Home » Archived » BIRT » Page Break in Birt 2.2
Page Break in Birt 2.2 [message #252743] Thu, 16 August 2007 10:05 Go to next message
Originally posted by: synus.synus.ch
Hello
I installed birt 2.2. on our webserver. It works so far, except of
customized page breaks.
There is a table with 4 groups and I want birt to insert a page break if
there is not enough space to print the whole second group on the current
page.
I tried to assign "Page Break - avoid" to the second group but it didn't
work.
I also tried to assign "Page Break - avoid" to every single item in group 2
including groups 3, 4. Also didn't work.
I hope you can help me.
Yours sincerely,
synus
Group Header Page Break in Birt 2.2 [message #256423 is a reply to message #252743] Thu, 27 September 2007 02:42 Go to previous messageGo to next message
Originally posted by: vivek.madurai.orangescape.com
I installed the major release, BIRT 2.2. It works so far, except the
I have a group in which i want to avoid the page break if there is not
enough space to print the whole group in a single page.
I tried to assign "Page Break - avoid" to the that group,but it didn't
work.
If somebody is aware of this issue,kindly help me in resolving this.
Yours sincerely,
vivek
Re: Group Header Page Break in Birt 2.2 [message #256432 is a reply to message #256423] Thu, 27 September 2007 04:18 Go to previous messageGo to next message
Sounds like you have a similar problem as I have.
I have not solved it yet but according to bug 196186 this is solved in 2.2.1
of BIRT:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196186
Let me know if you manage to solve the problem.
P
Re: Group Header Page Break in Birt 2.2 [message #257747 is a reply to message #256432] Wed, 10 October 2007 02:34 Go to previous messageGo to next message
Upgrading to 2.2.1 solved my problems.
"Paal Espen Reinertsen" <pal.espen.reinertsen@gmail.com> wrote in message
news:fdfp27$65i$1@build.eclipse.org...
> 2.2.1 of BIRT:
> P
Re: Group Header Page Break in Birt 2.2 [message #258671 is a reply to message #257747] Thu, 18 October 2007 03:23 Go to previous messageGo to next message
paal,
thanks a lot.
regards
vivek
>>Hi,
>>2.2.1 of BIRT:
>>Regards,
>>Pål Espen
>>"Vivekanandan Madurai" <vivek.madurai@orangescape.com> wrote in message
>>news:fdfj82$f0h$1@build.eclipse.org...
>>>Hi,
>>>work.
>>>Yours sincerely,
>>>vivek
Re: Group Header Page Break in Birt 2.2 [message #258985 is a reply to message #257747] Mon, 22 October 2007 09:19 Go to previous messageGo to next message
My problem is solved by doing some work around via scripting in BIRT 2.2
Release itself,
http://wiki.eclipse.org/GroupSeparator_(BIRT)
regards
vivek
>>Hi,
>>2.2.1 of BIRT:
>>Regards,
>>Pål Espen
>>>Hi,
>>>work.
>>>Yours sincerely,
>>>vivek
Re: Group Header Page Break in Birt 2.2 [message #259168 is a reply to message #258985] Tue, 23 October 2007 13:07 Go to previous message
Vivekanandan,
That link did not seem to work.
Scott Rosenbaum
> 2.2 Release itself,
> regards
> vivek
>> message news:fdfp27$65i$1@build.eclipse.org...
>>> Hi,
>>> in
>>> 2.2.1 of BIRT:
>>> Regards,
>>> Pål Espen
>>> message news:fdfj82$f0h$1@build.eclipse.org...
>>>> Hi,
>>>> the customized page breaks.
>>>> not enough space to print the whole group in a single page.
>>>> didn't
>>>> work.
>>>> this.
>>>> Yours sincerely,
>>>> vivek
Previous Topic:BIRT 2.2.0 - Report Viewer
Next Topic:select report on jsp using taglib
Current Time: Wed Dec 03 11:13:54 EST 2025
Powered by FUDForum. Page generated in 0.28238 seconds
