Home » Language IDEs » Java Development Tools (JDT) » Finding java.lang.String
Finding java.lang.String [message #254088] Thu, 19 June 2008 08:48 Go to next message
Hi Folks,
I'm failing to resolve java.lang.String as an IType using the
IJavaProject.findType(String)
method. When I pass in "java.lang.String", the result is null. I have
the same problem with other standard JDK types, but not with
user-defined types on the project's classpath. Is this working as
designed? The javadoc claims it will locate any type on the project's
class path. Are the JDK's runtime JARs not considered part of the
project's classpath?
- Paul
Re: Finding java.lang.String [message #254093 is a reply to message #254088] Thu, 19 June 2008 10:39 Go to previous message
Paul Glezen wrote:
> Hi Folks,
> - Paul
Paul,
What does IJavaProject.gerResolvedClasspath(true) return?
Is rt.jar included in the resulting classpath?
If not, then it looks like the project's classpath was not correctly
set up and it will not find "java.lang.String".
Jerome
Previous Topic:Modify the grammar of java
Next Topic:renaming behavior is strange for classes
Current Time: Thu Jul 24 11:14:42 EDT 2025
Powered by FUDForum. Page generated in 0.12105 seconds
