Internation chars become ? after saved/closed and reopened [message #25084] |
Wed, 30 April 2003 17:15  |
Originally posted by: emerson.tre-sc.gov.br
I'm using Suse 8.1 linux and eclipse 2.1 final release GTK.
Sometime ago i post a question about using portuguese chars in motif
version (eg: çéá, if you can see :), becouse i caouldn't type these
kind of chars. I solved this changing to GTK version. A while ago I
noticed that as the typing was working all right, when the file is saved,
closed and reopened, the portuguese chars became all '?' char. ANd i hate
using those "Ó" char's, what is terrible :)
Does anyone had this problem before or could help me on that???
Thanks in advance
Emerson Cargnin
Re: Internation chars become ? after saved/closed and reopened [message #27594 is a reply to message #25208] |
Mon, 05 May 2003 13:38  |
it appears that locale is not configured. when i typed locale it gave me :
LANG=POSIX
LC_CTYPE="POSIX"
LC_NUMERIC="POSIX"
LC_TIME="POSIX"
LC_COLLATE=POSIX
LC_MONETARY="POSIX"
LC_MESSAGES="POSIX"
LC_PAPER="POSIX"
LC_NAME="POSIX"
LC_ADDRESS="POSIX"
LC_TELEPHONE="POSIX"
LC_MEASUREMENT="POSIX"
LC_IDENTIFICATION="POSIX"
LC_ALL=
thanks veronika, i should have search a little bit more : )
other maybe related problem :
when using replace Ant task, it looses the special chars, unless i use
explicitly the encoding="iso-8859-1" property in each replace task, is
there a way to get it done without it?
and thanks for your reply.
Emerson
Veronika Irvine wrote:
> Sounds like an encoding problem when the file saved.
> Try the following:
> 1)In a shell, type 'locale' to see what the encoding is in the OS
> 2) In eclipse, there are two places where the enconding is set.
> Check Window -> Preferences -> Workbench -> Editors
> Check Edit-> Encoding
> ISO-8859-1 or Latin1 should work for Portuguese.
> "Emerson Cargnin" <emerson@tre-sc.gov.br> wrote in message
> news:b8pedu$orb$1@rogue.oti.com...
> > using those "Ã" char's, what is terrible :)
> > Thanks in advance
> > Emerson Cargnin
FUDForum. Page generated in 0.24478 seconds
