Home » Language IDEs » Java Development Tools (JDT) » Building in response to .java file changes
Building in response to .java file changes [message #250828] Tue, 22 January 2008 22:16 Go to next message
Originally posted by: rob.brainkandy-dot-org.org
Long series of questions ahead, sorry. I've been working on parts of this
problem for several months, and I have been avoiding this component for a while,
because there are some parts to the problem that I just can't get my head
around. This is in-part a platform question, but since most of it has a
JDT-bent, I thought I'd start here.
I want to maintain a local cache of interesting information in a project. When a
..java file changes (or is added), I want to parse the AST, find some specific
IJavaElement objects, and store them in an in-memory cache for easy access.
Assume for the sake of discussion, this is stored in a Map<IFile,
Set<IJavaElement>> (henceforth called 'map'.)
Note: these IJavaElement objects are not necessarily children of the IFile's
ICompilationUnit.
I'm planning to write either a resource listener or a Builder. It could be
either, but to keep this email clear, I'll just say it's a Builder.
Here are my questions and assumptions:
1. I assume that shutting down Eclipse initiates a close-workspace operation.
and starting Eclipse initiates an open-workspace operation. Also I assume that
using the Switch Workspace UI command initiates the same close-workspace
operation followed by the same open-workspace operation. Am I right, and if so,
how do I register a listener for these events?
2. If I want to cache map, either by
* storing the whole map as a project property, or
* individually as per-file properties, or
* storing it as a derived resource
How do I store an IJavaElement so it can be serialized and reloaded as quickly
as possible?
Alternatively, I could choose to not serialize map, and rebuild it when the
workspace listener hears about the open-workspace operation.
3. What is a good strategy for ensuring that when my Builder learns about
changes in .java files, it's parsing an AST and resolving bindings that are
up-to-date, and don't refer to the state of the compiled project before these
..java files changed?
I suspect what I want is to wait until the JavaBuilder completes before my
Builder even triggers its build command. Is this reasonable? Is it possible? Is
it better for me to have a Builder that listens to changes in generated .class
files, and use that as the impetus for building my map? Or should I write an
IElementChangedListener, and dump the Builder altogether?
Thanks. I hope these questions are clear. I could have asked each of them
separately, making them more likely to be asked, but then you would lose context.
Robert
Re: Building in response to .java file changes [message #250973 is a reply to message #250828] Sun, 27 January 2008 13:19 Go to previous message
> project. When a .java file changes (or is added), I want to parse the
> AST, find some specific IJavaElement objects, and store them in an
> in-memory cache for easy access. Assume for the sake of discussion, this
> is stored in a Map<IFile, Set<IJavaElement>> (henceforth called 'map'.)
> IFile's ICompilationUnit.
> be either, but to keep this email clear, I'll just say it's a Builder.
> operation. and starting Eclipse initiates an open-workspace operation.
> Also I assume that using the Switch Workspace UI command initiates the
> same close-workspace operation followed by the same open-workspace
> operation. Am I right, and if so, how do I register a listener for these
> events?
Don't forget also when a user closes/deletes a project, thus all of its
children resources, or when a user deletes an IResource (IFolder/IFile)
contained by a project/folder. Same thing for adding/renaming
resources. Then you have update your cache accordingly, e.g., removing
invalid entries.
Yes, your builder should also be notified on such events. You might
have to register a listener via the ResourcesPlugin if you want to react
to the event in a PRE-manner, that is, BEFORE eclipse actually performs
the change. There is a PRE/POST event. Eclipse will tell exactly all
the information you need via a delta change of resource. From there
your visitor can visit the delta (a tree) and performs whatever needed
for each of the element(s) in the delta change.
If you want persistency, store in a hidden preference entry, assuming an
IResource's properties are not persisted by Eclipse. If so, that is even
better.
I would use properties rather than derived resource and I would use as
per project rather than per-file, since that would be consistent with
the tree organization of resources in the workspace. The more scattered
the information, the more bookkeeping you will have to do.
> quickly as possible?
Serialized as XML? POJO?
In the past I had done the above in a configuration manner but not a
cache, both as properties, for example, having a project referenced
another project. I had also use POJO to stored serialized info in
dotted file in a project and not showing it. Then I had to write a hook
(using one of the model extension points) to make sure NOT to allow the
user deleting the dotted file in the project.
> the workspace listener hears about the open-workspace operation.
> about changes in .java files, it's parsing an AST and resolving bindings
> that are up-to-date, and don't refer to the state of the compiled
> project before these .java files changed?
> my Builder even triggers its build command. Is this reasonable? Is it
> possible? Is it better for me to have a Builder that listens to changes
> in generated .class files, and use that as the impetus for building my
> map? Or should I write an IElementChangedListener, and dump the Builder
> altogether?
> them separately, making them more likely to be asked, but then you would
> lose context.
> Robert
Previous Topic:Open actual class definition while debuggin
Next Topic:How to find out if an IFile is in a source folder
Current Time: Sun Aug 31 21:12:10 EDT 2025
Powered by FUDForum. Page generated in 0.04789 seconds
