| Why the code didn't be modified? [message #254300] |
Fri, 27 June 2008 07:48   |
Eclipse User  |
Originally posted by: upupsky.gmail.com
Hi, all,
I want to insert a statement into every IfStatement, For example, the
original code is like:
public class Test{
 public void test{
  if(true){
    String str="";
After insertion, the modified code is like:
public class Test{
 public void test{
  if(true){
    System.out.println("Hello"+" world");
    String str="";
I want to know why the code is not modified after calling modify(Block);
and what should I do to save the modification to file?
Below is my code:
package change;
import org.eclipse.jdt.core.dom.*;
import org.eclipse.jdt.core.dom.rewrite.ASTRewrite;
import org.eclipse.jdt.core.dom.rewrite.ListRewrite;
import org.eclipse.jface.text.*;
import org.eclipse.text.edits.MalformedTreeException;
import org.eclipse.text.edits.TextEdit;
import org.eclipse.text.edits.UndoEdit;
 * This class insert a statement into the source code. For example, the
original
 * code is like:
 * <p>
 * public class Test{ public void test{ if(true){String str="";} } }
 * </p>
 * After insertion, the modified code is like:
 * <p>
 * public class Test{ public void test{ System.out.println("Hello"+"
world");
 * if(true){String str="";} } }
 * </p>
 * @author Zhang Yu
public class Inserter {
	private ASTParser parser;
	private Document doc = null;
	private CompilationUnit unit = null;
	 * Creates a new Inserter instance.
	 * <p>
	 * </p>
	 * @param content
	 *            the source code to handle
	public Inserter(String content) {
		parser = ASTParser.newParser(AST.JLS3);
		parser.setSource(content.toCharArray());
		parser.setKind(ASTParser.K_COMPILATION_UNIT);
		doc = new Document(content);
		unit = (CompilationUnit) parser.createAST(null);
		unit.recordModifications();
	 * Visits the CompilationUnit.
	 * <p>
	 * Find every IfStatement and then change it
	 * </p>
	public void visit() {
		unit.accept(new ASTVisitor() {
			public boolean visit(IfStatement node) {
				Statement s = node.getThenStatement();
				if (s instanceof Block)
					modify((Block) s);
				return false;
	 * Creates a new expression statement node owned by this AST
	 * @param ast
	 * @return ExpressionStatement System.out.println("Hello"+ "world").
	public Statement createStmt(AST ast) {
		MethodInvocation methodInvocation = ast.newMethodInvocation();
		QualifiedName name = ast.newQualifiedName(ast.newSimpleName("System"),
				ast.newSimpleName("out"));
		methodInvocation.setExpression(name);
		methodInvocation.setName(ast.newSimpleName("println"));
		InfixExpression infixExpression = ast.newInfixExpression();
		infixExpression.setOperator(InfixExpression.Operator.PLUS);
		StringLiteral literal = ast.newStringLiteral();
		literal.setLiteralValue("Hello");
		infixExpression.setLeftOperand(literal);
		literal.setLiteralValue(" world");
		infixExpression.setRightOperand(literal);
		methodInvocation.arguments().add(infixExpression);
		ExpressionStatement expressionStatement = ast
				.newExpressionStatement(methodInvocation);
		return expressionStatement;
	 * Change the block by inserting an Statement
	 * @param block
	 *            the block to modify
	public void modify(Block block) {
		AST ast = block.getAST();
		ASTRewrite rewrite = ASTRewrite.create(unit.getAST());
		Statement newStmt = createStmt(ast);
		ListRewrite statementsListRewrite = rewrite.getListRewrite(block,
				Block.STATEMENTS_PROPERTY);
		int index = 0;
		statementsListRewrite.insertAt(newStmt, index, null);
		String code = applyModify();
		System.out.println("Code after modification:\n" + code);
	 * Apply the change and return the new source code
	 * @return the modified source code
	public String applyModify() {
		// Apply the rewrite, and get the output
		TextEdit edits = unit.rewrite(doc, null);
		try {
			UndoEdit undo = edits.apply(doc);
		} catch (MalformedTreeException e) {
			e.printStackTrace();
		} catch (BadLocationException e) {
		String code = doc.get();
		save();
		return code;
	 * Save the modified source code
	 * <p>
	 * What should I do to save the modification to file
	 * </p>
	public void save() {
		String CODE_START = "public class Test {\n public void Test(){\n";
		String CODE_END = "\n }\n}";
		String CODE = "    if(true){String str=\"\";}";
		String content = CODE_START + CODE + CODE_END;
		System.out.println("The original code:\n" + content);
		Inserter jp = new Inserter(content);
		jp.visit();
| Re: Why the code didn't be modified? [message #254443 is a reply to message #254300] |
Tue, 01 July 2008 09:18   |
Eclipse User  |
Let me reply to myself. :)
I found out that if the applyModify() is like below, then the code would
be modified:
TextEdit textEdits = rewrite.rewriteAST(doc, null);
try {
	textEdits.apply(doc);
Although I can't see the difference, but it works.
FUDForum. Page generated in 0.04901 seconds
