postscriptemitter [message #251965] |
Fri, 10 August 2007 09:35  |
Hello to everyone...
I have tried many times to generate an output in postscript format but
without luck!!
In PDF, XLS,HTML,DOC run correctly....
I'm using birt-runtime-2_2_1_N20070718 and the emitter is contained
I have also tried 2_2_1_S20070727 but without success.......
Anyone has any idea?
I obtain the following error :
Please Help...
ERROR:
INFO: Data Engine starts up
[Fatal Error] :-1:-1: Premature end of file.
10-ago-2007 15:22:51
org.eclipse.birt.report.engine.layout.pdf.font.FontConfigRea der
parseConfigFile
AVVERTENZA: Premature end of file.
org.xml.sax.SAXParseException: Premature end of file.
com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(D OMParser.java:264)
com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(DocumentBuilderImpl.java:292)
org.eclipse.birt.report.engine.layout.pdf.font.FontConfigRea der.parseConfigFile(FontConfigReader.java:171)
org.eclipse.birt.report.engine.layout.pdf.font.FontConfigRea der.parseConfigFile(FontConfigReader.java:136)
org.eclipse.birt.report.engine.layout.pdf.font.FontConfigRea der.parseFormatRelatedConfigFile(FontConfigReader.java:124)
org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.g etFontManager(FontHandler.java:237)
org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.s etFormat(FontHandler.java:268)
org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.<init >(FontHandler.java:110)
org.eclipse.birt.report.engine.layout.pdf.font.FontSplitter. <init>(FontSplitter.java:48)
org.eclipse.birt.report.engine.layout.pdf.text.ChunkGenerato r. <init>(ChunkGenerator.java:34)
org.eclipse.birt.report.engine.layout.pdf.PDFTextLM$Composit or. <init>(PDFTextLM.java:233)
org.eclipse.birt.report.engine.layout.pdf.PDFTextLM.<init>(PDFTextLM.java:91)
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory$ContentVisitor.handleText(PDFLayoutManagerFactory.java :210)
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory$ContentVisitor.visitData(PDFLayoutManagerFactory.java: 145)
org.eclipse.birt.report.engine.content.impl.DataContent.acce pt(DataContent.java:112)
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory.createLayoutManager(PDFLayoutManagerFactory.java:71)
org.eclipse.birt.report.engine.layout.pdf.PDFLineAreaLM.hand leChild(PDFLineAreaLM.java:167)
org.eclipse.birt.report.engine.layout.pdf.PDFLineAreaLM.trav erseChildren(PDFLineAreaLM.java:150)
org.eclipse.birt.report.engine.layout.pdf.PDFStackingLM.layo utChildren(PDFStackingLM.java:118)
org.eclipse.birt.report.engine.layout.pdf.PDFAbstractLM.layo ut(PDFAbstractLM.java:132)
org.eclipse.birt.report.engine.layout.pdf.PDFBlockContainerL M.traverseSingleChild(PDFBlockContainerLM.java:44)
org.eclipse.birt.report.engine.layout.pdf.PDFTextBlockContai nerLM.traverseChildren(PDFTextBlockContainerLM.java:57)
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .layoutChildNode(PDFBlockStackingLM.java:109)
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .traverseChildren(PDFBlockStackingLM.java:89)
org.eclipse.birt.report.engine.layout.pdf.PDFRowLM.traverseC hildren(PDFRowLM.java:88)
org.eclipse.birt.report.engine.layout.pdf.PDFTableLM.travers eChildren(PDFTableLM.java:109)
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layoutHe ader(PDFPageLM.java:161)
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.initiali ze(PDFPageLM.java:83)
org.eclipse.birt.report.engine.layout.pdf.PDFStackingLM.layo utChildren(PDFStackingLM.java:116)
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layout(P DFPageLM.java:212)
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layoutReport(PDFReportLayoutEngine.java:64)
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layout(PDFReportLayoutEngine.java:87)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:140)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:68)
evega.cbo.report.document.impl.birt.BirtService.createAndRen derDocument(BirtService.java:72)
evega.cbo.report.document.impl.builder.DocumentBuilder.build Report(DocumentBuilder.java:84)
evega.cbo.report.document.impl.DocumentService.createAndRend erDocument(DocumentService.java:70)
evega.cbo.report.document.impl.DocumentService.createAndRend erDocument(DocumentService.java:40)
evega.cbo.report.sg.test.document.DocumentToast.test04TestDo cumentService(DocumentToast.java:99)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
org.springframework.test.ConditionalTestCase.runBare(Conditi onalTestCase.java:69)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
10-ago-2007 15:22:53 org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
INFO: Data engine shuts down
FUDForum. Page generated in 0.04191 seconds
