Home » Newcomers » Newcomers » Eclipse and Ivy plugin
Eclipse and Ivy plugin [message #253863] Mon, 14 April 2008 11:13
Originally posted by: jp_york.hotmail.com
For anyone one out there using the plugin for ivy in eclipse I was
wonderingif you have come across the following issue and might have a fix?
When I have multiple projects open in eclipse and I change a jar file in
oneof my ivy.xml files, that change is made to all projects even though I
don'twant that. Example would be we upgraded from reportmill7.jar
toreportmill8.jar and I only wanted to do this for one project as the
otherswere still setup to use the reportmill7.jar. When I made the change
to theone project, the others were changed and I got a bunch of errors.
I just can't seem to get the projects to use there own ivy.xml files.
Previous Topic:unable to run 3.3.0
Next Topic:Default run target, desired run behavior
Current Time: Fri Jul 18 07:28:29 EDT 2025
Powered by FUDForum. Page generated in 0.10717 seconds
