Home » Archived » Memory Analyzer (MAT) » Version of BIRT Chart Engine?
Version of BIRT Chart Engine? [message #2122] Thu, 29 May 2008 09:57 Go to next message
The download page states
"One feature contains the heap analysis and reports, and the other
contains pie charts. The latter requires the BIRT Chart Engine."
Which *version* of BIRT Chart Engine has MAT been tested against? The
BIRT project currently has versions 2.1.3, 2.2.2, and 2.3 RCx available.
Brian
Re: Version of BIRT Chart Engine? [message #2130 is a reply to message #2122] Fri, 30 May 2008 02:19 Go to previous message
Hi Brian:
Use 2.2.2 if you are using Eclipse 3.3.
Alternative you can use the 2.3RC with Eclipse 3.4RCs.
I will also update the warning message.
Andreas.
Previous Topic:Webinar a/b Memory Analyzer
Next Topic:missing tracing tab
Current Time: Thu Jul 17 19:59:58 EDT 2025
Powered by FUDForum. Page generated in 0.03931 seconds
