Home » Eclipse Projects » Eclipse Platform » TreeItems
TreeItems [message #254217] Mon, 21 June 2004 08:52 Go to next message
Originally posted by: JWessling.gmx.de
Hi.
How can i expand TreeItems?
The tree is filled correct, there is a cross next to the Element that
has children, I get the TreeEvent that shows that the tree will be
expanded, but I don't see it. I tried in the treeExpanded-method
to update or redraw the tree. I set the item to setExpanded(true)
and I tried tree.showItem() for every item that is hierachily under
my expanded item, but the only thing happen, is that the cross beside my
item disappears.
Jan
Re: TreeItems [message #254369 is a reply to message #254217] Mon, 21 June 2004 15:22 Go to previous messageGo to next message
Jan Wessling schrieb:
> Hi.
> has children,
At least on Windows, a tree item also has a plus sign if the tree does
not yet know if there are children.
> item disappears.
Sounds exactly like having no child and the plus sign disappearing when
the tree knows about it after the unsuccessful try to show then children.
So please check your code if you _really_ add children to the item.
Ciao, Michael.
Re: TreeItems [message #254506 is a reply to message #254369] Tue, 22 June 2004 04:27 Go to previous message
>> Hi.
>> has children,
>> item disappears.
When debugging and examining the tree, the treeitems are added under the
top-level items. But when the event appears, the tree only has the
top-level elements. I tried out to make the tree more global, but the
same happens as described above.
CU
Jan
> Ciao, Michael.
Previous Topic:custom close dialog for an editor
Next Topic:test
Current Time: Thu Jul 17 23:52:20 EDT 2025
Powered by FUDForum. Page generated in 0.03117 seconds
