Home » Newcomers » Newcomers » problem with MessageDialog.openInformation
problem with MessageDialog.openInformation [message #252401] Tue, 25 March 2008 18:28 Go to next message
Originally posted by: hisastro.gmail.com
hi.
when I write this in the Run method :
MessageDialog.openInformation (......... )
it does not work :(
i have also written this for import :
import org.eclipse.jface.dialogs.*;
what is the problem ?
thank you in advance
Re: problem with MessageDialog.openInformation [message #252416 is a reply to message #252401] Tue, 25 March 2008 19:12 Go to previous messageGo to next message
Could you please provide more details on how it does not work
Darins
http://runnerwhocodes.blogspot.com
"Astro" <hisastro@gmail.com> wrote in message
news:627eb027a3fd59e96e264503fa053627$1@www.eclipse.org...
> hi.
> it does not work :(
Re: problem with MessageDialog.openInformation [message #252423 is a reply to message #252416] Tue, 25 March 2008 21:37 Go to previous messageGo to next message
thank you for reply.
when I write the "MessageDialog" and I press the "." the editor does not
have any openInformation command to propose .. and if I write it by hand
MessageDialog.openInformation(workbenchwindow.getShell(),"something ","something");
it says that it the method"openInformation" is undefined for the type
MessageDialog.
Re: problem with MessageDialog.openInformation [message #252427 is a reply to message #252423] Tue, 25 March 2008 21:42 Go to previous messageGo to next message
Can you provide the source code?
org.eclipse.jface.dialogs.MessageDialog has that method for me.
Darins
"Babak" <hisastro@gmail.com> wrote in message
news:8866bec9a44f966c1bafc3a5e01a3bed$1@www.eclipse.org...
> have any openInformation command to propose .. and if I write it by hand .
> MessageDialog.
Re: problem with MessageDialog.openInformation [message #252438 is a reply to message #252427] Tue, 25 March 2008 23:29 Go to previous message
thank you Darins.
i was following the EClipse book by ORILLY publications... chapter 12 ..
if it works for you .i will try again from begining by the instructions .
thanks again
Previous Topic:Import, File System, Filter Types do not work
Next Topic:Configuring Eclipse to use McKoi JDBC drivers?
Current Time: Wed Aug 27 14:48:55 EDT 2025
Powered by FUDForum. Page generated in 0.08176 seconds
