Home » Eclipse Projects » Eclipse Platform » Early Startup Bad extension exception
Early Startup Bad extension exception [message #251005] Wed, 09 June 2004 10:48 Go to next message
Originally posted by: ptiedt.us.ibm.com
Hi All,
I tried to load my plugin early and thus let my Plugin class implement
IStartup. I aslo specified the extension point org.eclipse.ui.IStartup.
When I try to run the Runtime Workbench I get the following error.
Reason:
Unable to execute early startup code for an extension
Bad extension specification
Reason:
startup class must implement org.eclipse.ui.IStartup
I am using WIN 2k and Eclipse 3 M9 + a 1.4 JRE
Any ideas?
thx
Philipp
Re: Early Startup Bad extension exception [message #251341 is a reply to message #251005] Thu, 10 June 2004 04:00 Go to previous message
Originally posted by: thomas_maeder.ch.ibm.com
The startup extension point has a class attribute. Does the class that
you give there implement IStartup?
ptiedt@us.ibm.com wrote:
> Hi All,
> Reason:
> Reason:
> Any ideas?
> thx
> Philipp
Previous Topic:How to prevent multiple resources with same name??
Next Topic:I wanna this feature
Current Time: Sun Jul 27 08:42:41 EDT 2025
Powered by FUDForum. Page generated in 0.03372 seconds
