Home » Modeling » TMF (Xtext) » System Architecture Document?
System Architecture Document? [message #24690] Fri, 26 December 2008 22:11 Go to next message
For the tmf xtext project is there a system architecture document
available? I just downloaded the source code. I was curious to see the
role of each plugin and relationship between the plugins.
Madhu
Re: System Architecture Document? [message #24767 is a reply to message #24690] Mon, 29 December 2008 15:33 Go to previous messageGo to next message
Hi Madhu,
unfortunately there is no architecture document describing the purpose
of the different bundles yet.
You can find some documentation here :
http://wiki.eclipse.org/Xtext/Documentation
However, the dependencies between bundles can be viewed using the
Plug-in dependencies view which is part of Eclipse PDE (and should be
part of your Eclipse instance).
Sven
Madhu Samuel schrieb:
> Hello,
> Madhu
Re: System Architecture Document? [message #24836 is a reply to message #24767] Mon, 29 December 2008 23:30 Go to previous message
Hi Sven,
Thanks for the details.
I was looking for a tool which will show the dependencies between all the
plugins in a workspace (or a set of selected plugins) in a single view.
But definitely the plugin dependencies view will help.
Madhu
Previous Topic:The cvs repository connection cannot be enabled.
Next Topic:[TCS] Split metamodel and concrete syntax into several files
Current Time: Thu Jul 17 02:08:27 EDT 2025
Powered by FUDForum. Page generated in 0.19193 seconds
