PDE Build problem: NPE when test fail [message #253380] |
Wed, 16 June 2004 15:12  |
I have been experiencing this problem for quite a while (it was not
happening 1 or 2 months ago). Whenever a JUnit test fails, I am getting a
NPE as indicated below. I've been always using the latest integration
driver and the HEAD version of org.eclipse.releng.basebuilder in my builds.
Note: The html file generated for the test is OK.
Does anyone have any tip I could use to fix this?
generateIndex:
[indexResults] Begin: Generating test results index page
[indexResults] Parsing XML files
BUILD FAILED
org.eclipse.releng.generators.ErrorTracker.registerError(Err orTracker.java:1
66)
org.eclipse.releng.generators.TestResultsGenerator.parseXml( TestResultsGener
ator.java:303)
org.eclipse.releng.generators.TestResultsGenerator.execute(T estResultsGenera
tor.java:130)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:269)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:301)
at org.apache.tools.ant.Target.performTasks(Target.java:328)
at org.apache.tools.ant.Project.executeTarget(Project.java:1215 )
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:383)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:107)
at org.apache.tools.ant.Project.executeTargets(Project.java:106 3)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.ja
va:633)
va:539)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:488)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:334)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:272)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:128)
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
FUDForum. Page generated in 0.03520 seconds
