Home » Language IDEs » Java Development Tools (JDT) » JSF app no longer deploys class files
JSF app no longer deploys class files [message #251203] Mon, 04 February 2008 00:49 Go to next message
I seem to have gotten my JSF app in a state where it will no longer deploy
the class files that I've written into the WAR file, either on export or
on automatic deploy to Tomcat.
I had created a dynamic web app with the JSF project facet. It was
basically working, except I was having some specific issues with my JSP
page and its interaction with JSF. I wanted to attach the JSF RI source
(I'm using the Sun 1.2 RI). For some reason that I can't explain, Eclipse
won't let me attach the source for this. Whenever I stored the path and
then clicked OK on the project preferences, I still couldn't see the
source files, and going back into the project properties shows that the
source dir setting was gone.
Anyway, I'm annoyed with that, but that's not even my current problem. I
decided since I would try to remove the JSF project facet and just add the
JSF RI jars as an ordinary library. This produced one bizarre
side-effect. It seemed to remove my source tree from the "Sources"
property settings. I readded it by editing the .classpath file directly,
adding the following line (looking at other projects for this):
<classpathentry kind="src" path="src"/>
I thought this fixed my source files situation for the moment.
Unfortunately, I then discovered that now JSP pages didn't know about my
JSF tag libraries. So, I decided it really needs to have it as a project
facet, so I backtracked on that, removing it as a regular library, then
re-adding it as a project facet.
Unfortunately, it seems like this didn't even help. Even worse, I
discovered that when I deploy the app, it doesn't put my compiled class
files into WEB-INF/classes.
Am I going to have to completely rebuild this application, or is there a
way to do surgery on my .classpath file (or other files) to restore normal
functionality?
I wouldn't mind solving my "original" problem, which is being able to set
the source files path for the JSF implementation.
Re: JSF app no longer deploys class files [message #251213 is a reply to message #251203] Mon, 04 February 2008 11:50 Go to previous messageGo to next message
I have no idea how it got into this state, but after recreating the
application from scratch (just copying the source files over after
creating the skeleton), I see the differences in the metadata files that
make the difference. In the ".settings/org.eclipse.wst.common.component"
file, I needed to have the following line:
<wb-resource deploy-path="/WEB-INF/classes" source-path="/src"/>
If this happens again, if it's less practical to recreate the project, at
least I might be able to fix it by adding this line.
I would think it would be a good idea to document the schemas for these
metadata files. I couldn't find any documentation on this file, or others
like it. I'm sure I just didn't know where to look.
Re: JSF app no longer deploys class files [message #251217 is a reply to message #251203] Mon, 04 February 2008 12:02 Go to previous messageGo to next message
This question is more likely to get help on the webtools and/or JSF
newsgroups. I've copied them to this response.
> deploy the class files that I've written into the WAR file, either on
> export or on automatic deploy to Tomcat.
> Eclipse won't let me attach the source for this. Whenever I stored the
> path and then clicked OK on the project preferences, I still couldn't
> see the source files, and going back into the project properties shows
> that the source dir setting was gone.
> I decided since I would try to remove the JSF project facet and just add
> the JSF RI jars as an ordinary library. This produced one bizarre
> directly, adding the following line (looking at other projects for this):
> project facet, so I backtracked on that, removing it as a regular
> library, then re-adding it as a project facet.
> normal functionality?
> set the source files path for the JSF implementation.
Re: JSF app no longer deploys class files [message #251221 is a reply to message #251213] Mon, 04 February 2008 12:03 Go to previous messageGo to next message
> ".settings/org.eclipse.wst.common.component" file, I needed to have the
> following line:
> at least I might be able to fix it by adding this line.
> others like it. I'm sure I just didn't know where to look.
Those files are probably not documented; they're not intended for user
modification as they are internal "state" of the WST tools.
Eric
Re: JSF app no longer deploys class files [message #251225 is a reply to message #251221] Mon, 04 February 2008 12:12 Go to previous messageGo to next message
The problem with amazing tools like Eclipse is that sometimes they don't
work properly. If the plugin somehow gets the internal state confused,
unless I know the hidden information about the structure of these files,
my only recourse is to just start over. If the structure of these files
was documented in a reasonable place, I'd at least have a chance of being
able to fix it without having to start over. If I make a mistake and the
result doesn't work, I'm no worse off than I was in the first place.
Re: JSF app no longer deploys class files [message #251229 is a reply to message #251221] Mon, 04 February 2008 12:31 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Eric, I would hope that there is some documentation somewhere about
those files and what they are used for. Regardless if they are intended
for user modification or not, documenting the usage of those files is
important.
>> these metadata files. I couldn't find any documentation on this file,
>> or others like it. I'm sure I just didn't know where to look.
> Eric
Re: JSF app no longer deploys class files [message #251250 is a reply to message #251229] Mon, 04 February 2008 17:35 Go to previous messageGo to next message
> important.
This is open source - if the WST development team didn't have reason,
motivation, time,...whatever... to document them, someone will have to
either a) open a bug report asking for it, b) do the work and submit it,
or c) both.
>>> project, at least I might be able to fix it by adding this line.
>>> file, or others like it. I'm sure I just didn't know where to look.
>> Eric
Re: JSF app no longer deploys class files [message #251258 is a reply to message #251250] Tue, 05 February 2008 03:00 Go to previous message
Hi guys,
Thanks for copying JSF on this issue. Vis-a-vis JSF tools, other than the
source attachment problem, are there any other issues here?
I see that we have some lively discussion on source attachment here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=202177.
Cameron
Previous Topic:Generate a JAVAC/JAVA/JAVAW command strings
Next Topic:How and where is the collapsed code/comment line drawn?
Current Time: Sat Jul 12 07:38:40 EDT 2025
Powered by FUDForum. Page generated in 0.05360 seconds
