Home » Language IDEs » Java Development Tools (JDT) » 3.4 M5 - Compiler error in cast
3.4 M5 - Compiler error in cast [message #251516] Tue, 19 February 2008 06:58 Go to next message
Originally posted by: andre_andrade_costa.yahoo.com
I'm getting a cast error in Eclipse in the following lines:
Properties panels = new Properties();
panels.load(this.getClass().getResourceAsStream(FILE_PANEL)) ;
List<String> keys = new ArrayList<String>((Collection<? extends String>)
panels.keySet());
This does not happen in 3.3
Re: 3.4 M5 - Compiler error in cast [message #251524 is a reply to message #251516] Tue, 19 February 2008 10:30 Go to previous messageGo to next message
> panels.keySet());
What is the exact error?
Re: 3.4 M5 - Compiler error in cast [message #251555 is a reply to message #251524] Wed, 20 February 2008 09:17 Go to previous messageGo to next message
>> panels.keySet());
"Cannot cast from Set<Object> to Collection<? extends String>"
The message is shown in the editor and in the Problems window. I'm using
JDK 1.5.0_12
Re: 3.4 M5 - Compiler error in cast [message #251575 is a reply to message #251516] Wed, 20 February 2008 15:22 Go to previous message
Originally posted by: wharley.bea.com
"Andre" <andre_andrade_costa@yahoo.com> wrote in message
news:59790f6c2438d3133d3e25a2d83f32da$1@www.eclipse.org...
> panels.keySet());
In Eclipse 3.3.2, I get a warning on the third line, "Type safety: Unchecked
cast from Set<Object> to Collection<? extends String>". In 3.4M5, as you
note, it's an error: "Cannot cast from Set<Object> to Collection<? extends
String>".
But enquiring minds might note that String is final, and wonder what happens
if we change the code to Collection<String>. Aha! Then, we get the same
"Cannot cast" error in both 3.3.2 and 3.4M5: "Cannot cast from Set<Object>
to Collection<String>"
So, it sounds like 3.3 allowed the cast to be treated just as a warning
rather than an error in this special "extends" case, and is changed in 3.4.
A bit more research reveals
https://bugs.eclipse.org/bugs/show_bug.cgi?id=89940 - it appears that what
happened was that the Java Language Spec was tightened up a bit around
wildcards.
If you really need this to work, you could just cast to a raw type, instead:
List<String> keys = new ArrayList<String>((Collection) panels.keySet());
That way you'll get an unsafe cast warning, appropriately, but not an error.
You can suppress the warning with @SuppressWarnings if you like.
Intuitively, "should it be an error"? It's clear that it's an unsafe cast -
there's nothing stopping someone from putting an Integer into the collection
along with the Strings, at any point. But that would just result in a
ClassCastException at runtime; so what? I'm not sure what the compiler's
guiding principle is on whether to consider a dubious cast a warning versus
an error.
Previous Topic:Need help for code change design
Next Topic:Re: Classpath in Launchconfiguration
Current Time: Sun Aug 31 08:04:24 EDT 2025
Powered by FUDForum. Page generated in 0.06847 seconds
