Home » Eclipse Projects » Eclipse Platform » Bracket Highlighting
Bracket Highlighting [message #254402] Mon, 21 June 2004 17:17 Go to next message
Originally posted by: strykeleader.hotmail.com
When you have bracket highlighting on, and it highlights beginning or ending
braces and parentheses in the Java editor, what is the actual editor plug-in
doing to perform the highlighting (not the JavaPairMatcher, since that's
only locating the braces), i.e. is it some widget or graphic tool thing to
make the box outline appear, and if so how could I employ this or something
similar to it for a different purpose?
- Parhaum
Re: Bracket Highlighting [message #254412 is a reply to message #254402] Mon, 21 June 2004 18:02 Go to previous messageGo to next message
> - Parhaum
I wrote an editor where i define my bracket highliting,
you need a MatchingCharacterPainter and you have to implement
a class : SomePairMatcher implements ICharacterPairMatcher
where you say what you want to match with highlighting.
Here is an example :
public class SomeEditor extends TextEditor {
protected PaintManager fPaintManager;
protected MatchingCharacterPainter fBracketPainter;
protected boolean isBracketHighlightingEnabled() {
return true;
private void startBracketHighlighting() {
if (fBracketPainter == null) {
fBracketPainter = new
MatchingCharacterPainter(fSourceViewer,new SomePairMatcher());
fBracketPainter.setColor(new Color(Display.getCurrent(), new RGB(
127, 0, 85)));
fPaintManager.addPainter(fBracketPainter);
protected void createActions() {
super.createActions();
fPaintManager = new PaintManager(fSource);
if (isBracketHighlightingEnabled()) {
startBracketHighlighting();
private void stopBracketHighlighting() {
if (fBracketPainter != null) {
fPaintManager.removePainter(fBracketPainter);
fBracketPainter.deactivate(true);
fBracketPainter.dispose();
fBracketPainter = null;
and it works.
Re: Bracket Highlighting [message #254733 is a reply to message #254412] Tue, 22 June 2004 13:17 Go to previous messageGo to next message
Would something like this work if I wanted to just highlight different
things? I.e. I don't want to do any pair anything highlighting, I just want
a way to change graphical appearances around characters and such without
affecting the code itself, and the bracket highlighting seems to relate to
that. I wanted to know if there's something (JFace, SWT, etc) that has
different editor window effects.
- Parhaum
"LIM erwin" <erwin@freesurf.fr> wrote in message
news:cb7lsk$c0l$1@eclipse.org...
ending
plug-in
to
something
> > - Parhaum
> return true;
> 127, 0, 85)));
> and it works.
Re: Bracket Highlighting [message #254869 is a reply to message #254733] Wed, 23 June 2004 03:40 Go to previous message
You could use Annotations - this is what's used to do the occurrences
highlighting and linked editing boxes.
See the org.eclipse.ui.editors.markerAnnotationSpecification extension
point to see how to contribute custom annotations.
-tom
> - Parhaum
> ending
> plug-in
> to
> something
>>>- Parhaum
>> return true;
>> 127, 0, 85)));
>>and it works.
Previous Topic:Package updater fails consistently
Next Topic:mark occurences broken in rc3?
Current Time: Mon Jul 21 23:57:36 EDT 2025
Powered by FUDForum. Page generated in 0.10436 seconds
