Home » Modeling » TMF (Xtext) » Dependency between eclipse plugins
Dependency between eclipse plugins [message #24730] Sun, 28 December 2008 09:57 Go to next message
Is there an open source app out there using which I can see the
dependencies between the plugins in an eclipse workspace as a diagram?
Which are the good applications using which I can reverse engineer the
code (especially eclipse plugins)?
Madhu
Re: Dependency between eclipse plugins [message #25866 is a reply to message #24730] Mon, 12 January 2009 04:38 Go to previous message
Hi Madhu,
for dependency visualisation I'm using this plug-in
http://www.eclipse.org/pde/incubator/dependency-visualizatio n/index.php
Best Regards,
Dennis.
> Madhu
Previous Topic:ei.unescapeString(getText(), 1)
Next Topic:[TCS] Problems with "Loading outline
Current Time: Fri May 09 19:56:16 EDT 2025
Powered by FUDForum. Page generated in 0.03767 seconds
