Home » Archived » BIRT » Birt Doesn't allow null parameter
Birt Doesn't allow null parameter [message #252754] Thu, 16 August 2007 11:21 Go to next message
Originally posted by: kale.anuradha.gmail.com
Hi All,
I created one text parameter and checked the box "Allow null value". I
also checked the box "Allow blank values".
When I try to preview this report/ view this report as HTML/PDF, then I get
the following error if I select the radio button "null value" in the "Enter
Parameter" dialog box.
Please let me know if I am missing something.
Error :
The following items have errors:
Table Detail:
- Default value for input parameter cannot be null.
data.engine.NullDefaultInParamValue ( 1 time(s) )
detail : org.eclipse.birt.data.engine.core.DataException: Default value for
input parameter cannot be null. at
org.eclipse.birt.data.engine.impl.ParameterUtil.evaluateInpu tParameterValue(ParameterUtil.java:298)
org.eclipse.birt.data.engine.impl.ParameterUtil.resolveParam eterBinding(ParameterUtil.java:198)
org.eclipse.birt.data.engine.impl.ParameterUtil.resolveParam eterBindings(ParameterUtil.java:161)
org.eclipse.birt.data.engine.impl.ParameterUtil.resolveDataS etParameters(ParameterUtil.java:133)
org.eclipse.birt.data.engine.impl.QueryExecutor.resolveDataS etParameters(QueryExecutor.java:956)
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.populateOdiQuery(PreparedOdaDSQuery.java:279)
org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:212)
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:396)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:145)
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:134)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:125)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:119)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:210)
org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1641)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:62)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:73)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:35)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:123)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:81)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:85)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:205)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:142)
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
Source) at
Source) at
org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.BirtRunAndRend erActionHandler.__execute(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source) at
org.eclipse.birt.report.presentation.aggregation.layout.Engi neFragment.doService(Unknown
Source) at
org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.service(Unknown
Source) at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(Un known
Source) at
org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGe t(Unknown
Source) at javax.servlet.http.HttpServlet.service(HttpServlet.java:740) at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995) at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199) at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:534)
Regards,Anuradha.
Re: Birt Doesn't allow null parameter [message #252865 is a reply to message #252754] Fri, 17 August 2007 04:54 Go to previous message
i think if you set the parameter which is refer by your query, that is not
possible to be null. at least you just display the parameter in your
report, then you can set it to null.
hope is helpful for you.
Previous Topic:Birt Newbie
Next Topic:Cross Tabs Issue - (BIRT Eclipse has a plethora of bugs)
Current Time: Sun Aug 31 21:37:11 EDT 2025
Powered by FUDForum. Page generated in 0.03148 seconds
