Home » Eclipse Projects » Remote Application Platform (RAP) » Weird bug in RAP
Weird bug in RAP [message #2116] Wed, 17 January 2007 02:36 Go to next message
Originally posted by: Stephanus.Mueller.itsquad.de
Hi there
When trying to create a "PropertySheet" using the System-properties on a
windows-system the Display went blank. I analyzed the causes and found:
o Any property (or table-item-text) that has a trailing backslash causes
this error
o there are properties that consist of newline-characters - these props
also cause a blank display
o In addition any backslash (e.g. within path-information) will be
filtered out
This error also occurs when doubling the (trailing) backslashes
This error not even occurs with the table but also with MenuItems so I
suppose it's a general issue of any text-containing widget and it might
also be an effect of other special (but valid) characters
Stephanus Mueller
Re: Weird bug in RAP [message #3101 is a reply to message #2116] Thu, 18 January 2007 05:23 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Stephanus,
thanks for the bug report. As you mentioned, it is a general issue that
affects all widget texts.
A fix should be in CVS today late afternoon. I will send a note to this
list when its in.
Rüdiger
Stephanus Mueller wrote:
> Hi there
> this error
> filtered out
> Regards
> Stephanus Mueller
Re: Weird bug in RAP [message #3156 is a reply to message #3101] Thu, 18 January 2007 09:23 Go to previous messageGo to next message
I just committed the fix to CVS.
Double quotes and backslashes are now escaped. Newline chars are
currently stripped from the text. This is only a quick fix, probably
multi-line and single-line text widgets need a different solution therefore.
Rüdiger
Rüdiger Herrmann wrote:
> Stephanus,
> list when its in.
> Regards
> Rüdiger
>> Hi there
>> a windows-system the Display went blank. I analyzed the causes and found:
>> causes this error
>> props also cause a blank display
>> filtered out
>> might also be an effect of other special (but valid) characters
>> Regards
>> Stephanus Mueller
Re: Weird bug in RAP [message #3190 is a reply to message #3156] Thu, 18 January 2007 09:38 Go to previous messageGo to next message
Hello Rüdiger
that was quick. That'll help a lot. I interpret your words that we have
to escape quotes and backslashes according to Java.
Stephanus
> Cheers,
> Rüdiger
Re: Weird bug in RAP [message #3221 is a reply to message #3190] Thu, 18 January 2007 10:16 Go to previous message
Hi Stephanus,
you just need to escape them as the compiler requires it.
For example
text.setText( "\"path\\to\\somewhere\"" );
would be displayed on the client as
"path\to\somewhere"
Rüdiger
> Hello Rüdiger
> Regards
> Stephanus
>> therefore.
>> Cheers,
>> Rüdiger
Previous Topic:Lazy Dataloading and Obfuscating
Next Topic:RAP has now elementary Workbench features
Current Time: Sun Aug 31 21:00:24 EDT 2025
Powered by FUDForum. Page generated in 0.04465 seconds
