jdt not up-to-date? [message #254882] |
Tue, 08 July 2008 17:51  |
I'm having a problem with reading some not update info from the jdt model.
Here's my scenario...
In my app I am using some third party code that generates some java source
files into my project. Then my code needs to introspect those generated
source files and perform some additional code gen based on that. What I
find happening is when I introspect those source files, sometimes (seems
to be random) I get incorrect results (e.g. getting no methods when there
should be some).
I find that if I trigger a build between the generation and my
introspecting code, then I would get the right reuslts.
So my question is, is a build absolutely necessary to force the jdt model
to be updated? Is there some lighter weight method I can call instead of
a build? I read in the javadocs that jdt has reconcile() and
makeConsistent() methods, would these methods help with my problem?
Thanks in advance
Andrew
Re: jdt not up-to-date? [message #254886 is a reply to message #254882] |
Tue, 08 July 2008 19:04  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I'm assuming the third-party code simply did a java.io.File write into
your project. If it did, after you come back from that code you need to
do a refresh on the project or folder where the files were written too.
If you don't then Eclipse doesn't know right away that those files were
changed. It will eventually notice this but maybe not right away if you
don't do a refresh.
See the IResource.refresh() method.
Andrew Mak wrote:
> model. Here's my scenario...
> source files into my project. Then my code needs to introspect those
> generated source files and perform some additional code gen based on
> that. What I find happening is when I introspect those source files,
> sometimes (seems to be random) I get incorrect results (e.g. getting no
> methods when there should be some).
> model to be updated? Is there some lighter weight method I can call
> instead of a build? I read in the javadocs that jdt has reconcile() and
> Thanks in advance
> Andrew
Rich Kulp
FUDForum. Page generated in 0.06077 seconds
