Home » Language IDEs » Java Development Tools (JDT) » Double-click to set breakpoint?
Double-click to set breakpoint? [message #254471] Tue, 01 July 2008 16:24 Go to next message
Has something intentionally changed in 3.4 so that you can no longer
toggle a breakpoint by double-clicking in the annotation area to the
left of the code in the Java editor? I don't remember seeing anything in
the New & Noteworthy about it, but perhaps I missed something...
Eric
Re: Double-click to set breakpoint? [message #254476 is a reply to message #254471] Tue, 01 July 2008 16:35 Go to previous messageGo to next message
Eric,
Dbl clicking to toggle a breakpoint is working for me in 3.4
Darins
http://runnerwhocodes.blogspot.com
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:g4e3qk$uie$1@build.eclipse.org...
> toggle a breakpoint by double-clicking in the annotation area to the left
> of the code in the Java editor? I don't remember seeing anything in the
> Eric
Re: Double-click to set breakpoint? [message #254480 is a reply to message #254476] Tue, 01 July 2008 22:33 Go to previous messageGo to next message
Darin Swanson wrote:
> Eric,
That's not what I wanted to hear - now I have to narrow it down instead
of just being lazy and complaining ;-)
Here's the exception from Error Log whenever I try to toggle a
breakpoint via double-click. Is this enough for a Bugzilla? It doesn't
seem like it...
null
Error
Tue Jul 01 22:31:57 EDT 2008
Unhandled event loop exception
org.eclipse.ui.actions.ContributedAction.runWithEvent(Contri butedAction.java:181)
at org.eclipse.ui.internal.actions.CommandAction.run(CommandAct ion.java:171)
org.eclipse.ui.texteditor.AbstractTextEditor$14.triggerActio n(AbstractTextEditor.java:2890)
org.eclipse.ui.texteditor.AbstractTextEditor$14.mouseDoubleC lick(AbstractTextEditor.java:2915)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:183)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
>> Eric
Re: Double-click to set breakpoint? [message #254484 is a reply to message #254471] Wed, 02 July 2008 03:20 Go to previous messageGo to next message
It happened to me for one class once... I couldn't understand why, but
after trying to set another breakpoint on another class, it worked, so I
thought it might have been because of Eclipse coulnd't set the
breakpoint on the first class (it was in a third-party library for which
I had the source, but I didn't know how it was compiled). Anyway, it
sounded strange to me because Eclipse didn't give any warning or error
message and because when debugging I could see the full stack traces
(with line numbers) for that class, too.
Mauro.
Re: Double-click to set breakpoint? [message #254488 is a reply to message #254480] Wed, 02 July 2008 03:27 Go to previous messageGo to next message
>> Eric,
> instead of just being lazy and complaining ;-)
> seem like it...
Could be a corrupt install. Can you try with a new install (Into a new
directory)? Also, does it always happen? If you can reproduce with the
fresh install then please file a bug report with the steps to reproduce
the NPE.
Dani
> null
> Error
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
>>> anything in the New & Noteworthy about it, but perhaps I missed
>>> something...
>>> Eric
Re: Double-click to set breakpoint? [message #254521 is a reply to message #254488] Wed, 02 July 2008 10:38 Go to previous messageGo to next message
Daniel Megert wrote:
>>> Eric,
>> seem like it...
> the NPE.
I just installed yesterday. I added the Mylyn JIRA connector and JET
0.8, but other than that it is the RCP/Plugin Dev package.
It happens on all classes, both source in projects and libraries. I'll
try restarting and if it persists I'll enter a bug.
Eric
Re: Double-click to set breakpoint? [message #254541 is a reply to message #254521] Wed, 02 July 2008 13:40 Go to previous messageGo to next message
>>>> Eric,
>>> doesn't seem like it...
>> reproduce the NPE.
Restarting Eclipse seems to have worked. Wish I could do more to track
it down, but its gone now.
Would there be any use in entering a bug report with the NPE stack trace
alone? Perhaps the code in that stack could be cleaned up to avoid such
problems in general...?
Eric
Re: Double-click to set breakpoint? [message #254627 is a reply to message #254541] Wed, 02 July 2008 14:34 Go to previous messageGo to next message
news:g4gehv$ua1$2@build.eclipse.org...
>>>>> Eric,
>>>> seem like it...
>>> the NPE.
>> I just installed yesterday. I added the Mylyn JIRA connector and JET 0.8,
> Restarting Eclipse seems to have worked. Wish I could do more to track it
> Eric
I would log it against Platform UI so that ContributedAction can get a
review for the problem
Darins
Re: Double-click to set breakpoint? [message #254632 is a reply to message #254627] Wed, 02 July 2008 15:14 Go to previous message
Entered https://bugs.eclipse.org/bugs/show_bug.cgi?id=239317
>>>>>> Eric,
>>>>> seem like it...
>>>> the NPE.
>> Eric
> Thanks
> Darins
Previous Topic:Debugging suddenly became very slow
Next Topic:How to listen for "Javadoc location" change
Current Time: Tue Jul 22 13:06:53 EDT 2025
Powered by FUDForum. Page generated in 0.04071 seconds
