Home » Newcomers » Newcomers » Auto file refresh
Auto file refresh [message #253021] Thu, 03 April 2008 09:05 Go to next message
Kinda a newbie question - I'm new to Europa...
When I open a file that's been changed in the file system (nearly always
when it's been checked out of source control) I get a message saying that
the resource is out of sync with the file system, and I have to refresh
it. I've checked "refresh automatically" in
Window->Preferences->Workspace but that doesn't appear to be working for
me (it used to in 3.1.2). Are there any logs I can check or things I can
test to try and work out what's going wrong?
Cheers
James
Re: Auto file refresh [message #253029 is a reply to message #253021] Thu, 03 April 2008 09:18 Go to previous messageGo to next message
James,
The Error Log view will show logged problems. It shows the contents of
<workspace>/.metadata/.log. I think the auto refresh is done as the IDE
gains focus so if the change is happening without the IDE losing and
regaining focus, the refresh might not be done. I'm not sure about that
though...
> always when it's been checked out of source control) I get a message
> saying that the resource is out of sync with the file system, and I
> have to refresh it. I've checked "refresh automatically" in
> for me (it used to in 3.1.2). Are there any logs I can check or
> things I can test to try and work out what's going wrong?
> Cheers
> James
Re: Auto file refresh [message #253036 is a reply to message #253029] Thu, 03 April 2008 09:42 Go to previous messageGo to next message
Ed
Thanks. Unfortunately nothing appears in the error log, and the IDE's
definitely losing focus. Is there anything else you can think of I can
try? It's not a huge problem, but it is very annoying!
Cheers
James
Re: Auto file refresh [message #253044 is a reply to message #253036] Thu, 03 April 2008 09:50 Go to previous messageGo to next message
James,
Other than opening a bugzilla, I can't think of anything else to try.
And likely it wouldn't be fixed in a maintenance stream (it's annoying
not show stopping) so the question of whether it fails in 3.4 would come
up. Is some type of mounted file system involved? Sometimes such
things can have issues with timestamp anomalies...
James wrote:
> Ed
> can try? It's not a huge problem, but it is very annoying!
> Cheers
> James
Re: Auto file refresh [message #253048 is a reply to message #253044] Thu, 03 April 2008 10:01 Go to previous message
Ed
Yes, it is mounted (source is kept on a Solaris machine using SCCS,
development is done on a windows box), though I'm pretty sure the times
are synchronized on login and this has lasted a few days.
As you say, it's annoying but not fatal. As it's bugging me I guess I'll
download 3.4 and see what happens...
Thanks for your help
James
Previous Topic:Browsing all packages in the workspace
Next Topic:Plugin Runtime classpaths in 3.3
Current Time: Fri Jul 25 21:18:57 EDT 2025
Powered by FUDForum. Page generated in 0.07976 seconds
