Home » Archived » BIRT » Apply a filter on a CHART after grouping is applied to X-Axis
Apply a filter on a CHART after grouping is applied to X-Axis [message #254111] Fri, 31 August 2007 17:24
Originally posted by: asdf.asdf.com
Hello Experts,
The following is an example of a combination chart where the filter is
applied to select topN customers , I would like to apply a similar filter
to the chart/dataset after the grouping on X Axis is applied , basically
the grouping is applied on XAxis to avoid the dupilicate labels on XAxis.
Is there any way to determine the length of the runtime series of a hart X
-Axis using API and take actions based on that , any ideas would be
greatly appreciated.
The following is an example using the designer to apply the filter, no
grouping on X Axis is done here.
http://www.eclipse.org/birt/phoenix/examples/reports/birt2.1 /combochart/index.
php
-Khan
Previous Topic:Table Of Contents as a report item
Next Topic:Wrapping text in data field
Current Time: Fri Jul 18 20:55:42 EDT 2025
Powered by FUDForum. Page generated in 0.03281 seconds
