Home » Eclipse Projects » Eclipse Platform » Plug-in's home directory (by code)?
Plug-in's home directory (by code)? [message #251725] Fri, 11 June 2004 06:52 Go to next message
Originally posted by: ramim.kauhajoki.fi
How do I find out the directory where my plug-in is installed by program?
I need to create several ASCII files and I thought I used the plug-in's
dir as the working directory !!
Thanks !!
Re: Plug-in's home directory (by code)? [message #251740 is a reply to message #251725] Fri, 11 June 2004 08:22 Go to previous messageGo to next message
Originally posted by: pieter.west.NOSPAM.nl
noon wrote:
> Thanks !!
The plugin installation directory should not be used to write files to
It's better to use YourPlugin.getDefault().getStateLocation()
If you have very good reasons, you can find the installation directory as
follows:
final URL url = Platform.find(Platform.getBundle(YourPlugin.PLUGIN_ID),new
Path("/"));
Re: Plug-in's home directory (by code)? [message #251756 is a reply to message #251740] Fri, 11 June 2004 08:48 Go to previous messageGo to next message
Thanks for you quick answer :)
I think you're right. The location of the files should something else than
the plug-in's home directory ... e.g. incase of updates etc.
Where are these files located in the disc if I save them by the
"YourPlugin.getDefault().getStateLocation()" -method?
Pieter wrote:
> noon wrote:
> > Hi,
> > Thanks !!
> follows:
> Path("/"));
Re: Plug-in's home directory (by code)? [message #251778 is a reply to message #251756] Fri, 11 June 2004 09:23 Go to previous message
noon wrote:
Just read the API
Previous Topic:How to move text editor cursor on right click?
Next Topic:Template
Current Time: Sun Jul 27 06:16:15 EDT 2025
Powered by FUDForum. Page generated in 0.03796 seconds
