Trac repository and the timeline doesn't seem to
>>> wolf, n.:
Re: Eclipse timeline plugin [message #581221 is a reply to message #28867] |
Fri, 14 September 2007 14:16  |
> features.
Thanks! That did fix the problem.
I did encounter one other small bug, though. If I click on Scroll To
Date ... and then Today, I lose all events. If I click on OK in the same
box, they all come back.
QOTD:
"She's about as smart as bait."
Re: Eclipse timeline plugin [message #581260 is a reply to message #28867] |
Fri, 14 September 2007 14:53  |
Great to see all this interest in the timeline :)
Jay: please post API questions to the mylyn-integrators list, and feel
free to open bugs tagged [api] to make access to the information you
need easier.
http://eclipse.org/mylyn/community/
Mik
> features.
Re: Eclipse timeline plugin [message #581786 is a reply to message #25224] |
Fri, 21 September 2007 04:19  |
Jay,
This is really a great idea, I have tried your plug-in and after setting
the http port via the command line it worked for me. However, it is a
little annoying to define a new port for each instance of eclipse, since
I'm often running two or three at once. I don't know if it's possible
with the current implementation of the timeline component, but a
solution could be to run it offline and configure it only via the
browser widget API (assuming you are using that) without having a web
server.
I would enjoy hearing your thoughts about this.
Thanks for your great work so far!
Martin Klinke
Jay Chen wrote:
> Good morning/afternoon/evening,
> Please forgive me if I post the wrong place, but i definitely think it will
> help to mylyn users.
> http://simile.mit.edu/timeline/) to show events in eclipse, and it integrate
> with Mylyn to show Mylyn tasks modification in the scrolling timeline view.
> The project is http://code.google.com/p/eclipsetimeline/, though it is in
> beta state, I hope someone can take a try and provide precious feedback for
> me.
> Thanks.
Re: Eclipse timeline plugin [message #581883 is a reply to message #30082] |
Mon, 24 September 2007 02:43  |
Hi Martin,
For this plugin depends on the great effort from
http://simile.mit.edu/timeline which is a javascript component that best
used in client-server mode. So I choose use a web server in the plugin. To
keep the plugin simple, I use the simple OSGi http service and it was a lazy
approching. Maybe I should change to use the org.eclipse.equinox.http.jetty
which can do more server configuration as the Eclipse Help does. But it is a
heavier implementation than OSGi http service.
About the your suggestion of offline mode, I think it will increase the
complication of manage the javascript source and the datasource locally,
and reduce the performance (must write datasource to somewhere). But I will
try it.
Anyway, thanks for your feedback.
"Martin Klinke" <mk@nospam.org> wrote in message
news:fcvur0$2m2$1@build.eclipse.org...
> Jay,
> I'm often running two or three at once. I don't know if it's possible with
> the current implementation of the timeline component, but a solution could
> be to run it offline and configure it only via the browser widget API
> (assuming you are using that) without having a web server.
> Martin Klinke
>> will help to mylyn users.
>> timeline view.
>> for me.
>> Thanks.
Re: Eclipse timeline plugin [message #582304 is a reply to message #25224] |
Thu, 27 September 2007 04:51  |
Originally posted by: eclipse.20.dbaer.spamgourmet.com
Hello
I can't install it. The timeline-features in the Updates-dialog creates this
error message:
"Timeline (1.0.0.200709141105) requires plug-in "javax.servlet"."
Any hints?
Thank you!
d.
Re: Eclipse timeline plugin [message #582310 is a reply to message #30862] |
Thu, 27 September 2007 05:14  |
You have to install the Eclipse Project Equinox bundle feature from the
Eclipse Updates site.
Baer wrote:
> Hello
> this error message:
> Any hints?
> Thank you!
> d.
Re: Eclipse timeline plugin [message #582332 is a reply to message #30896] |
Thu, 27 September 2007 07:56  |
Thank you for the hint, but I still get the same error message.
I have Eclipse 3.2.2 and installed the equinox-bundle (no entry in the "Featrue
Details", but 10 different org.eclipse.equinox.*-plugins). Equinox version
3.2.2.r322_v20070104-A15rI75VboyEcIl.
> Baer wrote:
>> Hello
>> creates this error message:
>> Any hints?
>> Thank you!
>> d.
Re: Eclipse timeline plugin [message #582363 is a reply to message #30931] |
Thu, 27 September 2007 12:41  |
Do you have the org.eclipse.equinox.http plug-in? Maybe you need to
start with -clean? I have it running under 3.3.
Another thing you could try is to go to Find and Install -> Search for
new features to install and select ALL update sites you have (including
the one for timeline), select timeline and then select required.
HTH,
Martin
> "Featrue Details", but 10 different org.eclipse.equinox.*-plugins).
> Equinox version 3.2.2.r322_v20070104-A15rI75VboyEcIl.
>> the Eclipse Updates site.
>> Baer wrote:
>>> Hello
>>> Any hints?
>>> Thank you!
>>> d.
Re: Eclipse timeline plugin [message #582401 is a reply to message #30227] |
Thu, 27 September 2007 14:05  |
For the jetty plugin if you specify 0 for the port then it uses the
first available port. You can then retrieve the http service and get
the port property to see what port it used. I thought this was true for
the osgi http service as well. At least this way a port would not need
to be specified. I have not used the timeline plugin so I am not sure
if this solution would work for you.
Dennis
Jay Chen wrote:
> Hi Martin,
> try it.
>> Jay,
>> Martin Klinke
>>> timeline view.
>>> for me.
>>> Thanks.
