How to ignore @Override under 1.4? [message #254274] |
Fri, 18 April 2008 14:12  |
Originally posted by: fake.phony_email_address.com
We've got a lot of code that uses @Override tags, and we need it to
compile under JDK 1.4. They cause compile errors. I'd rather not remove
the tags because they're really useful under 1.5.
Is there any way in Eclipse Preferences to temporarily ignore the
@Override tags when compiling under 1.4?
Re: How to ignore @Override under 1.4? [message #254299 is a reply to message #254287] |
Sat, 19 April 2008 07:25   |
--------------090705050708090206010303
Wayne,
I think the .class file compatibility must be greater or equal to the
source compatibility... It would be nice if Java could compile 1.5
level source down to 1.4 compatible byte code...
Wayne Beaton wrote:
> Try setting the compiler level to 1.6, but the "generated .class files
> compatibility" to 1.4
> Wayne
<html>
<head>
</head>
Wayne,<br>
<br>
level source down to 1.4 compatible byte code...<br>
<br>
<br>
Wayne Beaton wrote:
<blockquote cite="mid:1208551584.6093.98.camel@BADWOLF" type="cite">
<pre wrap="">Try setting the compiler level to 1.6, but the "generated .class files
Wayne
</pre>
<blockquote type="cite">
<pre wrap="">We've got a lot of code that uses @Override tags, and we need it to
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------090705050708090206010303--
Re: How to ignore @Override under 1.4? [message #254316 is a reply to message #254312] |
Sat, 19 April 2008 11:34   |
Well not at all if I read the document i referenced there appropiately
what the compiler does is simply adding casts inside the byte-code. This
could also be a pointer for our Java-5 discussion on the e4 mailinglist.
Tom
Ed Merks schrieb:
> Tom,
> Interesting. I suppose that doesn't mean it tosses generics away if you
> use them, which would be an interesting capability...
> Tom Schindl wrote:
>> Hi Ed,
>> It can some if you are using only things compatible with Java-1.4.
>> See http://dev.eclipse.org/newslists/news.eclipse.tools.jdt/msg2 0212.html
>> Tom
>> Ed Merks schrieb:
>>> Wayne,
>>>> Wayne
>>>>> remove the tags because they're really useful under 1.5.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: How to ignore @Override under 1.4? [message #254348 is a reply to message #254299] |
Sun, 20 April 2008 14:42  |
Thanks Ed. I was too lazy to try it myself; however, the properties let
you do this, so I thought it was worth a crack.
Wayne
On Sat, 2008-04-19 at 07:25 -0400, Ed Merks wrote:
> Wayne,
> > Wayne
FUDForum. Page generated in 0.66338 seconds
