Home » Newcomers » Newcomers » classpath not working ...
classpath not working ... [message #254705] |
Thu, 24 April 2008 20:59  |
Originally posted by: jeffbis.email.arizona.edu
Hello Everyone,
I am working through the Thinking in Java book and trying to get things to
work in Eclipse.
Here is how things are set up.
1. I have a folder on drive d: called d:\work.
2. I have the Thinking in Java book source code in a folder called:
d:\tij\code
Inside of this folder are .java and .class files in a directory structure.
I have the following class defined:
import java.util.*;
import static net.mindview.util.Print;
public class Print1 {
System.out.println("hello world");
print("Hello, it's: ");
print(new Date());
I tried to compile this and of course it failed due to not finding the
print class.
I then went into the project properties, Java Build Path and added a class
path to an external folder, that being:
d:\tij\code
Same issue.
I tried retyping the import line like so:
and pressed down arrow.
It resolved to:
net.mindview.util.
It won't resolve to print.
If I set a CLASSPATH variable to d:\tij\code and manually compile from the
command line and run the code it works fine.
Please help. It is driving me nuts.
Re: classpath not working ... [message #254723 is a reply to message #254705] |
Fri, 25 April 2008 08:10   |
Jeff,
Comments below.
Jeff Bishop wrote:
> Hello Everyone,
> things to work in Eclipse.
> d:\tij\code
> structure.
> import java.util.*;
> public static void main(String[] args) {
> print(new Date());
> print class.
> class path to an external folder, that being:
> d:\tij\code
Until 3.4M6, Java didn't properly support external folder on the
classpath. You could create a Java project that has d:/tij as the
project's physical location and configure the Java project o make code a
source folder. Or you could create a jar with the .class files and
point to that.
> Same issue.
> It resolved to:
> net.mindview.util.
> the command line and run the code it works fine.
I'd recommend trying to set up the tij/code thing as a project so that
you can get at all the source to browse it and debug into it easily...
Failing that, build a jar for it or use 3.4M6 and try again. Note that
I'm assuming that the "code" folder is the root of the source tree,
i.e., that the first folder under code represents the first segment of a
qualified package name...
Re: classpath not working ... [message #254742 is a reply to message #254723] |
Fri, 25 April 2008 09:46   |
What does everyone think about using 3.4m6? Do you think it is a pretty
stable release even though it is a beta? Can one simply unzip the eclipse
and overwrite the Eclipse already installed? What has changed in that
release?
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fushn9$8lt$1@build.eclipse.org...
> Jeff,
> Comments below.
> Jeff Bishop wrote:
>> Hello Everyone,
>> to work in Eclipse.
>> d:\tij\code
>> structure.
>> import java.util.*;
>> print(new Date());
>> print class.
>> d:\tij\code
> source folder. Or you could create a jar with the .class files and point
> to that.
>> Same issue.
>> It resolved to:
>> net.mindview.util.
> I'd recommend trying to set up the tij/code thing as a project so that you
> I'm assuming that the "code" folder is the root of the source tree, i.e.,
Re: classpath not working ... [message #254746 is a reply to message #254742] |
Fri, 25 April 2008 10:07   |
--------------000908010508000209020905
Jeff,
Comments below.
Because I'm developing the latest version of EMF, I always use the
platform's latest integration builds for all my development needs. It's
extremely rare for an integration build to have problems that make it
unusable.
Definitely. Especially when you get into the later milestones and soon
the release candidate builds. It also provides a service to the
community to test these builds and iron out any issues that have been
overlooked before there is a general release. So we Eclipse developers
greatly appreciate people trying out these builds and especially
reporting problems with them! You might want to get one of the packages
if you need plugins other than just the bare Eclipse ones:
<http://www.eclipse.org/downloads/packages/>
Yes, you can unzip, but no, don't overwrite existing installations. Put
it in a new place. Keep the old one around in case you have problems
and you'll be able to go back to using it.
> release?
The JDT added support for external folders, much to my personal
delight. Along with the corresponding changes in the PDE, this allows
me to bootstrap my development environment far more easily; I use EMF
itself to regenerate my models, so when I make changes to the generator,
I need to apply those changes to the project in the workspace I'm
already working on...
>> Jeff,
>> Comments below.
>> Jeff Bishop wrote:
>>> Hello Everyone,
>>> to work in Eclipse.
>>> d:\tij\code
>>> structure.
>>> import java.util.*;
>>> print(new Date());
>>> print class.
>>> d:\tij\code
>> to that.
>>> Same issue.
>>> It resolved to:
>>> net.mindview.util.
