Home » Newcomers » Newcomers » install Android Plugin
install Android Plugin [message #251580] Fri, 14 March 2008 08:39 Go to next message
Originally posted by: mahalaalrudra.gmail.com
Hello to All,
When I try to install the plugin for android in eclipse 3.3.1.1. I follow
all the step to install android plugin it give an error "Android Editors
(0.2.0.200802081635) requires plug-in 'org.eclipse.wst.sse.ui'". where
this plugin I download. please help me to out from this problem to use
android with my application. Other than when I update my eclipse it want
to require JDT & WST plugin.
Ravi
Re: install Android Plugin [message #251615 is a reply to message #251580] Fri, 14 March 2008 14:37 Go to previous message
Ravi wrote:
> Hello to All,
> follow all the step to install android plugin it give an error "Android
> Editors (0.2.0.200802081635) requires plug-in 'org.eclipse.wst.sse.ui'".
> where this plugin I download. please help me to out from this problem to
> use android with my application. Other than when I update my eclipse it
> want to require JDT & WST plugin.
The easiest solution would be to download and install the JEE package
from the Eclipse downloads page (make sure to install it in a different
location than your current Eclipse installation, or delete your old
installation first). The JEE package includes WST and JDT, so Android
should install into that easily.
Or you can install WST into an existing Eclipse by using Help > Software
Updates > Find and Install, making sure to select the Europa Discovery
Site when prompted.
Hope this helps,
Eric
Previous Topic:java.lang.nullpointerexception on OC4j standalone
Next Topic:QuickFix Engine
Current Time: Tue Jul 22 08:31:21 EDT 2025
Powered by FUDForum. Page generated in 0.07250 seconds