Re: Eclipse timeline plugin [message #583297 is a reply to message #31069] |
Thu, 11 October 2007 10:41  |
Sorry for the late reply, i had a long vacation, :).
Thanks for your hint Dennis, i have found a work around for this issue.
If the http service is not avaliable, and BundleContext has no
org.osgi.service.http.port property, set a system property
org.osgi.service.http.port with a unused local port then start
org.eclipse.equinox.http will resolve this problem.
To Martin, i had update the update site files, please update your plugins.
To other people who are intersted with this plugin, since here is mylyn
newsgroup, if you had any issues or suggestions on this plugin, please feel
free to post it in the project issues page, instead here. I think here is
used to talk about mylyn mostly. :).
"Dennis Vaughn" <devaughn@cisco.com>
??????:fdgrce$6go$1@build.eclipse.org...
> For the jetty plugin if you specify 0 for the port then it uses the first
> available port. You can then retrieve the http service and get the port
> property to see what port it used. I thought this was true for the osgi
> http service as well. At least this way a port would not need to be
> specified. I have not used the timeline plugin so I am not sure if this
> Cheers,
> Dennis
> Jay Chen wrote:
>> Hi Martin,
>> To keep the plugin simple, I use the simple OSGi http service and it was
>> a lazy approching. Maybe I should change to use the
>> org.eclipse.equinox.http.jetty which can do more server configuration as
>> the Eclipse Help does. But it is a heavier implementation than OSGi http
>> service.
>> will try it.
>>> Jay,
>>> server.
>>> Martin Klinke
>>>> timeline view.
>>>> in beta state, I hope someone can take a try and provide precious
>>>> feedback for me.
>>>> Thanks.
Re: Eclipse timeline plugin [message #583315 is a reply to message #28876] |
Hi David,
It is fixed, please update your plugins.
??????:fcej55$nut$1@build.eclipse.org...
>> features.
> I did encounter one other small bug, though. If I click on Scroll To Date
> ... and then Today, I lose all events. If I click on OK in the same box,
> they all come back.
> QOTD:
Re: Eclipse timeline plugin [message #584379 is a reply to message #25224] |
Sat, 03 November 2007 15:58  |
> me.
> Thanks.
Hi, I'm willing to try this plugin, but update manager complains
org.eclipse.equinox.http bundle is not available even it is.
Also, where is the source code? I was willing to take a look in why that
error was happening, but SVN repository in google code is empty.
Willian.
Re: Eclipse timeline plugin [message #584391 is a reply to message #35386] |
Sat, 03 November 2007 18:14  |
> that error was happening, but SVN repository in google code is empty.
By the way, why does that plugin require http server? Can't you just
serve a content from the Java code directly to the browser widget and
hook up some listeners to handle events from browser widget?
regards,
Eugene
Re: Eclipse timeline plugin [message #584879 is a reply to message #25224] |
Mon, 19 November 2007 08:42  |
Nice idea- but can't get it to run. After installing, I can show the view,
but all I get is (presumably) a javascirpt error:
Caught exception: [object Error]
Details: undefined
Any idea what I'm doing wrong?
Andi
"Jay Chen" <chen4613@gmail.com> wrote in message
news:fbitqj$j4i$1@build.eclipse.org...
> timeline view.
> for me.
> Thanks.
Re: Eclipse timeline plugin [message #591110 is a reply to message #32820] |
Thu, 10 July 2008 03:14  |
Hi Jay,
I really like the plugin and would like to extend it. Any chance you
could release the sources or upgrade it to current Mylyn 3.0 release?
Andi
Re: Eclipse timeline plugin [message #598054 is a reply to message #25224] |
Tue, 07 July 2009 12:06  |
Hi everybody,
as I was interested in brushing up my Eclipse skills, I've gone ahead
and hacked together an updated version of this plugin from the
distributes jar files. No source had been made public, but the jars were
under New BSD License according to http://code.google.com/p/eclipsetimeline/
So.. if anybody is interested, I'd be happy to provide what I've got
sofar. Basically working in Eclipse 3.5 environment with Mylyn 3.2
Andreas
> me.
> Thanks.
Re: Eclipse timeline plugin [message #598841 is a reply to message #70339] |
Fri, 21 August 2009 07:43  |
Andreas Goetz wrote on Tue, 07 July 2009 12:06
> Best regards,
> Andreas
Hi Andreas,
I'm working with eclipse 3.5 too and would be very interested in the fixed plugin !
Unfortunately I can't enable the "private message" feature in my profile and don't want to post my emailaddress here. Could you attach the plugin to a message here or provide a link ?
best regards
Thomas
Re: Eclipse timeline plugin [message #598868 is a reply to message #598841] |
Wed, 26 August 2009 10:51  |
Originally posted by: tagadax.voila.fr
Hi Andreas,
I am also working with eclipse 3.5 and Mylyn 3.2, and I would like to use
your timeline development to see Mylyn tasks in it, but when I open the
Timeline view in Eclipse, I have the following message :
HttpService is not started. Please check the OSGi HTTP service
configuration, make sure the port is not in used.
Could you please help me to solve this problem? Thank you in advance.
Re: Eclipse timeline plugin [message #598875 is a reply to message #598841] |
Wed, 26 August 2009 10:54  |
I am trying to use timeline, but :
In the timeline view in Eclipse, I have the following message :
Could you please help me? I would like to see mylyn tasks in timeline in
Eclipse.
Best regards.
Current Time: Sat May 10 09:57:39 EDT 2025
Powered by FUDForum. Page generated in 0.16684 seconds