<html>
<head>
</head>
Jeff,<br>
<br>
Comments below.<br>
<br>
Jeff Bishop wrote:
<blockquote cite="mid:fusnbj$qes$1@build.eclipse.org" type="cite">
<pre wrap="">What does everyone think about using 3.4m6? </pre>
</blockquote>
It's extremely rare for an integration build to have problems that make
it unusable.<br>
<pre wrap="">Do you think it is a pretty
stable release even though it is a beta? </pre>
</blockquote>
packages if you need plugins other than just the bare Eclipse ones:<a
href="http://www.eclipse.org/downloads/packages/"><br>
</a>
<blockquote><a href="http://www.eclipse.org/downloads/packages/">http://www.eclipse.org/downloads/packages/</a><br>
</blockquote>
<pre wrap=""> Can one simply unzip the eclipse
and overwrite the Eclipse already installed? </pre>
</blockquote>
Put it in a new place. Keep the old one around in case you have
problems and you'll be able to go back to using it.<br>
<pre wrap=""> What has changed in that
release?
</pre>
</blockquote>
generator, I need to apply those changes to the project in the
workspace I'm already working on...<br>
<pre wrap="">
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fushn9$8lt$1@build.eclipse.org">news:fushn9$8lt$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Jeff,
Comments below.
Jeff Bishop wrote:
</pre>
<pre wrap="">Hello Everyone,
to work in Eclipse.
d:\tij\code
structure.
import java.util.*;
print(new Date());
print class.
d:\tij\code
</pre>
</blockquote>
<pre wrap="">Until 3.4M6, Java didn't properly support external folder on the
to that.
</pre>
<pre wrap="">Same issue.
It resolved to:
net.mindview.util.
</pre>
</blockquote>
<pre wrap="">I'd recommend trying to set up the tij/code thing as a project so that you
</pre>
<pre wrap="">
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------000908010508000209020905--
Re: classpath not working ... [message #256077 is a reply to message #254754] |
Sun, 11 May 2008 12:50   |
I recently set up Europa and could not get the $CLASSPATH to work in the
IDE as it does in the command line...
I figured I could set up a CLASSPATH variable, select it for a project,
and Europa would look for *.class files in $CLASSPATH + (import path).
When trying to select a CLASSPATH variable, Europa says it can't be
selected because its value is a folder... isn't that what a CLASSPATH
variable supposed to do? I realize that the tail end of the CLASSPATH
variable should contain something executable... I think, because it's
called CLASS"PATH", it's easy to confuse it with containing just a path
instead of a path with an executable at its tail.
Anyway, I moved up to Ganymede M6 after reading this thread, and
assigning a CLASSPATH variable to a project does work... as long as the
*.class files are already in the imported path... ie if there is no
class file in the imported path, Ganymede produces an error.
Normally, the Java compiler will regenerate the class file, even the
imported class files, if the source is present. Is there a way of making
Ganymede do this?
Richard
Eric Rizzo wrote:
>> pretty stable release even though it is a beta? Can one simply unzip
>> the eclipse and overwrite the Eclipse already installed? What has
>> changed in that release?
> The Milestone builds (especially the later ones like M5, M6, and M7)
> have a long track record of stability, going back to the Eclipse 2.1
> days. I have no problem using them, personally.
> As for what has changed, that is a long answer. Start with this page
> http://download.eclipse.org/eclipse/downloads/drops/S-3.4M6- 200803301350/eclipse-news-M6.html
> and also follow all the links at the bottom of the page to earlier
> milestone builds.
> Hope this helps,
> Eric
Re: classpath not working ... [message #256104 is a reply to message #256077] |
Mon, 12 May 2008 09:59   |
> Ganymede do this?
It is not clear what your end goal is. It is fairly clear, however, that
you are unclear about build paths in Eclipse - it is not the same as or
similar to using javac on the command line. To begin with, Eclipse does
NOT use the system CLASSPATH variable in any way. In Eclipse, each
project has its own independent Build Path.
You seem to have discovered Classpath Variables, which are a convenient
way for projects to refer to external JARs or directories that might
differ between different machines (for example, if you and I were
working on the same projects that depended on a certain library but we
had that library installed in different locations on our machines). But
Classpath Variables are of limited use (IMO) because it is usually
better to contain all necessary libraries in the project itself or in a
special "Libs" project that other projects depend on. I always recommend
against referring to JARs that are assumed to exist somewhere on a
development file system, even though Classpath Variables make that a
little easier to manage.
If you describe your end-goal I'm sure we can provide specific advice on
how to set it up in Eclipse. Better yet, you can read the "Project
Configuration" tutorial that is in the Eclipse Help (under section Java
Development User Guide, Getting Started) - that will help you understand
the fundamentals of project set-up.
Hope this helps,
Eric
Re: classpath not working ... [message #256372 is a reply to message #256104] |
Wed, 14 May 2008 15:45  |
>> Ganymede do this?
> Hope this helps,
> Eric
You are correct, Eric. I was under the impression that the CLASSPATH
variables in Eclipse served the same purpose as the CLASSPATH variable
in javac. The names look the same.. I guess the "duck" rule does not
apply.
Thanks for the advice.. I'll go to the tutorial and learn the
distinctions between Eclipse and javac CLASSPATH vars. Just when you
think you've got it, alas there's always something new.
BTW, my goal was to make the CLASSPATH var in Eclipse give me the the
same behavior as the CLASSPATH var in javac.
Richard
Current Time: Fri Jul 18 01:53:27 EDT 2025
Powered by FUDForum. Page generated in 0.29752 seconds
