Home » Newcomers » Newcomers » What's the standard term for the behavior of the little (i) icons and tool tip that shows next to a
What's the standard term for the behavior of the little (i) icons and tool tip that shows next to a [message #252661] Sat, 29 March 2008 11:51 Go to next message
Originally posted by: nospam_kowalskilee.gmail.com
My apologies in advance if this is "old hat". I've just not run across
this before in the Eclipse windows that I normally use.
I am using Eclipse 3.4 M5 and just noticed in the Add a new CVS
Repository that there's this little blue (i) icon next to the Host
field. And when you hover over it, you get a tool tip with info.
Is there a standard term to refer to this combination of the blue (i)
icon and tool tip behavior? Is it under the UA umbrella, or something else?
I think it's a rather neat feature, and when I demo it to others, I'd
like to know what terms to use to talk about it. :-)
Thanks!
Lee Anne
Re: What's the standard term for the behavior of the little (i) icons and tool tip that shows next t [message #252665 is a reply to message #252661] Sat, 29 March 2008 13:21 Go to previous messageGo to next message
Lee Anne wrote:
> Thanks!
> Lee Anne
Hi Lee Anne. Are you referring to Label Decorations (Help/Workbench User
Guide/Concepts)? For example, the CVS Label Decorations are documented
in Help/Workbench User Guide/Reference/Team support with CVS. Hope this
helps. Mark
Re: What's the standard term for the behavior of the little (i) icons and tool tip that shows next t [message #252788 is a reply to message #252665] Mon, 31 March 2008 15:53 Go to previous messageGo to next message
Hi Mark,
Thanks for the pointer! I'm not sure (yet) if these are the same as the
Label Decorations. The info you provided is great because it gives me a
place to see if it is the same thing. :-)
Thanks again,
Lee Anne
> helps. Mark
Re: What's the standard term for the behavior of the little (i) icons and tool tip that shows next t [message #252997 is a reply to message #252788] Wed, 02 April 2008 18:47 Go to previous message
You may want to investigate org.eclipse.jface.fieldassist.ControlDecoration
and org.eclipse.jface.fieldassist.FieldDecorationRegistry
HTH
Darins
http://runnerwhocodes.blogspot.com
"Lee Anne" <nospam_kowalskilee@gmail.com> wrote in message
news:fsrfa2$cv9$1@build.eclipse.org...
> Hi Mark,
> Thanks again,
> Lee Anne
>> Guide/Concepts)? For example, the CVS Label Decorations are documented in
>> helps. Mark
Previous Topic:Externalize Strings Wizard - Are There Any Preference Settings
Next Topic:unable record the project
Current Time: Fri Oct 24 18:02:59 EDT 2025
Powered by FUDForum. Page generated in 0.09755 seconds
