Home » Archived » BIRT » Viewing a Chart with birt 2.2
Viewing a Chart with birt 2.2 [message #253645] Tue, 28 August 2007 03:04
I have a report that contains a chart that works with Birt 2.1.2. When I
try to use this report item using the Birt 2.2 runtime to
render a report I get the following error.
org.eclipse.birt.report.engine.executor.ExecutorManager$Exec utorFact
ory.visitExtendedItem(ExecutorManager.java:274)
org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept( Extended
ItemDesign.java:37)
ory.createExecutor(ExecutorManager.java:246)
org.eclipse.birt.report.engine.executor.ExecutorManager.crea teExecut
or(ExecutorManager.java:196)
org.eclipse.birt.report.engine.executor.ReportExecutor.getNe xtChild(
ReportExecutor.java:114)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportE
xecutor.getNextChild(WrappedReportExecutor.java:64)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM$1.getN extChild
(HTMLPageLM.java:59)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children
(HTMLPageLM.java:125)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPag
eLM.java:84)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.la
yout(HTMLReportLayoutEngine.java:90)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAn
dRenderTask.java:148)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndR
enderTask.java:71)
Any ideas.
Any help would be appreciated.
Cheers
Louise
Previous Topic:Viewing a Chart with birt 2.2
Next Topic:Problem in Pie Chart(Urgent)
Current Time: Sun Jul 27 18:09:22 EDT 2025
Powered by FUDForum. Page generated in 0.02803 seconds
