Home » Newcomers » Newcomers » Eclipse crashes when adding jars to project
Eclipse crashes when adding jars to project [message #251190] |
Tue, 11 March 2008 01:08  |
I keep running into a problem where eclipse crashes whenever I try to
create a user library.
I was able to reproduce the problem using a fresh installation of eclipse
3.3.2 in a new location, using a new workspace. I create a new java
project and attempt to create a new user library. When I attempt to select
libraries, eclipse crashes.
The only thing in the .log file is the message:
!ENTRY org.eclipse.ui 4 4 2008-03-10 23:48:13.890
!MESSAGE Invalid preference page path: Cache
Also, this message is not printed every time eclipse crashes. I was able
to make it crash 5 times in a row without the message being printed.
In summary, here is the test procedure:
1) Install fresh eclipse (specifically
eclipse-java-europa-winter-win32.zip)
2) Open eclipse in a new workspace
3) Create new java project
4) Add libraries and CRASH!!!
It seems to only happen when my mouse actually moves over a file in the
file chooser ... but maybe I'm over diagnosing the problem.
Any help is appreciated. Also, if this is the wrong forum, could someone
please point me to the right forum? Thanks.
Re: Eclipse crashes when adding jars to project [message #251201 is a reply to message #251190] |
Tue, 11 March 2008 09:02   |
> eclipse 3.3.2 in a new location, using a new workspace. I create a new
> java project and attempt to create a new user library. When I attempt to
> select libraries, eclipse crashes.
> The only thing in the .log file is the message: !ENTRY org.eclipse.ui 4
The correct mechanism for reporting bugs is Bugzilla
(http://bugs.eclipse.org/bugs). You've provided some good details, but
probably not enough to go on; obviously people can create User Libraries
or it would have been reported and fixed by now, so you must be doing
something out of the ordinary to cause this to happen, or perhaps there
is something about your environment that is non-standard (such as JVM).
In your bug report, be as detailed as possible about your environment
and the exact steps you take. In fact, if you provide that information
here, we might be able to diagnose the problem without going through the
effort of a formal bug report. It's up to you...
Hope this helps,
Eric
Re: Eclipse crashes when adding jars to project [message #251216 is a reply to message #251201] |
Tue, 11 March 2008 10:17   |
> Hope this helps,
> Eric
Eric,
I understand that this is not a common bug, or else no one could add
libraries. That's why I'm a little hesitant to file it as a bug.
I don't know what could be non-standard about my configuration. I'm using
the standard sun jdk/jvm 1.6 update 3 (downloaded from java.sun.com). I'm
installing a fresh version of eclipse (downloaded the latest version) and
creating a new project. The log file is amazingly empty. The complete
contents are:
!SESSION 2008-03-10 23:46:11.015
eclipse.buildId=M20080221-1800
java.version=1.6.0_03
Command-line arguments: -os win32 -ws win32 -arch x86
When eclipse crashes, it just disappears, with no warning or error dialog
whatsoever. Sometimes the .log file will not even contain the "Invalid
preference page path" message.
Thanks for the help.
Re: Eclipse crashes when adding jars to project [message #251388 is a reply to message #251249] |
Wed, 12 March 2008 09:36   |
Simon wrote:
> Oliver,
> What would a VM dump look like? I'm looking in my eclipse installation
> folder (C:\Program Files\eclipse) and I don't see anything out of the
> ordinary.
It might be on your desktop, or in your user directory (typically
something like C:\Documents and Settings\<username>), or it might be in
the directory from which Eclipse is launched. I forget the extension
that is used, or I'd just tell you to search for that.
Finally, how are you launching Eclipse? Can you post the batch/command
script you use and the contents of your eclipse.ini file? Have you
specified the JVM that Eclipse should use, as in
http://wiki.eclipse.org/Eclipse.ini ?
Eric
> Olivier Thomann wrote:
>> Simon a écrit :
>>> When eclipse crashes, it just completely shuts down. There is no
>>> trace of it.
>> So you should have a VM dump somewhere on your disk. Check the folder
>> when you have your eclipse executable.
>> Inside the VM dump, you might have a better clue why the VM aborted.
>> Could be a JIT bug. Could be a SWT bug.
>> HTH,
>> Olivier
Re: Eclipse crashes when adding jars to project [message #251402 is a reply to message #251388] |
Wed, 12 March 2008 10:16   |
> something like C:Documents and Settings<username>), or it might be in
Eric,
I didn't find anything in My Documents, my desktop, or my user directory
that looked like a JVM dump. However, I'm not sure what I'm looking for
exactly...
I'm launching eclipse using a shortcut that has a target of:
"C:\Program Files\eclipse3.3\eclipse\eclipse.exe" -vm "C:\Program
Files\Java\jdk1.6.0_04\bin"
I've been able to reproduce the problem when pointing to jdk1.6.0_03 as
well as jdk1.5.0_13.
My eclipse.ini file is as follows:
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256M
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
Thanks for the help,
-Simon-
Re: Eclipse crashes when adding jars to project [message #251439 is a reply to message #251435] |
Wed, 12 March 2008 12:18  |
Walter Harley a écrit :
> I think you need to specify the actual VM executable, not just the
> directory. At least that's how it's done in the eclipse.ini file that Eric
> pointed to:
Once Eclipse has started, you might want to check the VM used by going to:
Help>About Eclipse SDK>Configuration details.
Olivier
Current Time: Fri Jul 18 09:16:40 EDT 2025
Powered by FUDForum. Page generated in 0.11069 seconds
