Home » Language IDEs » Java Development Tools (JDT) » problem with JDT Javadoc setup
problem with JDT Javadoc setup [message #251534] Tue, 19 February 2008 16:07 Go to next message
Originally posted by: gl4jalopi.verizon.net
I seem to have gotten something messed up in my Eclipse installation.
Since installing Eclipse I've installed the Nokia java development tools.
I'm now working on a standard java utility and when I click on 'Open
Declaration' in the context menu for something like 'String' I get the
list of members in the String class but the displayed page also says that
'Source Not Found'. Has something in my configuration been messed up, or
is there something that I'm missing?
Any help would be greatly appreciated,
Greg
Re: problem with JDT Javadoc setup [message #251546 is a reply to message #251534] Tue, 19 February 2008 20:31 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Greg Wilson-Lindberg" <gl4jalopi@verizon.net> wrote in message
news:f23adf17ba9692a8377ebc08f714f5da$1@www.eclipse.org...
>Declaration' in the context menu for something like 'String' I get the list
Maybe the Nokia tools pointed your default JRE to a JRE that doesn't have
source associated with it?
Re: problem with JDT Javadoc setup [message #251551 is a reply to message #251534] Tue, 19 February 2008 20:34 Go to previous message
> tools. I'm now working on a standard java utility and when I click on
> 'Open Declaration' in the context menu for something like 'String' I get
> the list of members in the String class but the displayed page also says
> that 'Source Not Found'. Has something in my configuration been messed
> up, or is there something that I'm missing?
> Greg
Hi Greg. Do you have the source attached for the JRE? You can check this
by selecting Project/Properties/Java Build Path, Libraries Tab. Expand
JRE, expand rt.jar. Under rt.jar is Source attachment. It should list
your "src.zip" file in the location where you installed the JDK (e.g.,
for me, c:\program files\Java\jdk1.6.0\src.zip). It should also point to
the java.sun.com/javase/6/docs/api or similar website for the Javadoc
location.
You need to have installed the JDK, not just the JRE. Hope this helps. Mark
Previous Topic:Question about "Build Automatically"
Next Topic:Need help for code change design
Current Time: Tue Jul 15 13:08:37 EDT 2025
Powered by FUDForum. Page generated in 0.24939 seconds
