RC3 loading problem [message #255560] |
Fri, 25 June 2004 07:00  |
Since RC3 is out, I'm constantly receiving the following message right after
workbench loading, and also experiencing 5 second delay, which is very
annoying as slows down the plugin development process.
While loading class
" org.eclipse.team.internal.ccvs.ui.console.ConsoleDocument$Co nsoleLine ",
thread "main" timed out waiting (5000ms) for thread "Worker-0" to finish
starting bundle "org.eclipse.team.cvs.ui". To avoid deadlock, thread "main"
is proceeding but
" org.eclipse.team.internal.ccvs.ui.console.ConsoleDocument$Co nsoleLine " may
not be fully initialized.
I tried to find an answer in the news/bugzilla but did not succeed. Any
idea?
Thanx
/Leo
Re: RC3 loading problem [message #256041 is a reply to message #255586] |
Sun, 27 June 2004 09:50   |
I've just intstalled 3.0 release (build 200406251208) from scratch. But the
problem still exists.
While loading class
is proceeding but
java.lang.Exception: Generated exception.
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
assLoader.java:102)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
oader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java:93)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.team.internal.ccvs.ui.console.ConsoleDocument.ge tLines(ConsoleDo
cument.java:78)
org.eclipse.team.internal.ccvs.ui.console.CVSOutputConsole.d ump(CVSOutputCon
sole.java:150)
org.eclipse.team.internal.ccvs.ui.console.CVSOutputConsole.a ccess$1(CVSOutpu
tConsole.java:147)
org.eclipse.team.internal.ccvs.ui.console.CVSOutputConsole$1 .run(CVSOutputCo
nsole.java:118)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
----- Original Message -----
Newsgroups: eclipse.platform
Sent: Friday, June 25, 2004 2:01 PM
Subject: Re: RC3 loading problem
> I believe this has been fixed in later builds.
> PaScaL
after
> > While loading class
"main"
> > is proceeding but
may
> > idea?
> > Thanx
> > /Leo
Re: RC3 loading problem [message #256094 is a reply to message #256041] |
Sun, 27 June 2004 11:12  |
Originally posted by: pascal.ibm.canada
The CVS team looked at the problem and guaranteed the fact that this is
not a problem.
PaScaL
> While loading class
> is proceeding but
> at
> assLoader.java:102)
> at
> oader.java:371)
> at
> .java:402)
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> cument.java:78)
> at
> sole.java:150)
> at
> tConsole.java:147)
> at
> nsole.java:118)
> at
> at
> at
> java:335)
> at
> at
> From: "Pascal Rapicault" <pascal@ibm.canada>
>>PaScaL
> after
>>>While loading class
> "main"
>>>is proceeding but
> may
>>>idea?
>>>Thanx
>>>/Leo
FUDForum. Page generated in 0.03636 seconds
