Home » Archived » BIRT » Please help - Kinda lost
Please help - Kinda lost [message #255474] Fri, 14 September 2007 10:26 Go to next message
Originally posted by: sheldon.oreilly.gmail.com
Hi All.
I really need some help please. I am looking into Birt 2.2 for a project
we are doing at my company.
The scenario is that
1) our client would use Eclipse to design reports.
2) the reports designs (.rptdesign) would be deployed to the webserver.
3) then through the our web interface (think J2EE mapping web app) the
reports can be accessed by the user.
But the kicker is: While the query is known at design time (Oracle DB
BTW), such as SELECT * FROM SCHOOLS;
The actual values (WHERE Clause) would not be known till run-time. E.g.
The user selects from the map six schools in an area and then wishes to
produce the report based only on the six selected schools.
A Report (UI) parameter will not suffice - the user should not have to
enter the school names explicitly.
My attempts so far is this:
Use the Birt viewer and simply use a ? parameter in the design query and
then pass the runtime values in through the URL - But i cant figure out
how to make the report interpret this:
SELECT * FROM SCHOOLS WHERE SCHOOLNAME = ?
as
SELECT * FROM SCHOOLS WHERE SCHOOLNAME = inParamA AND inParamB AND
inParamC ...
Plus this approach seems less the ideal do to url lenght limitations.
Another way was I figured was to use Engine API in a servlet to get the
query string from the design and then alter it and set it back. But i
dont really see anything like this in the API or the oodles of web
searching that I've done.
Can someone please advise me. What may the best approach (above or other)
and some clue on how to implement it/
Scripting, java code, etc is a viable solution for me, only requirement I
have is that the client needs to be able to easily use the Eclipse
designer to create the reports(no scripting) on their end.
Sheldon
Re: Please help - Kinda lost [message #255486 is a reply to message #255474] Fri, 14 September 2007 11:27 Go to previous message
Sheldon,
You can do this using the beforeOpen script on the dataset like.
this.queryText = this.queryText + " mywhereclause" ; or if in a parameter
this.queryText = this.queryText + " " + prams["mywhereclause"];
You can use a standard string parameter or multiple parameters. Another
option to look at is is use the Tag libraries to build your own
parameter page.
Jason
Sheldon wrote:
> Hi All.
> project we are doing at my company.
> E.g. The user selects from the map six schools in an area and then
> wishes to produce the report based only on the six selected schools.
> as
> inParamC ...
> other) and some clue on how to implement it/
> I have is that the client needs to be able to easily use the Eclipse
> Thanks
> Sheldon
Previous Topic:Urgent:Specifying multiple values for Y-Series
Next Topic:Error calling Platform.startup() for teh Servelt Demo
Current Time: Thu Jul 17 23:18:52 EDT 2025
Powered by FUDForum. Page generated in 0.10196 seconds
