question about activities and help [message #251605] |
Thu, 10 June 2004 16:28  |
Originally posted by: exquisitus.rogers.com
Hi -
Let's say I have a TOC file (toc_a.xml) and it is primary. It subsumes
another primary TOC file (toc_b.xml) by including a <link toc="..toc_b.xml"
/>. If I create an activity that filters toc_a.xml and then disable that
activity, what should I expect? Should toc_b.xml now show up in the
top-level of the navigation since toc_a.xml is disabled and can no longer
subsume it? Should both toc_a.xml and toc_b.xml not show up, period?
When I play with this, I'm finding that disabling toc_a.xml results in a
disable of both TOCs (toc_b.xml does not show up, even though it isn't
explicitly included as part of the activity). To be honest, I'm not sure
what I was expecting here - I could understand both results. But I do want
to know if what I'm seeing is what is expected.
Jennifer Calder
Re: question about activities and help [message #251885 is a reply to message #251605] |
Fri, 11 June 2004 14:17  |
Yes, this is the design. Since topics are in a hierarhy, and activities
filtering is applied to a ready navigation, not before it is built, a topic
is visible if all its parents (toc_b and toc_a) are visible. If toc_b fits
logically into (is part of from a users point of view) toc_a, and toc_a is
not desired to be shown, why should the toc_b alone be shown.
Konrad
"Jennifer Calder" <exquisitus@rogers.com> wrote in message
news:caafqb$7ju$1@eclipse.org...
> Hi -
toc="..toc_b.xml"
> Jennifer Calder
FUDForum. Page generated in 1.04034 seconds
