Home » Language IDEs » Java Development Tools (JDT) » Eclipse 3.3 -> 3.4: Warning no longer reported
Eclipse 3.3 -> 3.4: Warning no longer reported [message #255091] Wed, 16 July 2008 15:11 Go to next message
I'm using Eclipse 3.3 and am looking at using 3.4 on an existing project.
When I build the project with 3.4 one of the warnings reported under 3.3
is no longer reported.
The warning is "The method {methodName} does not override the inherited
method from {parent class} since it is private to a different package".
This can be seen in the following code:
Parent.java
package com.bar;
public class Parent {
static Object getSomething() {
return "parent";
Child.java
package com.foo;
import com.bar.Parent;
public class Child extends Parent{
return "child";
This code in Eclipse 3.3 will display the warning at the getSomething() in
Child. The same code in Eclipse 3.4 displays no warning.
Is this a bug in 3.4? Or was 3.3 broken?
Thanks!
Re: Eclipse 3.3 -> 3.4: Warning no longer reported [message #255105 is a reply to message #255091] Thu, 17 July 2008 07:42 Go to previous message
3.3 was wrong, since static methods are not technically overriding each
other:
Try for instance:
class Parent {
return "parent";
class Child extends Parent {
return "child";
It will report an error which is valid.
Previous Topic:Question regarding copySubtree Method
Next Topic:Eclipse often freezes when cleaning projects
Current Time: Tue Jul 15 16:26:26 EDT 2025
Powered by FUDForum. Page generated in 0.15036 seconds
