Eclipse 3.3.2 install on Linux x86_64 [message #252654] |
Fri, 28 March 2008 20:19  |
Originally posted by: pratik_murali.yahoo.com
Hi All,
I have been trying to install Eclipse 3.3.2 for Java development on Red
Hat Enterprise Linux WS release 4 (64 bit)
I installed JDK 1.5 (64 bit) which the eclipse IDE needs in order to start
When i run the command Java -version to verify i get:
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_15-b04)
Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_15-b04, mixed mode)
But when i run eclipse, i get this popup :(
JVM terminated. Exit code=1
/usr/java/jdk1.5.0_15/bin/java
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m eclipse -vm /usr/java/jdk1.5.0_15/bin/java
-jar
/home/pmura/Desktop/eclipse/plugins/org.eclipse.equinox.laun cher_1.0.1.R33x_v20080118.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /home/pmura/Desktop/eclipse/eclipse
-name Eclipse
--launcher.library
/home/pmura/Desktop/eclipse/plugins/org.eclipse.equinox.laun cher.gtk.linux.x86_1.0.3.R33x_v20080118/eclipse_1023.so
-startup
-exitdata d0012
-vmargs
-Xms40m
-jar
This has been driving me nuts. I tried
A)
/eclipse -os linux
B)
/eclipse -vm /pathTo/java/bin
C)
I even tried invoking the eqvinox launcher directly :
java -jar plugins/org.eclipse.equinox.launcher_1.0.1.R33x_v20080118.ja r
Could someone please tell me what i might be doing wrong? Point me in the
right direction?
THanks!
Pratik
Re: Eclipse 3.3.2 install on Linux x86_64 [message #252903 is a reply to message #252866] |
Wed, 02 April 2008 07:04  |
Originally posted by: 4cs6fcg02.sneakemail.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigDAC6BBBE9E8204C1A6D03317
Content-Type: text/plain; charset=UTF-8; format=flowed
Pratik Murali schreef:
> Thanks Walter, actually the Eclipse version i downloaded is named=20
> eclipse-java-europa-winter-linux-gtk-x86_64.tar.gz So i'm guessing=20
> that it should work on 64 bit linux.
> I don't see my logs (/eclipse/configuration) getting updated either whe=
n=20
> eclipse fails to launch. No idea why..
>=20
> Though my Java path is set, to JDK 1.5 with a 64 bit VM, for some reaso=
n=20
> eclipse is not picking it up, even when i force it too by specifying th=
e=20
> below in my eclipse.ini
>=20
> -showsplash
> org.eclipse.platform
> --launcher.XXMaxPermSize
> 256m
> -vm
> -vmargs
> -Xms40m
> -Xmx512m
Do you have other Javas installed? What does =E2=80=98which java=E2=80=99=
tell you?=20
What does =E2=80=98/usr/java/jdk1.5.0_15/bin/java -version=E2=80=99 tell =
you?
Do you have other Eclipses installed? Are you sure you are invoking the =
64-bit one? You say your logs don=E2=80=99t get updated in=20
/eclipse/configuration (that=E2=80=99s a strange place to have Eclipse, b=
tw,=20
usually it would be in /usr/share/eclipse or /usr/lib64/eclipse if you=20
installed it through a package manager, and in /usr/local/eclipse if you =
installed by hand), then maybe somewhere else they are, where?=20
Somewhere in the find man page there is a trick to see which files have=20
changed in the last X minutes, use it to see where the logs are.
Cheers, H.
--=20
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.4-svn0 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iD8DBQFH82gqe+7xMGD3itQRAq6pAJ9KJLwIjUiO+iLpixtjqMZXjOuizgCf Vik1
nKAU5tytbi2p3kFmuVqEWck=
=7l48
-----END PGP SIGNATURE-----
--------------enigDAC6BBBE9E8204C1A6D03317--
FUDForum. Page generated in 0.08679 seconds
