Home » Newcomers » Newcomers » Problem Launching Eclipse on OS X (error on launch)
Problem Launching Eclipse on OS X (error on launch) [message #251736] Mon, 17 March 2008 19:19 Go to next message
Originally posted by: peterlaurenspublic.gmail.com
I have a problem launching Eclipse on OS X.
I have had Eclipse and some projects up and running for a few weeks and
have been working on them fine (enjoying Eclipse). Now all of a sudden I
cannot launch Eclipse - I just get an error.
The error is simply a dialog that appears just after the splash screen
which says "An error has occurred. Please see the log ...". Then Eclipse
quits.
I have tried redownloading Eclipse - I get the same error and it puts an
error log in the configuration folder.
I have tried moving my workspaces around, rebooting, I just can't seem to
get Eclipse running again. My platform hasn't changed since I had been
working successfully in Eclipse.
Here's the log:
!SESSION 2008-03-17 18:36:03.161
eclipse.buildId=M20080221-1800
java.version=1.5.0_13
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Framework arguments: -keyring /Users/peterlaurens/.eclipse_keyring
-showlocation
Command-line arguments: -os macosx -ws carbon -arch x86 -keyring
/Users/peterlaurens/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.update.configurator 4 0 2008-03-17 18:36:04.213
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start() of
bundle org.eclipse.update.configurator.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
Caused by: org.eclipse.core.runtime.CoreException: Cannot create
configuration in file:/Applications/eclipse/configuration/
org.eclipse.update.internal.configurator.Utils.newCoreExcept ion(Utils.java:96)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:113)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:69)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 10 more
Root exception:
org.eclipse.core.runtime.CoreException: Cannot create configuration in
!ENTRY org.eclipse.core.runtime 4 0 2008-03-17 18:36:04.227
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.core.jobs;
bundle-version="[3.2.0,4.0.0)"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
!ENTRY org.eclipse.osgi 4 0 2008-03-17 18:36:04.234
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.update.configurator_3.2.101.R33x_v 20070810.jar/
is not active.
!MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.core.runtime_3.3.100.v20070530.jar /
was not resolved.
!ENTRY org.eclipse.osgi 4 0 2008-03-17 18:36:04.238
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:72)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
!ENTRY org.eclipse.osgi 2 0 2008-03-17 18:36:04.244
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-03-17 18:36:04.245
!MESSAGE Bundle
was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-03-17 18:36:04.245
!MESSAGE Missing required bundle org.eclipse.equinox.app_[1.0.0,2.0.0).
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
org.eclipse.equinox.registry_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-03-17 18:36:04.246
org.eclipse.core.contenttype_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-03-17 18:36:04.247
org.eclipse.equinox.preferences_[3.2.0,4.0.0).
!ENTRY org.eclipse.osgi 2 0 2008-03-17 18:36:04.248
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-03-17 18:36:04.248
!MESSAGE Bundle
[3] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-03-17 18:36:04.248
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-03-17 18:36:04.249
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-03-17 18:36:04.250
!MESSAGE Missing optionally required bundle
org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
(End of the log)
Any help would be *much* appreciated, thanks so much for your time.
Thanks a lot,
- Peter
Re: Problem Launching Eclipse on OS X (error on launch) [message #251791 is a reply to message #251736] Tue, 18 March 2008 12:31 Go to previous message
Bump: Really - I cannot seem to fix this issue: permissions, rebooting,
removing preferences and hidden eclipse files - nothing works.
Any help much appreciated...
Previous Topic:Eclipse RCP Patch 2 for 3.3.1.1 failed
Next Topic:Inputting Runtime Arguments
Current Time: Thu Jul 17 20:06:48 EDT 2025
Powered by FUDForum. Page generated in 0.09789 seconds
