Home » Eclipse Projects » DTP » SQL Editor using an Oracle Connection
SQL Editor using an Oracle Connection [message #24920] Fri, 05 January 2007 04:00 Go to next message
I'm using dtp 1.0 with an Oracle 10 database. I'm able to explore the
schemas and other objects in the database in the Datasource Explorer and
I can run several statements.
But follwing features seam not to work:
- Stored Procedures cannot be opened or edited: The editor says 'Failed
to get source' (not entries in the eclipse log)
- In the sql editor tables, columns or other database objects are never
proposed by the content assist
How can I avoid these problems?
Kind regards,
Stefan
Re: SQL Editor using an Oracle Connection [message #25190 is a reply to message #24920] Wed, 10 January 2007 03:22 Go to previous messageGo to next message
Stefan Holzknecht wrote:
> Kind regards,
> Stefan
I forget to say that other features cannot be used either. Eg. I'm
unable to specify schema filters based on a selection when editing
properties of a database. I remember a M? build with which I got a list
of all schemas to choose from here.
Probably the wrong behaviour is connected to the fact that the method
org.eclipse.datatools.sqltools.sql.util.ModelUtil.getSchemas (Database,
String) is called with a catalog name null (while debugging the content
assist invokes this in SQLDBProposalsService.loadDBProposals(). The
field SQLDBProposalsRequest._database is set to null.). The database
name is set as default catalog name. It seams to me that the empty
string is a better solution here (at least the Database object contained
a proper filled catalog with empty name).
This information probably helps in order to provide a better working sql
editor.
Stefan
Re: SQL Editor using an Oracle Connection [message #25269 is a reply to message #25190] Wed, 10 January 2007 21:53 Go to previous message
Originally posted by: hcao.sybase.com
Hi Stefan,
Please see the inline comments below:
Max (Hui) Cao
Sybase Inc.
"Stefan Holzknecht" <s.holzknecht@intershop.de> wrote in message
news:eo27hv$t9j$1@utils.eclipse.org...
The generic catalog loader can't load the stored procedure source for you
since it's dependent on the JDBC api. You'll have to create your own catalog
loader for Oracle.
The generic sql parser does not help much in this case. A fully-fledged
content assist feature needs the support of a customized parser. But I agree
there's something to improve, like the ModelUtil.getSchemas() method you
mentioned below.
>> Kind regards,
>> Stefan
> I forget to say that other features cannot be used either. Eg. I'm unable
> to specify schema filters based on a selection when editing properties of
> a database. I remember a M? build with which I got a list of all schemas
The schema filter function is hosted in the connectivity project and I don't
know the details.
> assist invokes this in SQLDBProposalsService.loadDBProposals(). The field
> SQLDBProposalsRequest._database is set to null.). The database name is set
> as default catalog name. It seams to me that the empty string is a better
> solution here (at least the Database object contained a proper filled
> editor.
This is a good suggestion, I'v created BZ170153 for it. Thanks!
> Stefan
Re: SQL Editor using an Oracle Connection [message #583852 is a reply to message #24920] Wed, 10 January 2007 03:22 Go to previous message
> Kind regards,
> Stefan
editor.
Stefan
Re: SQL Editor using an Oracle Connection [message #583882 is a reply to message #25190] Wed, 10 January 2007 21:53 Go to previous message
Hi Stefan,
Max (Hui) Cao
Sybase Inc.
loader for Oracle.
mentioned below.
>> Kind regards,
>> Stefan
know the details.
> editor.
> Stefan
Previous Topic:Executing SQL programmatically
Next Topic:DTP 1.0: Connection profiles don't get saved between Eclipse sessions?
Current Time: Fri Jul 18 00:15:32 EDT 2025
Powered by FUDForum. Page generated in 0.08330 seconds
