Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Project meta data is out of date for tools.buckminster
[buckminster-dev] Project meta data is out of date for tools.buckminster [message #25168] Fri, 05 September 2008 00:00
Henrik, Thomas,
Projects are required to keep meta data up to date using the MyFoundation
Portal (http://portal.eclipse.org/). The following problems were found
with this project's meta-data:
* The date for release "1.1.1" is in the past, but the release is not
marked as completed. If it is completed, it should be marked as completed;
if it has been postponed, it should be given a new target date.
* There is no next/future release of this project. All Eclipse projects
must have a "next release" planned and scheduled.
Previous Topic:Wiki articles on getting your builds up and running with Buckminster
Next Topic:Build system now checked into SVN
Current Time: Sat May 10 09:51:01 EDT 2025
Powered by FUDForum. Page generated in 0.02738 seconds
