Home » Newcomers » Newcomers » Menu Image
Menu Image [message #254115] Thu, 17 April 2008 07:32 Go to next message
Originally posted by: andymorton.btinternet.com
Hi.
I am dynamically creating a context/popup menu whenever I startup.
It creates a menu item, with a dynamic amount of sub menus.
All is well with the menu, but I want to be able to put an image on the
menu, and not the sub menus.
Currently the code is like this:
final MenuManager menuDynamic = new
MenuManage(PrefConstants.TEMPLATE_MENU_NAME,null);
menuDynamic.add(new Action(PrefConstants.TEMPLATE_MENU_FAKE){});
menuDynamic.setRemoveAllWhenShown(true);
<--- I want to set the image on the menuDynamic object around here....
while (items)
....//add children
Is this possible to do?
Andrew
Re: Menu Image [message #254127 is a reply to message #254115] Thu, 17 April 2008 09:05 Go to previous messageGo to next message
What are you hoping to see? "image on the menu" doesn't make any sense
to me" You can put an image on a menu item (Action), but not on a menu
itself.
Wayne
On Thu, 2008-04-17 at 11:32 +0000, Andrew Morton wrote:
> Hi.
> while (items)
> ...//add children
> Andrew
Re: Menu Image [message #254131 is a reply to message #254127] Thu, 17 April 2008 09:27 Go to previous messageGo to next message
Wayne,
Apologies for the confusion.
My context menu contains a parent, for example, 'Mortys Menu'.
I have added several actions to this as children, for example 'Do This'
and 'Do That'.
I want to place an icon beside the text 'Mortys Menu' in the context menu.
Again apologies for the confusion.
Andrew
Re: Menu Image [message #254243 is a reply to message #254131] Fri, 18 April 2008 10:53 Go to previous message
I poked around a bit and, sadly, my answer at this point is
"dunno" (though, after a quick review of some of the menus in the
Eclipse IDE, it seems possible).
I recommend moving this question to the eclipse.platform newsgroup;
somebody there may have an answer.
HTH,
Wayne
On Thu, 2008-04-17 at 13:27 +0000, Andrew Morton wrote:
> Wayne,
> and 'Do That'.
> Andrew
Previous Topic:.properties file format
Next Topic:TIFF FORMATS
Current Time: Fri Jul 18 22:23:37 EDT 2025
Powered by FUDForum. Page generated in 0.10455 seconds
