Home » Archived » Visual Editor (VE) » problems extending JPanel
problems extending JPanel [message #24679] Thu, 11 March 2004 07:24 Go to next message
Originally posted by: mb.thomas-daily.de
Greetinx!
I am using Visual Editor 0.5.
I just tried to add a class that extends JPanel.
The result:
!ENTRY org.eclipse.ve.java.core 2 0 Mrz 11, 2004 13:10:25.404
!MESSAGE Exception
!STACK 0
java.lang.ExceptionInInitializerError: IWAV0118E Class
somepackage.MyJPannel (or one of its superclasses) is not found or has
errors.
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:825)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:752)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponentWithConstraint(ContainerProxyAdapter.java:210)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponent(ContainerProxyAdapter.java:178)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.appli ed(ContainerProxyAdapter.java:53)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.appliedLi st(BeanProxyAdapter.java:180)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.applyAllS ettings(BeanProxyAdapter.java:525)
org.eclipse.ve.internal.jfc.core.ComponentProxyAdapter.apply AllSettings(ComponentProxyAdapter.java:635)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:754)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:125)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:103)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1663)
at java.lang.Thread.run(Unknown Source)
!MESSAGE Could not instantiate somepackage.MyJPannel with initialization
string=null
!MESSAGE Exception
!STACK 0
errors.
This is the code:
package somepackage;
import javax.swing.JPanel;
public class MyJPannel extends JPanel
This is the example code that uses the above class:
import javax.swing.JFrame;
public class MyJPanelExamleJFrame extends JFrame
private javax.swing.JPanel jContentPane = null;
private somepackage.MyJPannel myJPannel = null;
public MyJPanelExamleJFrame()
super();
initialize();
private void initialize()
this.setSize(300, 200);
this.setContentPane(getJContentPane());
private javax.swing.JPanel getJContentPane()
if (jContentPane == null)
jContentPane = new javax.swing.JPanel();
jContentPane.setLayout(new java.awt.BorderLayout());
jContentPane.add(getMyJPannel(), java.awt.BorderLayout.CENTER);
return jContentPane;
private somepackage.MyJPannel getMyJPannel()
if (myJPannel == null)
myJPannel = new somepackage.MyJPannel();
return myJPannel;
Is this a bug?
thanx!
Marcus
Re: problems extending JPanel [message #24719 is a reply to message #24679] Thu, 11 March 2004 07:49 Go to previous messageGo to next message
Marcus Beyer wrote:
> Greetinx!
> The result:
now I've seen that there are some more messages in the log:
!ENTRY org.eclipse.jem.beaninfo 2 0 Mrz 11, 2004 13:10:15.483
!MESSAGE %Introspection failed on class "somepackage.MyJPannel."
!ENTRY org.eclipse.jem.beaninfo 2 0 Mrz 11, 2004 13:10:15.967
!MESSAGE %Introspection failed on class "somepackage.MyJPanelExamleJFrame."
!ENTRY org.eclipse.jem.beaninfo 2 0 Mrz 11, 2004 13:10:24.467
!ENTRY org.eclipse.jem.beaninfo 2 0 Mrz 11, 2004 13:10:24.951
string=null
Marcus
Re: problems extending JPanel [message #25058 is a reply to message #24679] Thu, 11 March 2004 10:18 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Do you have build on resource changes turned on? This kind of error
usually occurs because your classes aren't being compiled. Try doing a
rebuild all first to see if that allows them to come up.
Thanks, Rich Kulp
Re: problems extending JPanel [message #25465 is a reply to message #25058] Fri, 12 March 2004 06:00 Go to previous messageGo to next message
I think so, but can't find that switch :|
> This kind of error
Thank you! Strange: the error only disappears from the "Java Beans"
view, when I close the Visual Editor of the file referencing the new
class -- and open it again. Is this normal for VE?
In the meantime I have a new (but smaller) problem with this tiny class:
import javax.swing.BoxLayout;
public class XBoxedJPanel extends JPanel
public XBoxedJPanel()
super();
initialize();
setLayout(new BoxLayout(this, BoxLayout.X_AXIS));
When I add this somewhere I don't get an entry for "layout" in the
"Properties" view. The "layout" field is simply empty. Why?
thanx!
Marcus
Re: problems extending JPanel [message #25585 is a reply to message #25465] Fri, 12 March 2004 10:18 Go to previous messageGo to next message
We have problems with BoxLayout. It will take a little time to catch
everything up. New parsing algorithm we are using breaks BoxLayout
because it is special because it requires the parent for construction.
(This is actually a stupid implementation. Layouts aren't meant to be
shared, and they are told who the parent is when they applied, there was
no reason to require it in the constructor too).
Thanks, Rich Kulp
Re: problems extending JPanel [message #25692 is a reply to message #25465] Fri, 12 March 2004 10:53 Go to previous messageGo to next message
Eclipse 3.0 has changed notifications on when things are changed and we
haven't had the time to make it work completely. So it may be necessary
at times to close and reopen an editor if something changes.
Thanks, Rich Kulp
Re: problems extending JPanel [message #25745 is a reply to message #25692] Fri, 12 March 2004 11:05 Go to previous messageGo to next message
Sorry? I am using Eclipse 2.1.2.
Then VE runs also on Eclipse 3?
thanx!
Marcus
Re: problems extending JPanel [message #25752 is a reply to message #25745] Fri, 12 March 2004 12:36 Go to previous messageGo to next message
Not VE 0.5.0. The 1.0.0 drivers do, but they are not up to production
level yet.
We aren't doing any bug fixes for 0.5.0 because we are heads down on
1.0.0 work.
> thanx!
> Marcus
Thanks, Rich Kulp
Re: problems extending JPanel [message #25763 is a reply to message #25752] Fri, 12 March 2004 15:56 Go to previous message
> level yet.
> 1.0.0 work.
I see. I wish you good luck and a nice weekend :)
And thanks for this nevertheless nice tool!
Marcus
Re: problems extending JPanel [message #584228 is a reply to message #24679] Thu, 11 March 2004 07:49 Go to previous message
Marcus Beyer wrote:
> Greetinx!
> The result:
string=null
Marcus
Re: problems extending JPanel [message #584275 is a reply to message #24679] Thu, 11 March 2004 10:18 Go to previous message
Thanks, Rich Kulp
Re: problems extending JPanel [message #584396 is a reply to message #25058] Fri, 12 March 2004 06:00 Go to previous message
> This kind of error
super();
initialize();
thanx!
Marcus
Re: problems extending JPanel [message #584439 is a reply to message #25465] Fri, 12 March 2004 10:18 Go to previous message
Thanks, Rich Kulp
Re: problems extending JPanel [message #584475 is a reply to message #25465] Fri, 12 March 2004 10:53 Go to previous message
Thanks, Rich Kulp
Re: problems extending JPanel [message #584503 is a reply to message #25692] Fri, 12 March 2004 11:05 Go to previous message
thanx!
Marcus
Re: problems extending JPanel [message #584531 is a reply to message #25745] Fri, 12 March 2004 12:36 Go to previous message
level yet.
1.0.0 work.
> thanx!
> Marcus
Thanks, Rich Kulp
Re: problems extending JPanel [message #584561 is a reply to message #25752] Fri, 12 March 2004 15:56 Go to previous message
> level yet.
> 1.0.0 work.
Marcus
Previous Topic:Error in Plugin Installation
Next Topic:error when starting eclipse
Current Time: Sat Jun 28 18:36:24 EDT 2025
Powered by FUDForum. Page generated in 0.16321 seconds
