Home » Language IDEs » Java Development Tools (JDT) » How does the JDT editor do paren and bracket matching?
How does the JDT editor do paren and bracket matching? [message #254977] |
Fri, 11 July 2008 19:32  |
Could someone please point me the code in the JDT and hopefully some
explanation?
I kind of get the idea on how to do it for my editor, but I want to make
sure I do it correctly for my editor. Basically it involves adding an
annotation to show the matching parenthesis or bracket.
Thank you.
Re: How does the JDT editor do paren and bracket matching? [message #255012 is a reply to message #255008] |
Mon, 14 July 2008 20:34   |
AL wrote:
> Daniel Megert wrote:
>>> explanation?
>>> make sure I do it correctly for my editor. Basically it involves
>>> adding an annotation to show the matching parenthesis or bracket.
>> See
>> org.eclipse.ui.texteditor.SourceViewerDecorationSupport.setC haracterPairMatcher(ICharacterPairMatcher)
> I installed the DefaultCharacterPairMatcher with char[] = {'(', ')',
> '{', '}', '[', ']'} and to the partition of interest. Nothing happens
> :-( The installation is done in MyEditor.createPartControl(...); that
> is, MyEditor.createPartControl(...) calls super.createPartControl(...)
> then install the DefaultCharacterPairMatcher.
> Am I missing something? Thanks for any tips!
Added MyEditor.configureSourceViewerDecorationSupport(support), where
'MyEditor' extends TextEditor and 'support' is
SourceViewerDecorationSupport object. Still not working...
Re: How does the JDT editor do paren and bracket matching? [message #255019 is a reply to message #255012] |
Tue, 15 July 2008 01:59   |
AL wrote:
>>>> explanation?
>>> See
Ok...Chased it down a bit more...This is quite frustrating, as much as I
really like Eclipse, but there is no example :-(
Using the Java editor as my guide...Finally I chased it down to
MatchingCharacterPainter.paint(int reason), where a point and click
causes the execution of the method.
With my editor, I point and click but not event generated to execute the
method MatchingCharacterPainter.pain(int reason). I know that
MatchingCharacterPainter is created for my editor.
Any tip?
Re: How does the JDT editor do paren and bracket matching? [message #255029 is a reply to message #255019] |
Tue, 15 July 2008 07:08   |
Originally posted by: asterite.esperanto.org.ar
AL a écrit :
> AL wrote:
>>>>> some explanation?
>>>> See
>>> Hi,
>>> happens :-( The installation is done in
>>> MyEditor.createPartControl(...); that is,
> Any tip?
Hi Al,
It seems the character painter matcher only works if there is an
associated preference for it, and it is enabled.
See this:
http://kickjava.com/src/org/eclipse/ui/texteditor/SourceView erDecorationSupport.java.htm
(method areMatchingCharactersShown())
And here it is how it is done in JDT:
protected void
configureSourceViewerDecorationSupport(SourceViewerDecoratio nSupport
support) {
fBracketMatcher.setSourceVersion(getPreferenceStore().getStr ing(JavaCore.COMPILER_SOURCE));
support.setCharacterPairMatcher(fBracketMatcher);
support.setMatchingCharacterPainterPreferenceKeys(MATCHING_B RACKETS,
MATCHING_BRACKETS_COLOR);
super.configureSourceViewerDecorationSupport(support);
Where MATCHING_BRACKETS and MATCHING_BRACKETS_COLOR are strings that
indicate preferences. The easiest thing you can do for this to work is
to make a preference initializer for your plugin that set those keys to
"enabled" and some color. See the "org.eclipse.core.runtime.preferences"
extension point.
Hope that helps.
Re: How does the JDT editor do paren and bracket matching? [message #255039 is a reply to message #255029] |
Tue, 15 July 2008 12:54   |
Ary Borenszweig wrote:
> AL a écrit :
>> AL wrote:
>>>>>> some explanation?
>>>>>> to make sure I do it correctly for my editor. Basically it
>>>>>> involves adding an annotation to show the matching parenthesis or
>>>>>> bracket.
>>>>> See
>>>> Hi,
>> I really like Eclipse, but there is no example :-(
>> the method MatchingCharacterPainter.pain(int reason). I know that
>> Any tip?
> Hi Al,
> See this:
> @Override
> protected void
> support) {
> extension point.
> Hope that helps.
Thanks for your response...Yeah, I did the above, too. My editor
overrides the configureSourceViewerDecorationSupport(...) and call the
setMatchCharacterPainterPreferenceKeys(...) method with my own
preference keys that are from the preference store I set to the
decoration support object. I have stepped into the code and verify that
the preference values are correctly set and got. They are iniitalized
in my preference initializer.
But still not working--ca va pas :-(
Re: How does the JDT editor do paren and bracket matching? [message #255066 is a reply to message #255039] |
Wed, 16 July 2008 03:14  |
>> AL a écrit :
>>> AL wrote:
>>>>>>> some explanation?
>>>>>>> bracket.
>>>>>> See
>>>>> Hi,
>>>>> ')', '{', '}', '[', ']'} and to the partition of interest. Nothing
>>>> where 'MyEditor' extends TextEditor and 'support' is
>>> as I really like Eclipse, but there is no example :-(
>>> Any tip?
>> Hi Al,
>> See this:
>> @Override
>> protected void
>> support) {
>> to "enabled" and some color. See the
>> "org.eclipse.core.runtime.preferences" extension point.
>> Hope that helps.
Eureka! The problem was that I override the method
AbstractTextEditor.configureSourceViewerDecorationSupport(.. .), which
gets called before the TextEditor.createPartControl(...). There I set
everything up, but when createPartControl(..) gets called, it's
installed the TextEditor's preference to the
SourceViewerDecoratorSupport object, thus, disabling the
PairMatcherPainter that I previously set in the overriden
configureSourceViewerDecorationSupport(...) method. This is why no
painting was done.
The solution is to set things at the end of the overriden
MyEditor.createPartControl(...) method, after calling
super.createPartControl(...) method.
Current Time: Thu Jul 17 22:34:53 EDT 2025
Powered by FUDForum. Page generated in 0.30528 seconds
